First of all sorry for my English and for my poor knowledge in transistor behavior, I'll do my best to be clear…
I have a problem with the DC detection circuit of a Panasonic 40W Subwoofer, model SW-P270.
The relay in the DC detection circuit never turns on thought there is no DC in the audio output signal.
Output signal is ok, controlled with an oscilloscope.
I found the service manual (full board schematic attached to this post) and measured the voltage as shown below, pink is the expected value indicated in the manual, red is my reading:
First of all, I suspected a failure on Q13 (NPN Transistor), so I removed it and got those new readings:
Getting closer but still doesn't trigger the 24V relay and created a problem with the R19 resistor which began to overheat.
I have multiple questions to ask you:
1. About the overheating resistor:
2. A curiosity question:
3. About my main problem:
Thanks for your time and for your help, it was a long post!
Bye Bye
Voltage at B+ being +35V, if Q10 is on then, if I'm not mistaken, there should be a +35V voltage drop at R19.
R19 being a 330 Ohm / 2W resistor it cannot dissipate U²/R = 35²/330 =3.7W so I must be missing something…
Could you tell me what I got wrong? There is no voltage drop in the relay right?
In the schematics I see that Q11 is supposed to be on (Vce = 0V and Ve=0.8V) with only Vbe = 0.5V when I understand it should be at least 0.6V to turn on a transistor… Maybe there's a tolerance but then why creating a circuit so close to the limits.
Again, I must get something wrong, do you have any explanation for me?
The schematics says I should get Vbe = 0.7V on Q10, in my circuit I have reading of 0.6-0.1= 0.5V that, I believe is not enough to fully trigger the transitor and explains the 10.6 V voltage drop on Vce.
I also get lower voltage on many other rails as shown on the second schematics.
I thought of replacing Q11 and Q10 but I fear there are other problems in my circuit…
I double checked my measurements with to different multimeter one Fulke and one ChauvinArnoux.
Do you think changing Q11 and Q10 will do? Then I fear for the over heating R19 resistor…
Bye Bye
