Onkyo TX-NR616, constantly clicking, no display, no light/led
  • lcdcaps1
    • Oct 2011
    • 322
    Re: Onkyo TX-NR616, constantly clicking, no display, no light/led
    This is what i get when i check the firmware
    any help appreciated please
    I have tried to do update by using the ethernet cable
    When i try to do them individually using the menu
    it gives the following error
    error!! 5-82
    on vsp and vmpu
    not tried by usb
    I have a a uart cable and a USB CH341A chip programmer
    Many Thanks all in advance
    Please help
    • lcdcaps1
      • Oct 2011
      • 322
      Hey all
      • lcdcaps1
        • Oct 2011
        • 322
        Originally posted by budwich
        try using a USB stick to update as opposed to a network connection.
        Hi
        All
        I have tried to update by USB and still get the same error
        5-82 on vsp and vmpu
        Please can someone send me the firmware so that I can program this myself or upload it
        alternatively can I use the UART cable
        Please can someone reply and assist me, I will be really grateful and appreciate it so much
        Many Thanks
        Kind Regards
        • R_J
          • 9535
          How did you try and update it via usb if you don't have the firmware? Download it from Oink-yo
          • lcdcaps1
            • Oct 2011
            • 322
            Originally posted by R_J
            How did you try and update it via usb if you don't have the firmware? Download it from Oink-E-yo
            i downloaded the official firmware and put it on a USB drive but get an error
            as mentioned
            i read that i can flash the nor chip (q8040) using a chip programmer but i need a firmware dump from another board
            I was also reading that this might be able to be fixed using UART but not sure how
            please i need lots of help
            thanks in advance
            • R_J
              • 9535
              I take it you unzipped the 3 files and the 1 directory to the root of a clean FAT32 formatted usb stick.
              Do you get:
              Select the USB input source.
              “Now Initializing...” appears on the AV receiver’s
              display and then the name of the USB device is
              displayed. It takes 20 to 30 seconds to recognize the
              USB device.
              • lcdcaps1
                • Oct 2011
                • 322
                #27
                Do you get:
                “Now Initializing...” appears on the AV receiver's
                USB device.
                yes i done exactly that but it gives me error 5-82 on vsp and vmpu
                have you used uart on these onkyo amps
                • R_J
                  • 9535
                  No I have not.
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    #29
                    No I have not.
                    ok thanks
                    have you ever seen this error i am having
                    please can you help
                    • budwich
                      • Jul 2015
                      • 3097
                      you might want to check / ensure that those processor boards have the proper electrical conditions (voltage / ground) to allow for proper operation before going down the path of trying to "manually write" the firmware. It is a strong possibility that there is a issue at the board level.
                      • R_J
                        • 9535
                        I have not seen this error, if you look it up on the internet you will see others that have had it. It says it is a time out error.
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          #32
                          Can you help with this Please.
                          I have one screw in the hdmi port to chassis
                          What voltge do I check and where do I check .
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            #33
                            I saw that but I've tried by usb as well so not sure why it is timing out . what can cause this
                            • R_J
                              • 9535
                              Have you checked the update procedure that tells you to configure the amp in a certain way before updating the firmware?
                              • lcdcaps1
                                • Oct 2011
                                • 322
                                #35
                                Yes I did but can't see anything on the tv. Can't get the osd to show. So no way me to turn off things. I have done the rest key combination so I assume it's ok
                                If you know how to then please post
                                • lcdcaps1
                                  • Oct 2011
                                  • 322
                                  #36
                                  I have been thinking it might be a voltage problem but i cant get to the regulators as they are on the bottom of the board.
                                  can I do any tests from the top or can i flip the board over with something underneath and test and
                                  in order to do this do all the cables need to be attached
                                  Thanks so much
                                  please can someone help who has worked on these boards
                                  can someone tell me which regulators please
                                  thanks so much
                                    • 31015
                                    interesting pdf,
                                    so are you just connecting the power cord??
                                    i cant help thinking this thing tries to download something over ethernet!
                                    The firmware update should take 15 to 40 minutes
                                    really??? not from a usb it shouldnt!!
                                    • lcdcaps1
                                      • Oct 2011
                                      • 322
                                      #38
                                      Originally posted by stj
                                      interesting pdf,
                                      I cant get it to do any firmware update
                                      I am leaning towards a voltage problem where the chips are not being powered
                                      Can anyone help with this please
                                      thanks
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        you probably need to look for the source of 3.3v or equivalent that is usually used for logic powering. You don't actually need the actual source (regulator or otherwise) at this point, just check test points on the various boards that show access or provide access to that type of powering so that you can check if it is there or not.
                                        • lcdcaps1
                                          • Oct 2011
                                          • 322
                                          #40
                                          I have tested voltages on the following coils
                                          L8932 - 1.3V
                                          L8942 - 1.8V
                                          L8952 - 3.3V
                                          L8962 - 5.2V
                                          • DProf.
                                            Hp Elitebook 840 g3. Power light constantly on
                                            by DProf.
                                            Hi great minds. Please I have this hp Elitebook 840 g3. When shotdown the system the power light will remain on constantly. Can anyone share any posible solution to this issue. Thank you so much in advance.
                                            02-25-2025, 10:14 AM
                                          • frankusb
                                            Onkyo TX-NR708 standby light
                                            by frankusb
                                            My Onkyo TX-NR708 when plugged in the standby light turns on very briefly than goes out.
                                            I measured relative to GNDMPU
                                            1-MPOWER - 0.0002V
                                            2-+12VDG1+SUB - 11.7V
                                            3-GNDMPU
                                            4-+12RL - 0.318V
                                            5-/POFF - 10.49V
                                            I found that C922 was out of spec and replaced it with a used replacement but no change. I feel like +12RL should be driven by T902 always under normal operation. Is that correct?...
                                            07-16-2023, 11:00 AM
                                            Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                            by sam_sam_sam
                                            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                            I also have back when Light of America had these light bulbs available for yard lights
                                            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                            While the Lithonia lighting fixture has all most certain bulb failure
                                            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                            I have only had this light fixture for not more than a year if it...
                                            07-02-2023, 03:45 PM
                                            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
                                            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 09:10 PM
