DC detection circuit failure on Subwoofer
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: DC detection circuit failure on Subwoofer
    Q12 and Q13 though are the same part number, but don't need to be matched looking at the circuit configuration. You could try putting Q12 into Q13 slot and leave Q12 open (or use another cheap transistor here) to see if it works but I think Q13 slot may be a transistor killer in the long term, though the spec sheets seem to indicate the KTC2874 is a bit more robust than the typical 2SC945, 2N3904, 2N2222, etc.-like transistors which would not like being put in that kind of circuit.
    So make sure you use an authentic KTC2874 if you buy one, if the KTC2874 datasheet is trustable to begin with (translation: DO NOT SUBSTITUTE IF DATA SHEET IS REAL!). Position Q12 is a bit more safe for substitution, you can use a cheap 2sc945 or something like that here instead when you borrow the KTC2874 for Q13.
      Vebo of the original Q13 Transistor is 25V so what ever you use make that spec is also matched the original, 2n2222 has Vebo of around 6V, you can see the E-B junction of Q13 is exposed to reverse bias of 10V or more.
      • Durenth
        • Nov 2020
        • 11
        • FRANCE
        Hi!
        First off all I'll answer Budm question:
        "I think you need to report the Voltage readings of all the Base Voltages (with ref to circuit ground) of the Transistors when Q13 is in place."
        Here are the voltages with Q13 removed. They're all matching the service manual references (indicated in pink):
        Here are the voltages when I put Q13 back in place:
        If I got you well Budm, you think Q13 is bad but the problem is a leak from base to collector?
        • Durenth
          • Nov 2020
          • 11
          • FRANCE
          eccerr0r, if I substitute Q13 with Q12, it works fine.
          But then I don't have the DC protection in the audio signal anymore.
          So find myself with the problem of the replacement for Q12.
          It's kind of hard to find a C2874, I only found an Ebay shop in Great Britain that have some and they're quite expensive..
          I understand you say a 2sc945 will do but don't you guys think the 2SC2878, that is exactly the same as C2874 (see my post above with datasheet) except for the Collector Power Dissipation that is 400mW instead of 625 mW is also ok?
          Then I'm curious about the "Q13 slot may be a transistor killer in the long term". If you have time could you tell me why? Maybe In can improve the circuit if I get to understand the issue..
          Bye!
          • Durenth
            • Nov 2020
            • 11
            • FRANCE
            I think I should add that the "audio signal form speaker" is AC +/-18V
            It might be important though the RC (R27/C25) circuit on the base of Q12 filters it if I understood the circuit correctly...
              Q12 is for detecting + DC offset of the amplifier output and shutdown the relay by killing the bias for Q11, when Amp output has - DC offset, Q11 will be bias off due to reverse bias.
              So right now you have problem with leaky B-C junction of Q13, D18 is clamping the negative Voltage to - 0.5V because it is forward bias by that -4.5V Voltage source.
              • Durenth
                • Nov 2020
                • 11
                • FRANCE
                #27
                Ok, thanks! So 2SC2878 is ok: it has a Vebo of 25V
                  2SC28278 is fine, you are not dissipating that much power in that section of the circuit.
                  They could have put 4.7V zener to clamp the maximum reverse Voltage on E-B junction to -5V so you do not need to get such high Vebo spec.
                  Q13 is used to turn off the relay when AC power is removed, C13 negative power supply filer will go away fast when AC power is removed then Q13 will be bias on by the 12V supply (which drained slowly) via R34..
                  So basically, the speaker relay must:
                  1) Delay turned on when AC is first applied to the unit so the speaker will not pop due to amplifier need settling time for the AMP DC off set to be at 0V..
                  2) Protect the speaker when it detects + or - Voltage offset of the amplifier that will damage the speaker.
                  3) Turn off the real fast when AC power is removed.
                    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                    I was working on this CNC machine today found no keyboard functioning no control relay powering on
                    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                    Found shorted diodes on main controller relays there are 3 of them that...
                    01-07-2023, 05:43 PM
                  • npielawski
                    MacBook Pro late 2016 (820-00239) with multiple failure modes.
                    by npielawski
                    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                    10-15-2025, 01:53 AM
                  • valvashon
                    Repair Success! Middle Atlantic UPS2200R-IP
                    by valvashon
                    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                    02-06-2024, 12:54 PM
                  • Astonished
                    Fixing the Charge Circuit of the Batteries of the DC Motor
                    by Astonished
                    Hi friends of electronics
                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                    Please help me fix this circuit.
                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                    01-28-2025, 06:24 AM
                  • CoppellTVRepair
                    Troubleshooting PFC with SPC1012T not raising output
                    by CoppellTVRepair
                    It has been a long while since I posted here to ask anything....hope you can help.
                    I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                    I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                    03-09-2025, 10:38 PM
