DC detection circuit failure on Subwoofer
  • Durenth
    • Nov 2020
    • 11
    • FRANCE
    First of all sorry for my English and for my poor knowledge in transistor behavior, I'll do my best to be clear…
    I have a problem with the DC detection circuit of a Panasonic 40W Subwoofer, model SW-P270.
    The relay in the DC detection circuit never turns on thought there is no DC in the audio output signal.
    Output signal is ok, controlled with an oscilloscope.
    I found the service manual (full board schematic attached to this post) and measured the voltage as shown below, pink is the expected value indicated in the manual, red is my reading:
    First of all, I suspected a failure on Q13 (NPN Transistor), so I removed it and got those new readings:
    Getting closer but still doesn't trigger the 24V relay and created a problem with the R19 resistor which began to overheat.
    I have multiple questions to ask you:
    1. About the overheating resistor:
    Voltage at B+ being +35V, if Q10 is on then, if I'm not mistaken, there should be a +35V voltage drop at R19.
    R19 being a 330 Ohm / 2W resistor it cannot dissipate U²/R = 35²/330 =3.7W so I must be missing something…
    Could you tell me what I got wrong? There is no voltage drop in the relay right?
    2. A curiosity question:
    In the schematics I see that Q11 is supposed to be on (Vce = 0V and Ve=0.8V) with only Vbe = 0.5V when I understand it should be at least 0.6V to turn on a transistor… Maybe there's a tolerance but then why creating a circuit so close to the limits.
    Again, I must get something wrong, do you have any explanation for me?
    3. About my main problem:
    The schematics says I should get Vbe = 0.7V on Q10, in my circuit I have reading of 0.6-0.1= 0.5V that, I believe is not enough to fully trigger the transitor and explains the 10.6 V voltage drop on Vce.
    I also get lower voltage on many other rails as shown on the second schematics.
    I thought of replacing Q11 and Q10 but I fear there are other problems in my circuit…
    I double checked my measurements with to different multimeter one Fulke and one ChauvinArnoux.
    Do you think changing Q11 and Q10 will do? Then I fear for the over heating R19 resistor…
    Thanks for your time and for your help, it was a long post!
    Bye Bye
    Re: DC detection circuit failure on Subwoofer
    Just for testing, you should be able to short the E and C pin of Q11 to force on Q10.
    "Voltage at B+ being +35V, if Q10 is on then, if I'm not mistaken, there should be a +35V voltage drop at R19.
    R19 being a 330 Ohm / 2W resistor it cannot dissipate U²/R = 35²/330 =3.7W so I must be missing something…"
    You will not have Vdrops of 35V on R19 because you also have 24V relay coil resistance + Vdrops on Q10.
    What are Vdrops of R19 and the Vdrops of the relay right now?
    • Durenth
      • Nov 2020
      • 11
      • FRANCE
      Hi Budm,
      I shorted E and C pin of Q11 and Q10 beavior didn't change for what I can understand, I got the same readings as before Vce=10.6V on Q10 and the relay didn't trigger.
      I know have :
      R19:
      24.5V voltage drop
      Q10:
      Vce=10.5V
      Vbe=0.6V (0.7V when Q11 is shorted)
      Vcb=9.9V
      Relay:
      0V voltage drop
      Just for you to know, I did try the relay offboard, it's operative and starts triggering at 20V.
      Do you think D4 could be the cause of the problem?
      Thanks for your help!
        "Relay: 0V voltage drop"
        You need to check the DC resistance of the relay coil and the dc resistance of snubber diode D4, suspecting shorted D4.
        • redwire
          • 3912
          These circuits can be hairy because they're trying to do so much with a few transistors - DC detect, power on delay, AC fail, over temperature etc. I see maybe two problems.
          With Q13 removed, Q10 is not fully on (low beta) at VCE 10.6V, OR it is overloaded. I second the notion of a shorted zener D4 or relay coil. OSA-SS-224DM3 24VDC relay should have a coil resistance of 1,100 ohms needing at least 18V to pull in. R19 should never smoke, it drops the 35V down to something the relay is comfy with.
