Help diagnosing Pyle Receiver PTA66BT with burned resistors
  • SluggerB
    • Aug 2020
    • 747
    • US
    #121
    Re: Help diagnosing Pyle Receiver PTA66BT with burned resistors
    OK, I soldered the 2W resistor in. With chips A-E & the power LED connected (F, G, and the CD IC disconnected), I read 6.23v across it.
    I soldered back in the resistors to connect up chips F & G. With chips A-G & the power LED connected (CD IC disconnected) I read 7.66v across it. The VCC+ of chip F & G were around 5v each (A-E are ~10v)
    I soldered back on the resistors and all the other components connecting the CD IC to the board, and read 11.70v across the new resistor. I took out my thermometer and the temp seems to stabilize at 137F-139F degrees. Certainly to hot to touch for more than a second, but I saw no white smoke and no burning resistor smell.
    Now here is where I earn my idiot reward. I was checking the fan, and I disconnected it to the board and connected the ends to a 9v battery, and it spun. So I thought maybe somehting is wrong with the board not turning it on, how about I just wire it right to the main power supply going into the unit? Nothing bad could happen by dumping 120 AC into a small 12v DC fan, could it?
    So yeah, now I need a new fan. And annoyingly its a 60mm fan and all I have on hand are 80mm fans, and even more annoyingly the unit is like 75mm tall so I can't fit an 80 in there as a replacement. Sigh
    So I'm ordering a new 60mm fan, I don't want to run the unit for a long time without the cooling fan attached, so while it's back together I have not extensively tested it yet. When I get the new fan in and run it through it's paces I will let you know what happens.
      Now here is where I earn my idiot reward. I was checking the fan, and I disconnected it to the board and connected the ends to a 9v battery, and it spun. So I thought maybe something is wrong with the board not turning it on, how about I just wire it right to the main power supply going into the unit? Nothing bad could happen by dumping 120 AC into a small 12v DC fan, could it?
      So those Voltages are for the 180 Ohms 2W for the V+ only? No change in the reading for the 180 Ohms for the V-, correct?
      "I took out my thermometer and the temp seems to stabilize at 137F-139F degrees."
      So if room temp is 70F then temp rise is 69F (about 20c rise), so that is way below the handling spec of two Watts resistor.
      According to the chart for 2W with power dissipation of 0.76W (11.70V on 180 Ohms, 37.50 % of power rating ratio), the temp rise is expected to be
      50c (122F), so the resistor is cooler than expected since temp rise is only 69F.. less rise than using 1W dissipating 0.76W.
      • SluggerB
        • Aug 2020
        • 747
        • US
        #123
        Yes. I didn't check voltage on the V- cause I didn't add anything back onto it.
        The room was about 64 degree that I was working in. So about a 76F rise. But that's still less than 122F. I also mounted the resistor about as far above the board as the legs would lift it.
          "But that's still less than 122F" Do you want to see 122F temp rise instead?
          Well, it is good that the measured temp rise is not 122F, if it is then the resistor will be 191F!, the lower the measured temp rise you see the better.
            BTW, can you get a hold of Oscilloscope and know how to use it?
            • SluggerB
              • Aug 2020
              • 747
              • US
              #126
              That would be a no and no.
              Replacement fans showed up, tonight I install the new fan, button everything up, and run the unit for 30 minutes straight and see if it holds up. If it passes that test it's back to the owner on Saturday.
              • SluggerB
                • Aug 2020
                • 747
                • US
                #127
                No, I was saying it's less than 122F, which is a good thing.
                • SluggerB
                  • Aug 2020
                  • 747
                  • US
                  #128
                  Final update: I installed the new fan, plugged in a speaker, connected to my phone's Bluetooth, and played about 30 minutes of music. I kept the thermal probe resting on the new 2W resistor and it held steady at 137-139F the whole time. I reassembled the unit, gave it one last test run, and I'm calling it fixed. It goes back to the owner on Sat.
                  Again huge huge huge thanks to budm for all the help, I've learned a ton and had a blast! Here's to the next one!
