Micromega CD player repair
  • PowerAmpFreak
    • 982
    • Sweden
    I was doing a ordinary change of a laser unit and mechanism on a Micromega stage CD-player. The laser unit is a Philips CDM12.4.
    After laser change, player refuse to play one single cd. Here is what happens:
    Tray closes. Laser succeeds focusing. Cd starts to spin, though way too fast,
    3 seconds later display shows "ERR".
    If closing tray without having a cd in, the display show "No disc" which means the laser can focus correctly and actually works, right?
    The CDM12.4 laser has an onboard RF amp, as can be seen in the picture.
    Before the laserchange the player actually worked, but had reading problems.
    Any advice is appreciated.
    Best regards
    PowerAmpFreak
    • 31029
    Re: Micromega CD player repair
    disk spinning out of control is an unreadable signal.
    you can get this if the bias or gain on the laser is wrong.
    another symptom is the disk moving in small bursts & the laser lens clicking.
    • PowerAmpFreak
      • 982
      • Sweden
      Thanks for fast reply, stj!
      There are no adjustments for gain or bias, only laser power which is set as the old pickup.
      The cd spins up maximum speed for 3-4 seconds, drops to near zero, and repeats again.
      I wonder what I can do to make it work..
        • 31029
        scope the eye & look at the pot on the laser assembly.
          • 31029
          and look at the caps in the psu, there may be ripple causing the laser to not read clearly.
          • PowerAmpFreak
            • 982
            • Sweden
            You mean scoping the RF amp data output, and watch for the "eye" pattern?
            What do you mean by "looking at the pot"?
            Didn't check for PSU ripple, but all +5VDC was nice and stable.
            • japlytic
              • Oct 2005
              • 2086
              Does the laser emit?
              Most laser assemblies have a switch or a piece of flexible wiring which can be safely cut off (read the service manual first), to protect the laser diode from static.
              • PowerAmpFreak
                • 982
                • Sweden
                Guess it's not possible to focus correctly if laser doesn't emit, right?
                The player can determine if there are a CD or not inside, which I assume is a result of focus ok...
                With no cd display show "No disc", with a disc inside it show "ERR".
                Other lasers I've replaced all did contain a solder jumper which must be desoldered (for ESD protection), but I can't see any on this dude.
                May be probably due to the RF amp fitted on the laser assembly itself, minimizing ESD problems, since laserdiode is "already connected" and properly terminated to the RF frontend.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  no, it may focus well enough to detect a disc, but not well enough to actually read it.
                  sigpic
                  (Insert witty quote here)
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    Yes, so the answer to the question "does the laser emit" must be YES since it's actually able to focus at all, though doesn't read it correctly, right?
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      The laser gives a decent 1V peak-peak RF signal measured right at the RF amp output. The "eye pattern" is visible but not that clear. If memory serves me right the eye pattern should be pretty sharp and clear. So could this mean the new laser is actually bad?
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        Believe it or not, but it appears my "new" laser was an old used one which the company where I ordered it, cannot explain. A new laser unit is on delivery!
                        Hope for better luck next time.
                        • PowerAmpFreak
                          • 982
                          • Sweden
                          The new laser arrived, this time it was new and not used...
                          Unfortunately it didn't make any difference to the repair. It still shows "ERROR" in the display. There are just above 1V peak RF amplitude, and the "eye pattern" is visible. Have no idea why the player refuse...
                          There are no adjustments except for laser power which appears to be good since the RF level is ok. There are a few screws on the laser unit covered with glue so you shouldn't touch these.
                          Anyone having a hint?
                          Regards,
                          PowerAmpFreak
                          • seanc
                            • Nov 2008
                            • 1319
                            Checked the draw is closing and activating any relevant switches correctly.
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              yes, that seems fine, as soon as the tray enters "home" position, the laser unit begin to focus, cd starts to spin, but it speeds up too much, probably because it isn't able to read the disc properly (for any reason)...
                              • king__33
                                • Mar 2014
                                • Malaysia
                                Hi All,
                                I have the same issue for this case on my micromega player too. have anyone resolve this issue ? Thanks
                                • MViktor
                                  • Dec 2016
                                  • Россия
                                  Hello everyone and health!!
                                  I understand, chtema old, but the answer to a question and have not found.
                                  I tried to attach four new CDM12,4. And always result one - ERROR. The eye moves as well as it is necessary by search, and the beam is not present, where that it vanishes. Where?
                                  • olegeisler
                                    • Dec 2016
                                    • 100
                                    • Denmark
                                    Could you please take a picture of the whole player ( without cover ) ?
                                    I might have an idea, but I am not sure it is the correct player I am remembering.
                                      • 31029
                                      the eye pattern must be more that visible, it must be correct - it should look like perfect equal diamonds.
                                      • olegeisler
                                        • Dec 2016
                                        • 100
                                        • Denmark
                                        Check the mainboard. Close to where the laser FFC attach, is there a TDA1300T ?
                                        If yes, change it.
                                        • bogosort
                                          Sony DVD player stuck tray (DVP-SR310P)
                                          by bogosort
                                          I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                                          Anyone knows why?
                                          Thank you....
                                          05-11-2024, 04:29 PM
                                          MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 05:30 PM
                                        • Dannyx
                                          Hilti PD30 Laser Range meter Error 276
                                          by Dannyx
                                          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                                          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                                          07-30-2023, 05:05 AM
                                        • dkneyle
                                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                          by dkneyle
                                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                          02-01-2022, 02:08 AM
                                        • kokopelli75
                                          Victrola multi-player - No audio
                                          by kokopelli75
                                          Hello!
                                          My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
                                          01-11-2025, 03:51 PM