          Because of the large voltage drop across R21, you know there is base current flowing into Q10 so it should be on. Using the VBE measurements i.e. 0.5V or 0.7V does not tell you the full picture. Some transistors are naturally 0.55V to 0.75V it does vary, especially with temperature.
          Q12, Q13 are special "muting" transistors KTC2874 which have a reverse-beta and can actually conduct a bit backwards. So a + or -ve DC offset can activate Q12.
          Q13 is for fast off when AC is switched off, the -31.6V rail falls faster than the +12V rail.
          Q13 also has high reverse E-B voltage spec 25V, which it does not seem to meet so it could be bad.
          • petehall347
            • Jan 2015
            • 4429
            • United Kingdom
            also r19 resistance .
            • redwire
              • 3912
              Odd that R19 350R is a 2W part but my math says it dissipates 0.2W for the 24mA and 8.5V it would drop.
                Since the B+ is 35VDC , relay is 24VDC coil, so the Vdrops on the R19 should be around 10 ~ 11VDC.
                • Durenth
                  • Nov 2020
                  • 11
                  • FRANCE
                  Thanks to you all for your replies and your help.
                  So D4 is short dead as Budum and Redwire suspected!
                  I took D4 off the board and I now have 1,050 ohms on the relay, good
                  I don't want to damage anything without what I understand to be a flyback diode, so I'll try to find a replacement diode on some other board before turning on the device again.
                  Redwire, thanks for your detailed explanations. You guys do also believe Q13 is bad if I understood everything well.
                  Just got back from work so I'll look into your explanations in details tomorrow, as I told you in my first post, I'm really not familiar with transistors so I'll work on it!
                  Bye and Thanks again
                  • redwire
                    • 3912
                    Good to find a problem With the shorted zener, R19 and Q10 would be overloaded and may be damaged from the heat. I'd check R19 and then run it to see if Q10 is doing OK.
                    Q13 seems to be fishy. You should be seeing -10V at Q13 base but are seeing -5V. It's spec is min. -25V withstand VEB so it looks leaky. Could swap it with Q12.
                    • Durenth
                      • Nov 2020
                      • 11
                      • FRANCE
                      Hi!
                      First of all R19 is ok: 330 Ohms.
                      Unfortunately I can't manage to find a equivalent Zener diode for my dead MTZJ24 so I still can't power up the board and try Q10.
                      I believe the D4 is a Zener in order to maintain a stable Voltage drop on the coil and protect it from overvoltage.
                      If I'm correct with R19 being 330ohm, the voltage on the relay shouldn't exceed Rrelay*(Ub/(R19+Rrelay)) = 1100*(35/(330+1100)) = 27V.
                      The relay datasheet states that it can handle up to 30V, so I thought I could put a regular diode for testing and maybe replace it later with a correct 24V Zener Diode.
                      Do you think I'm right and I can try it that way without damaging anything?
                      Then for the choice of the regular diode I should put in my circuit...
                      D4 (MTZJ24) datasheet says :
                      I looked for 500mW diodes in my spare parts supplies and I found myself with a few options:
                      1N4001:
                      1N4148:
                      1N4448:
                      BAV20:
                      I was going for 1N4001 500mW with Vrrms = 35V, but not really sure it's the best choice.. What do you think?
                      I "usually" use donor boards or order the exact same part when fixing my stuff so as you can see I'm not really practical with choosing...
                      Bye Bye!
                      • redwire
                        • 3912
                        The zener circuit is a bit weird, I think to prevent mains sags from cutting out the relay. Nobody likes a sub cutting out when the bad guy explodes lol.
                        A diode is used to suppress a relay coil's back EMF, the -ve voltage spike due to coil inductance that will damage the driver transistor.
                        But in this circuit, the zener acts as an ordinary diode for coil back EMF, and in the reverse direction it regulates the relay coil's voltage to around 24VDC.
                        Actually a relay is not finicky about the voltage it gets, so a zener is not typically used there.
                        MTZJ24B is a 1/2W 24V zener, I would upsize to 24V 1W zener 1N4749A there, for long life. Your old zener is running over spec 0.6W and why it died.
                        Just a plain 1N4001 or better would work- assuming the relay coil gets around 22-26V. If you have high mains voltage, instead of 33V you have 35V so a bit extra the zener gets rid of. But the relay will just run a bit warmer and not be an issue.
