Numark NS6 Usb problem
  • falcontech
    • Oct 2013
    • 470
    • italy
    #61
    Re: Numark NS6 Usb problem
    I try to load it let's see what happens
    • falcontech
      • Oct 2013
      • 470
      • italy
      #62
      where should i load the firmware?
        • 31038
        what firmware? you extracted some?
        • falcontech
          • Oct 2013
          • 470
          • italy
          #64
          the firmware that posted Per Hansson
            • 31038
            the chips are not the same.
            for a start your unit does not have an ST32 microcontroller or a DFU mode.
            or an XMOS chip.
            final problem, that's a 20k binary and you only have 16k flash space.
            • falcontech
              • Oct 2013
              • 470
              • italy
              #66
              but look what the hell ... I try to ask if they send me an atmega with the firmware inside let's see what happens
              • falcontech
                • Oct 2013
                • 470
                • italy
                #67
                Hello here I am after receiving an answer from numark italia assistance, unfortunately I have no good news, I was denied the purchase of the atmega containing the firmware and also the sending of the firmware to be reloaded, I was offered to buy the card at the price of 190 euros, now I wonder but what the hell do they put an ISP attack on the card if they don't give you the possibility to have the firmware? now I'm at a standstill, if anyone has a solution let me know thanks
                  • 31038
                  scumbags.
                  i wonder if they know this is out in the open for potential customers to read.
                  • falcontech
                    • Oct 2013
                    • 470
                    • italy
                    #69
                    I wrote them a nice message on FB's wall but I know they will never make it public:
                    Good morning,
                    I have a problem with my ns6 (first edition) I have written several times to the Italian assistance that at the parent company, I need the firmware of this controller because due to a problem it failed to load, I was asked to change the card main for a cost of 190 euros, you call this me assistance service? do i have to spend 190 euros for a problem that i can solve at no cost? I await an answer and the firmware otherwise I will be forced to stop buying your products and as a reseller do not recommend the purchase anymore Thanks
                    • falcontech
                      • Oct 2013
                      • 470
                      • italy
                      #70
                      I finally managed to get the firmware through the Italian assistance, how should I proceed now?
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #71
                        this is the firmware
                          • 31038
                          that is not the atmel firmware, it's for the main chip.
                          the atmel firmware will be a BIN or HEX file
                          • falcontech
                            • Oct 2013
                            • 470
                            • italy
                            #73
                            and now how do you do it? what request should I make to numark, I think it will be a bit difficult to explain to him what I need, can you give me a precise indication?
                              • 31038
                              if they actually know what they are doing then ask for the firmware for the atmel usb controller and include the page from the service manual with the chip reference.
                              better yet, include the page with a big red circle added around the chip!
                              • falcontech
                                • Oct 2013
                                • 470
                                • italy
                                #75
                                this sticker was on the original chip, can it be useful to us?
                                  • 31038
                                  send them that picture, tell them it's U7 and you need the binary file to put in it.
                                  • izzzzzz6
                                    • Jul 2014
                                    • 24
                                    • France
                                    #77
                                    Why mess around with all this. Buy one or two broken units and swap parts till you have it working. By now units can be found for between £40 £150 with questionable performance. Use as parts,keep or sell the rest as spairs. You will probably turn a profit.
                                    I saw a main board, tested, for £75
                                    • falcontech
                                      • Oct 2013
                                      • 470
                                      • italy
                                      #78
                                      I also thought about this solution, putting up ads looking for a defective drive with other problems, but in Italy it seems that this controller is a ghost, and the only main I found was in Brazil and it cost 200 dollars, if you have found something cheap send me thanks
                                      • izzzzzz6
                                        • Jul 2014
                                        • 24
                                        • France
                                        #79
                                        Just a few things. Way back you seem to get sidetracked listening to this guy going on about replacing the chip. have you checked that the chip is getting the correct voltages on the pins that supply it? Perhaps you just need to restore voltage.
                                        There are a load of these in France and UK look on leboincoin.fr ebay.rf and ebay.co.uk one guy is selling a main board for £75 but if you bought a complete unit you would have more spares or parts to sell on.
                                        Also you can check facebook marketplace.
                                        Another thing that caught me out was not using a power adapter that was powerful enough, you need a strong 2A power supply.
                                        Good luck.
                                        • falcontech
                                          • Oct 2013
                                          • 470
                                          • italy
                                          #80
                                          Good luck.
                                          The original chip was burned out and it was not a power problem, now I will check what you told me, I tried to find a complete unit but I was not lucky, in the meantime thanks if I can not find what you reported maybe I will ask you to send me the link
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • foshland
                                            DELL XPS 9560 Burned zone need photo please
                                            by foshland
                                            Hi to all, I have a XPS 9560 with some faults, im working on it for fun, I have a "burned" zone I need to dremel but afterwards ill need a photo of the zone for rebuilding as far as I can, I have the schematics and the boardview but will like a photo, if some of you can get any so I see the traces will be cool.
                                            It was some kind of lucky that the zone had not too much components, so I think I can deal with it.
                                            Its under the zone where PC308 PC309 and PC337 is located, next to PU300
                                            Thanks a lot for all and "pray" for me ...
                                            04-21-2022, 07:33 PM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • TurcoLoco
                                            Questions About The Numark MixDeck Onboard DC Port
                                            by TurcoLoco
                                            Hello all,
                                            I have a Numark MixDeck from 2011. The power supply seems OK but the DC port within the deck itself seems broken or loose.
                                            The device will not power on until the DC connector is inserted and then turned a little counterclockwise then it works but if you touch the cord, poof!
                                            I am guessing the cube shaped DC port on the board is bad and needs to be replace?
                                            Does anyone know what this part is called so I can check on DigiKey or somewhere?
                                            TIA...
                                            08-05-2025, 04:00 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