                  • petehall347
                    • Jan 2015
                    • 4448
                    #129
                    59.4444C sounds lots better than in F ... if the owner is happy that is what matters . if it comes back graft in a better power supply for that circuit and maybe add a fuse or 2 .
                      Thanks for the follow-up.
                      • PMan976
                        • Jan 2020
                        • 9
                        I tried following this as best as I could and I am probably missing something.
                        I have a unit that has the exact same issue with that resistor burned up. Does anyone happen to remember what was the cause?
                          It is due to failed Voltage transistors, read post 41 and lots after that.
                          • PMan976
                            • Jan 2020
                            • 9
                            Thank you budm, I replaced all of the blown transistors and also upgraded the Resistors to 3 watt. The unit is working great now. Your input was most helpful.
                            • snoozr
                              • Feb 2012
                              • 5
                              #134
                              I also had this same issue. I replaced the transistors and used the 2 watt resistor. Any idea what would cause distortion in this unit. I'm using bluetooth but can not turn the sound up very much due to distortion.
                              Thanks. By the way I think budm deserves an award for most patient member
                              • dragonmas
                                • May 2018
                                • 9
                                May be a day late and a dollar short but I took a pta66bt-A good working and either pulled and tested every active component made pictures took voltage readings dl data sheets.I used these findings and am in process of repairing same model unit with blown 180 ohm 1 watt resistor.
                                Every d716/2SD716(30-35 watt)(2SD718)(35-40 watt) checks good Collector( pin 2)(base pin 1)(emmiter pin 3) and c-b is .55 ,c-e reads OL(infinity or open) b-e OL using black lead(reference) on Fluke 77 diode check. Voltage on 7805(input 29v output is 5.02)voltage drop of 180 resistor toward speaker connection =24/31 180 toward the front is -24/-31.KIA4558p(op amp) pin 4 -11.9 pin 5 is =11.9.Connection(ribbon cable) from main board to ps board 5v=5v +v=11.9 -v=-11.9.These readings are from the good working unit only difference is the power tx's they are 2SD718(35-40 watts) waiting on the 180's. and op-amp.Can not find anything dead shorted on the bad PS board on the bad unit.
                                • Flacooo1
                                  • Jun 2017
                                  • Usa
                                  #136
                                  Hi everyone and thanks for those that are helping on this tread I Know is kind of old now, I have some help not the real fix just some help, the burned resistor is NOT 180ohm I have 3 units 2 pta66bt one brand new and one burnt that i purchase off ebay for $25 and one brand new pta44bt that stopped working but with warranty, so I sended the pta44bt to pyle and they in fact fixed I don't want to open the unit and see what they did to it but i can confirm they put a bigger resistor same ohm but 2w and it looks like the 3 caps next to it are bigger in size I don't have pictures of that one from inside since I did not opened but i do have pictures from the pta66bt new unit and burnt unit, on the burn unit i put a 2w 100ohm resistor and it did smoke as well so next is to check transistors and see if i can upsize the caps
                                  • dragonmas
                                    • May 2018
                                    • 9
                                    Have repaired about 4 burnt resistors units. None have had fans running. Bought new unopened 66bt.It's fans not running. Traced 12v+ line of fan back to 47ohm-66ohm b647 have 32 Vdc on emitter and base and nothing on collector which appears to feed the 12vdc to the fan?
                                    Any suggestions?
                                    • dragonmas
                                      • May 2018
                                      • 9
                                      My $3.50 fix for non-operational fan.
                                      • dragonmas
                                        • May 2018
                                        • 9
                                        Neat it up some
                                        • EZabala
                                          • Feb 2023
                                          • Dominican Republic
                                          #140
                                          Hi, i have the same problem. I found that is you move to switch to 220V instead of 110V and connect to 110V, the system work great. I don't know how it's work, but it's working great.
                                          • mikey5791
                                            by mikey5791
                                            Hi to all forum members,
                                            12-26-2024, 04:55 AM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
