Onkyo TX-NR616, constantly clicking, no display, no light/led
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo TX-NR616, constantly clicking, no display, no light/led
    I'm keep saying to you, that you need to solder wires to those joint, where you want to measure.
    Look up each IC's schematic, that you want to measure and find the Vcc pin and solder a wire to that.
    • lcdcaps1
      • Oct 2011
      • 322
      #62
      Hi
      I can solder a wire but does the hdmi board need to be connected to test for voltages on the component on the board below
      Have you used J-link on these receivers to flash the firmware please
      • tibimakai
        • Jan 2012
        • 3680
        You solder a long wire, and install the board, that way you can measure the wire outside.
        • lcdcaps1
          • Oct 2011
          • 322
          #64
          ok great thanks
          i will get on to it
          • Sisko
            Onkyo-593 No power and now clicking sound
            by Sisko
            Hi all!!
            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
            10-03-2025, 02:18 PM
          • DProf.
            Hp Elitebook 840 g3. Power light constantly on
            by DProf.
            Hi great minds. Please I have this hp Elitebook 840 g3. When shotdown the system the power light will remain on constantly. Can anyone share any posible solution to this issue. Thank you so much in advance.
            02-25-2025, 10:14 AM
          • frankusb
            Onkyo TX-NR708 standby light
            by frankusb
            My Onkyo TX-NR708 when plugged in the standby light turns on very briefly than goes out.
            I measured relative to GNDMPU
            1-MPOWER - 0.0002V
            2-+12VDG1+SUB - 11.7V
            3-GNDMPU
            4-+12RL - 0.318V
            5-/POFF - 10.49V
            I found that C922 was out of spec and replaced it with a used replacement but no change. I feel like +12RL should be driven by T902 always under normal operation. Is that correct?...
            07-16-2023, 11:00 AM
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
