1973 Magnavox. One dead channel.
  • budwich
    • Jul 2015
    • 3097
    Re: 1973 Magnavox. One dead channel.
    how are you physically determining what pins are what? maybe you are looking at the "bodies" wrong?
    • JunkForLess
      • Nov 2021
      • 44
      I made a video: https://www.youtube.com/watch?v=p5KATw6cG-g
      If I did something wrong, I am willing to accept my fate To triple check I used the Magnavox's board, since it has C,B,E labeled for each.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8714
        looks like you're doing it right, the only exception is that we don't see how the probes are plugged into your fluke
        If you can return them to your local dealer, demonstrate it to them that something's fishy. If you can't return them I'd assume the markings are wrong and install them as you identified them as NPN or PNP.
        It's a good thing you checked first instead of soldering them in and frying stuff!
        • JunkForLess
          • Nov 2021
          • 44
          The Fluke has the red lead plugged in at "Volt, Ohms, Diode". Black to "com." You can see it for a split second at the start of the video, but I also tested it with that Proster.
          The place I bought them from were very friendly on the phone, but shipping would be as much as the parts.
          What do you all think? Roll the dice and run them for what they tested as? I could always order another set.. but then I gotta wait for them..
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8714
            Your call. Depending on how much I paid for them and how much it'd cost to refund them, I would use them if I had no fear of completely destroying them. Else the devices aren't what they seem to be, and who knows what's under the lids, some overdriven 2N2222 die... well doubt that, but it makes one wonder...
            • JunkForLess
              • Nov 2021
              • 44
              I don't mind if the new parts burn up, I just don't want to cook anything else in the amp.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8714
                There's always a chance to release the magic smoke, but if you got your pnp and npn in the right slots you're more likely than not at least come up with something that sort of works...
                • JunkForLess
                  • Nov 2021
                  • 44
                  On Mouser is a MJ2955G and 2N3055G made by onsemi. Yay/Nay?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8714
                    Those should be OEM parts, unlike NTE which may have simply bought MJ2955 and 2N3055, rubbed off the markings, painted NTE219 and NTE130 on them, and jacked up the price...
                    • JunkForLess
                      • Nov 2021
                      • 44
                      I wasn't sure if the G at the end meant anything, the specs are spot on tho..
                      I got the NTEs for the same price, that's why I was happy to find them in sets.. but I should have known better...
                      So, I also need the caps for the speaker crossovers, it has a 8mfd 25v. By the look of it, it seems to be a non-polarized with the leads out either end, but it doesn't seem to be a common value.. parts sites always point me to the really little Radial Polyesters..
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8714
                        Appears 2N3055's are on the downward trend, was kind of doubting they'd be making these anymore, it's an ancient part... and NOS is eventually the only way like vacuum tubes. Or chinese/russian clones, like vacuum tubes...
                        The G series is lead free. Probably don't need to worry about it.
                        Same way with axial capacitors - since they are of large, nonstandard sizes they can't be machine placed and nobody wants to make them anymore. You'll have to deal with the radial or NOS units.
                        • JunkForLess
                          • Nov 2021
                          • 44
                          I don't mind if its the exact shape or whatever, I just wasn't sure what I can use as a replacement. For example, the current cap for the crossover is a rather large electrolytic, but could I use a gum drop capacitor of the same value, or a film? I also read that since its 10%, I could use something like a 6.x mfd instead of a 8?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8714
                            yes you can generally use a plastic, paper, or ceramic cap in their place. You shouldn't use tolerance as a way to skirt matching capacitances however, these aren't storing charge (well they are...) but rather to build filters and you need to be exact for filters. Paralleling units is the only way to go. A 3.3uF + 4.7uF should work.
                            • JunkForLess
                              • Nov 2021
                              • 44
                              I ordered some Nichicon UDBs. Set of 2x 6.8s and 2x 3.3s and 2x 4.7 I'll try both ways a try. "Designed specifically for crossover networks in Hi-Fi sound systems." Good enough for my neighborhood..
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8714
                                Using the smaller 6.8uF will shift your cutoff frequencies. Again me, as a non audiophile, I probably can't tell the difference. However it clearly will change how things sound.
                                • JunkForLess
                                  • Nov 2021
                                  • 44
                                  I figured that will allow me to adjust it to stock, then see what it sounds like going up or down a bit.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8714
                                    Curious what was the WPC rating for this amplifier?
                                    Was comparing to this other integrated radio/amplifier I repaired, it uses TO-220 transistors. Supposedly only 15 or 20WPC or so. One of the transistors was fried to a crisp "again" (I saw that it had been reworked before, poorly.
                                    The funny thing is that I swapped the fried transistor with a transistor I chose randomly from my junk box. Well, it wasn't totally random - I knew it was the correct NPN polarity but I couldn't find any details about the particular transistor so I just took a shot in the dark and luckily it worked. After adjusting the bias on the transistor I really couldn't tell if it was sounding weird or not. Seems to work just fine now.
                                    Not sure how it fried but judging by the heat damage some of the plastic took, the old transistor got mighty toasty.
                                    • JunkForLess
                                      • Nov 2021
                                      • 44
                                      I have been told this is a 50 watt model. So I would think that means 25/25?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8714
                                        Don't know, possible. Should be more than what my TO-220s can handle, TO-220s usually limit at around 80W or so before they hit thermal resistance limits of the package. TO-3's can dump more heat, from the 115W 2N3055 and 150W for 2N3771... Note these heat dissipation numbers have nothing to do with WPC but some data could be inferred.
                                        • JunkForLess
                                          • Nov 2021
                                          • 44
                                          The new transistors test correctly.
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                          • mikey5791
                                            Help on car amplifier only one channel works
                                            by mikey5791
                                            Hi all forum members,
                                            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                            08-06-2025, 10:36 PM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • dicky96
                                            American Audio VLP1500 Distorting on one channel
                                            by dicky96
                                            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                            Protection and Clip LED are off
                                            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                            07-13-2022, 05:25 AM
