Hello
I have a problem with this board, it is the main board of the numark NS6 controller, the board has already undergone a repair, the two components highlighted in the photo have been replaced, the larger chip which is a CS5368-CQZ of the cirrus logic burned in continuation due to the breakdown of the smaller chip which is a voltage regulator (Ap1510) which instead of 5 volts supplied 12 volts and burned the CS5368-CQZ. Solved this problem I tried to connect it to the PC via USB but not by signs of life, so it is not detected by the computer, I state that the controller turns on regularly. I would be grateful if someone could help me, replacing the card costs more than 300 euros and it's not worth it. I enclose a photo of the card and the service manual of the controller. Thank you
