Discovered that input to left or right channel will instigate a rumbling noise from sub , which is still present when signal removed.
Also discovered that if i monitor the plus 173V across one of the main smoothing caps, which is stable with no signal , but when input provided voltage can fluctuate 152V - 168V . Replaced the cap , which made no difference .
The minus 173V across the other cap is fine .
Could really do with some help trying to isolate this issue.
https://youtu.be/MSwIRZFfPc0
