Victrola multi-player - No audio
  • kokopelli75
    • Oct 2019
    • 6
    Hello!
    My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually, nothing is obvious. No caps look bad or bulging, no cooked resistors. Power regulators are providing voltages in range. Any thoughts on what I can check to identify the bad component(s)? Unfortunately, I'm limited to a multi-meter for test equipment.
    Thanks!
    • 31277
    get a datasheet for the amplifier,
    then check it's getting the right supply voltage.
    if it is then try injecting hum into the input pins to test it.
    • kokopelli75
      • Oct 2019
      • 6
      Hi, thanks for the suggestion, makes sense to bypass the processor to see if the amp is working. I previously did the first part, both vcc pins are at the correct voltage. What's the best way to introduce hum without blowing anything up?
      • kokopelli75
        • Oct 2019
        • 6
        Ok, I injected some noise on right and left inputs, and heard it through the speakers. I guess that means the amp IC is working. Perhaps the sound processor is toast?
          • 31277
          i see some op-amps in the picture, the LM324, says UTC but it's an LM
          LM4558 - again marked UTC,
          the 4066 is a digital switch - probably selecting the inputs.
          i cant see the number on the other 8pin chip or the larger one with pencil on it
          try messing with the opamps
            • 31277
            btw, if it was EMP then the 4066 is pretty vulnerable.
            • kokopelli75
              • Oct 2019
              • 6
              Appreciate your feedback. Will poke around some more. In the meantime, here's a better picture of the whole board with some notes.
              By the way, I was just testing with the radio function, and I can just barely hear some output on the speakers. Changing the volume had no affect. Playing a CD, nothing at all was audible.
              • kokopelli75
                • Oct 2019
                • 6
                Interestingly, I measured 0V at all of the UTC324 Vcc pins (4). 🤔
                • samson7point1@yahoo.com
                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                  by samson7point1@yahoo.com
                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                  The player processes the audio signal using two different reference frequencies. The "R"...
                  04-30-2024, 11:22 AM
                • silver60618
                  Macbook M3 A2991 Speaker Audio Amplifier IC
                  by silver60618
                  Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                  I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                  09-26-2025, 12:25 PM
                • eccerr0r
                  Frying amplifier finals... audio, not rf...
                  by eccerr0r
                  Well for RF transmitters, transmitting without an impedance matched antenna and if the transmitter doesn't have automatic limiting... kiss the final transistor goodbye and chalk one up to something you killed.
                  But that's not the same way with audio amps for the most part, well, at least the wavelength of audio on copper is so long that you get all of it back anyway but the transistor is fine with it...
                  So how are people destroying finals in their audio amplifiers then? Heh.
                  Are people shorting their outputs or something, overdriving output to a too big speaker?...
                  11-27-2021, 12:30 AM
                • nervous_capybara
                  Repairing the Hitachi DA-6000 CD player
                  by nervous_capybara
                  Hello everyone !
                  I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                  Feel free to share your experience if you ran into other issues.
                  DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                  CD tray would not come out of the player
                  I could hear a motor spinning inside the player but the CD tray would not come out.
                  Turned out that the issue was the CD tray belt that aged poorly and began to...
                  11-05-2025, 03:11 AM
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
