Onkyo TX-NR616, constantly clicking, no display, no light/led
  • lcdcaps1
    • Oct 2011
    • 322
    Hi
    I have an Onkyo TX-NR616 that has is constantly clicking when I plug it into the mains
    I can hear the relay clicking but also the transformer is vibrating not sure why
    I have tried with all the ribbon cables connected and with just JL901B connected but same symptoms
    I have tried with fan and no fan
    I have followed this thread
    repairalmostanything.com/thread/790/onkyo-relay-constantly-clicking-txnr
    I have replaced the components mentioned on this thread with hope that it will turn on but with no success
    I am a novice when repairing Amplifiers but know a little about electronics but always wanting to learn more
    This is My own Amplifier and is well looked after like a baby
    I had to open because I needed to check for leaking caps as I was not getting any HDMI output
    Please can someone help me fix this. I will be so grateful and will appreciate it so so much
    There are allot of talented people here so I look forward in getting to know you all and
  • lcdcaps1
    • Oct 2011
    • 322
    Re: Onkyo TX-NR616, constantly clicking, no display, no light/led
    Hi
    Please can anyone help me
    • petehall347
      • Jan 2015
      • 4450
      if it worked before apart from the hdmi best i can suggest is putting everything back to how it was then see if it is back to square one .
      • lcdcaps1
        • Oct 2011
        • 322
        Thanks for the reply
        I read on another forum it is due to certain components failing ..
        So I replaced those bits but no change as mentioned in the link in the link i posted
        I've been reading the forums and reading allot .
        Some people have had similar issues and it has been the thermal fuse but I don't think it is this because I have few ohms across the primary side of the transformer but i am confused which wires are the thermal fuse wires but there is continuity between all the wire
        The other thing I read is it could be a grounding problem.
        I Did not put the screws back that go into the hdmi board and the power supply board is held by top screw only .
        Can this be the problem .
        The other thing I read is the the cable coming from the power supply board to the hdmi board is not seated properly
        I have checked and checked but makes no difference.
        Will adding the screws that secure the hdmi board to the chassis and the screw that secures the hdmi board to the board on the right, not sure what board it is plus the power board screw that secure it to the chassis make a difference
        Please can you help me .
        Thanks so much
        • petehall347
          • Jan 2015
          • 4450
          try and see
          • lcdcaps1
            • Oct 2011
            • 322
            try and see
            Have you had similar issues in the past
            • lcdcaps1
              • Oct 2011
              • 322
              I have put all the screw back for the power supply board that secures it to the chassis and I put two screws securing the hdmi board to the chassis*
              I tested ground from pin 3 from jl901b to the chassis and it was a good ground. Near to the same as when I touch my meter probes together.*
              I get voltage on the cable coming from the power supply* board that connects to the hdmi board*
              Below are measurements taken from when the cable is plugged into the hdmi board*
              Pin 1 is 12v but when relay clicks it goes down*
              Pin 2 is 0v
              Pin 3 is GND*
              Pin 4 is 12 v
              Pin 5 is 0v
              I read that if I put jumper wire from Pin 1 and Pin 3 on jl901b which is on the hdmi board the relay should latch but with the transformer cable removed*I tried this and got nothing*
              I tested the relay and got about 300 ohms*And the relay is clicking*
              I am really stuck and will appreciate some detailed help from this amazing community Please*
              Many Thanks*
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I’d start looking for anything shorted first just anything you can, relays don’t just click on and off like that unless there’s something wrong.
                • lcdcaps1
                  • Oct 2011
                  • 322
                  Where do i start looking
                  on the power supply board or the hdmi board
                  I have not worked on such amplifiers before so any help will really be much appreciated
                  If there are any onkyo experts, please reply
                  Thanks so much
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    The relay is working
                    i have tested by jumping the wire pin 1 and pin 3
                    there is a strong latch
                    • lcdcaps1
                      • Oct 2011
                      • 322
                      I have been doing more voltage measurements. The results are below
                      I tested q7018
                      pin 1 is gnd,
                      pin 2 is 4.8v
                      pin 3 is 3.3v
                      also tested q7019
                      pin 1 is gnd,
                      pin 2 is 11.89v - 11.90v
                      pin 3 is 5.6v
                      Nothing is getting hot and i cant see any bulging caps
                      Please will really appreciate all the help from this forum
                      Many Thanks in advance
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        After some probing and testing resistors
                        I came across F201, that shows no continuity.
                        I am not sure how this has blown, there are no marks or anything
                        Would this cause for it not to turn on
                        Please someone help
                        Thanks all in advance
                        • R_J
                          • Jun 2012
                          • 9624
                          That fuse is in the a/c input for D201 bridge rectifier that supplies +12volts to the hdmi board. It also supplies a voltage via D204 to the POFF2 line on P2800A which connects to Main Micom Q7009
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            Can this fuse stop the unit on turning on and causing the relay to constantly click as it is
                            I measured and i had 12v on pin 1 and pin 4 on jl901b
                            maybe this was not enough to turn the receiver on
                            I will appreciate all your help please
                            Thanks again
                            • R_J
                              • Jun 2012
                              • 9624
                              Look at the schematic and you will see what it is for, This is the +12VD(ANA), +12TRG and the POFF2, it is not the same 12 volts that supplies the relay.
                              • lcdcaps1
                                • Oct 2011
                                • 322
                                Thanks. Yes I saw that. Was trying to post a reply but wouldn't post. Thanks. Will put a replacement fuse
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  First use your meter to check for continuity from the fuse to ground otherwise it might just blow again.
                                  • lcdcaps1
                                    • Oct 2011
                                    • 322
                                    I checked that and Will recheck again
                                    Will report back
                                    Thanks all
                                    • lcdcaps1
                                      • Oct 2011
                                      • 322
                                      Hi
                                      I have got My Onkyo Tx-NR616 to turn on but there is no HDMI OUT displaying on the TV
                                      I have gone through debug mode and the firmware check
                                      V and K shows no firmware details
                                      I have tried doing the firmware update using the key combination and using the ethernet cable but get error
                                      "error!! 5-82"
                                      Is there any way to force the firmware update please
                                      Or using the uart interface
                                      I am really stuck and need some help
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        try using a USB stick to update as opposed to a network connection.
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • DProf.
                                          Hp Elitebook 840 g3. Power light constantly on
                                          by DProf.
                                          Hi great minds. Please I have this hp Elitebook 840 g3. When shotdown the system the power light will remain on constantly. Can anyone share any posible solution to this issue. Thank you so much in advance.
                                          02-25-2025, 10:14 AM
                                        • frankusb
                                          Onkyo TX-NR708 standby light
                                          by frankusb
                                          My Onkyo TX-NR708 when plugged in the standby light turns on very briefly than goes out.
                                          I measured relative to GNDMPU
                                          1-MPOWER - 0.0002V
                                          2-+12VDG1+SUB - 11.7V
                                          3-GNDMPU
                                          4-+12RL - 0.318V
                                          5-/POFF - 10.49V
                                          I found that C922 was out of spec and replaced it with a used replacement but no change. I feel like +12RL should be driven by T902 always under normal operation. Is that correct?...
                                          07-16-2023, 11:00 AM
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