                        A diode's peak and RMS voltage ratings - here it can see around 35V max. so a 1N4001 (50V) or better is fine. A 1N4148 is OK too because the coil current is around 25mA, the back EMF is also 25mA max.
                        I thought R19 could even be higher in value, even 400 ohms.
                          Do you have 1N4007 to use sincee back EMF can be 100's of Volt from 24V coil? The snubber diode will try to clamp it down to Vf of the diode.
                          • redwire
                            • 3912
                            The design is a 24V zener regulator for the relay coil when it is on, and a diode 0.7V for clamping the back-EMF. Not the usual circuit.
                            Zeners are used for a back-EMF clamp when you want fast relay switching. The coil's magnetic field collapses very slow with a diode at 0.7V compared to a high voltage (zener) clamp.
                              I do not think in this case the relay release time (speakers disconnected when error occur) is much of a factor.
                              The zener being used in this case will also clamp to 0.6V (compared to your figure 3 which is not the case), but when relay is energized, the zener will clamp the relay col Voltage to 24V, they may have done that because the 35V power supply is not regulated power supply so the if the incoming AC can go up and down.
                              • Durenth
                                • Nov 2020
                                • 11
                                • FRANCE
                                Hooray It works!!
                                I've replace the Zener with a regular 1N4001, just for testing (I also I ordered a 1N4749A diode for the long term fix).
                                I'm kind of busy lately so didn't have the time to go probing around the circuit, I can only say that voltage drops around the relay are now back to normal and that I can here the beautiful sound of the relay turning on when I power up the board! I also tried with audio input and the signal reaches the speaker connector.
                                So tomorrow I'll try Q13 again
                                Again thanks for your explanations and for your time, I've also read some articles related to your answers and began to understand much better how this circuit works.. Exciting subject!
                                  I doubt that there is any problem with Q13.
                                  • Durenth
                                    • Nov 2020
                                    • 11
                                    • FRANCE
                                    Unfortunately when Q13 is back on the board, it doesn't work anymore..
                                    Q13 seems to leak between Base and Emitter and drops the voltage to a negative -0.5V at the base of Q10, thus not allowing the relay to turn on.
                                    Voltage measurements are almost the same as the red ones in my first post..
                                    After a lot of research, I found what I believe to be a good replacement for Q13, an other muting transistor with almost the same characteristics except for Collector Power Dissipation that is 400mW instead of 625mW on the existing transistor.
                                    For what I understand Q13 is almost never, or let say for a very brief amount of time, conducting (when fast-off), for that reason I thought it might not be a big deal if Pc is lower on my replacement part..
                                    What do you think?
                                    Q13 / C2874 :
                                    My best replacement (actually, I found other but tehrer not available online) / 2SC2878:
                                    Bye!
                                    • petehall347
                                      • Jan 2015
                                      • 4429
                                      • United Kingdom
                                      you might be better with a matched pair for q12 q13 ... not 100 percent on that though .
                                        "Q13 seems to leak between Base and Emitter and drops the voltage to a negative -0.5V at the base of Q10, thus not allowing the relay to turn on."
                                        Emitter of Q13 is connected to circuit ground so leakage between Base and Emitter will cause low negative reading.
                                        So if Q13 is not in place what is the Voltage on the Base of Q11? To have negative on Q11 the leakage will be from Base - Collector junction of Q13.
                                        I also cannot see how you can have negative Voltage on the Base of Q10 unless you have negative on the Base of Q11 and it also has bad leakage on the Emitter-Base of Q11 (Negative Voltage on the Base of Q11 = Reverse Bias of Q11 E-B junction which means there will be no current flow)) to let the negative Voltage get all the way to the Base of Q10.
                                        I think you need to report the Voltage readings of all the Base Voltages (with ref to circuit ground) of the Transistors when Q13 is in place.
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • CoppellTVRepair
                                          Troubleshooting PFC with SPC1012T not raising output
                                          by CoppellTVRepair
                                          It has been a long while since I posted here to ask anything....hope you can help.
                                          I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                                          I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                                          03-09-2025, 10:38 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
