Teufel Concept E Magnum PE - Subwoofer loud buzzing
  • Capacitorial
    • 44
    Hello Badcaps-Forum,
    I got a Subwoofer (just the Sub) and found out that after powering it (without speakers connected) the Subwoofer is very loud and buzzes or puts out loud continuous bass sound. If I disconnect the sub from the inside (the two cables on the membrane) and connect only the speakers, everything is fine and music plays normally.
    What can be the issue here? This is the PCB of the subwoofer amplifier since the fault has to be there: https://imgur.com/a/YgbZZ6O
    One of those big caps feels more bloated than the other. Should those be completely flat, cause I can feel that they are slightly bloated at the top.
  • petehall347
    • Jan 2015
    • 4427
    Re: Teufel Concept E Magnum PE - Subwoofer loud buzzing
    no pic in link
    • Capacitorial
      • 44
      The link contains a picture now. Sorry for that. I also scraped of some of that weird "glue" (?) and uncovered some resistors under it. These were still good.
      https://imgur.com/a/x7SfT5i
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sounds like loud utility AC-frequency buzzing to me! I think it's safe to say bad caps!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Capacitorial
          • 44
          Alright. I will try to find those 6800uF 63V capacitors, replace them and come back to bring some good news (hopefully).
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Get rid of all the glue, it becomes conductive.
            And check the legs of wires and resistors covered by glue: they might be corroded and damaged.
            For example that big power resistor: one leg looks green on it!
              Originally posted by per hansson
              get rid of all the glue, it becomes conductive.
              And check the legs of wires and resistors covered by glue: They might be corroded and damaged.
              For example that big power resistor: One leg looks green on it!
              +1
              • Capacitorial
                • 44
                So guys, I am back with news. I changed the Capacitors and nothing changed. But I found out that the transistor A1941 (top right big transistor) is overheating. Changed that one too without positive result.
                If I disconnect the subwoofer cables (red and black sitting on the speaker) it doesn't overheat.
                Resistance of the subwoofer speaker was at 3.6Ohm. The cables that connect onto the subwoofer have 38.6V or something. What can be the reason.
                Also if I connect everything and measure the voltage on the sub (with the cables on it) it doesnt have the 40V.
                • Capacitorial
                  • 44
                  Update: I changed all other capacitors too, without a positive result. Now I really don't know what to look after. Is the speaker itself faulty? What else can I check? Can the other board be a problem?
                  • petehall347
                    • Jan 2015
                    • 4427
                    if you removed the glue it leaves transistors .
                    how many volts does it run on the rails .
                    • Capacitorial
                      • 44
                      The connector with three cables (yellow, black, yellow) that connects to the pcb has 31V between yellow and black and 63V between yellow and yellow.
                      I don't understand what the first sentence means.
                      • petehall347
                        • Jan 2015
                        • 4427
                        make sure the glue is removed as it can become conductive .
                        • Capacitorial
                          • 44
                          I did without a positive result. Now it looks like this:
                          https://imgur.com/a/qMt4e6Z
                          Now I literally don't know what else I can do. The other PCB is not for the Subwoofer, but for the satellites/speakers, so I guess it is ok since they work properly.
                          Another experiment I did was to connect the cables of a sat to the subwoofer "replacing the sat with the sub-speaker" and there was music coming from it quietly. So I guess the sub speaker itself is ok (with 3.7Ohm).
                          • petehall347
                            • Jan 2015
                            • 4427
                            you could test all the transistors
                            • mmartell
                              • Oct 2013
                              • 3189
                              Try flexing that board with the butt end of a pencil or similar while it's buzzing to see if you have a dodgy joint.
                              • Capacitorial
                                • 44
                                Update:
                                - I measured all resistors on the PCB and they are all good and have the right value.
                                - I tested the transistors and they are all good.
                                So basically I tested every single component on that board and replaced all capacitors.
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  can you record the sound and post it ?
                                  • Capacitorial
                                    • 44
                                    The sound is now different like in the attached audio file. You got to turn up the sound a bit. My mic couldn't catch it like it is in real life. It is a bit louder than that.
                                    At first there was loud buzzing. Then after I cleaned the glue, there was no buzzing but also no other sound. Now after all the replacements (Transistor A1941, and all caps) with further cleaning, there is a quiet whining going on. There is no audio source connected. Just the Sub by itself.
                                    • petehall347
                                      • Jan 2015
                                      • 4427
                                      check over your work . maybe a short or broken wire etc .
                                      • Capacitorial
                                        • 44
                                        Ok I will check again.
                                        I did test the speaker again by directly connecting a 9V battery to it. The speaker moved and made knocking/cracking sounds. So 3.7 Ohms and this test should be enough info to be sure that the speaker must be ok.
                                        • reessi
                                          Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
                                          by reessi
                                          The pics are off the other really long thread as they are much clearer than my phone will do.
                                          The fault:
                                          In standby there is no buzzing.
                                          After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
                                          It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
                                          If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
                                          I have checked every single cap on the psu and logic board by un-soldering...
                                          07-05-2020, 05:23 AM
                                        • rustinjust
                                          Please help, subwoofer connected to tv, read description below
                                          by rustinjust
                                          I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there a way of...
                                          10-28-2023, 07:09 AM
                                        • rustinjust
                                          Please help, where can I get a remote for my subwoofer?
                                          by rustinjust
                                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there...
                                          10-28-2023, 03:43 AM
                                        • link626
                                          Klipsch computer subwoofer speakers hissing buzzing. Does this look like bad cap?
                                          by link626
                                          Klipsch 4.1 computer speakers hissing.
                                          Looking at all the caps on the amplifier, they all seem flat, except one maybe.
                                          Not sure if this is leakage, or factory marker pen.
                                          Can you tell?
                                          The speaker system recently developed nonstop hissing noise. after 22 years.
                                          Is there a special kind of cap I have to buy?
                                          Low ESR? or general?
                                          I see these for sale.... Panasonic FC 47uF 50v low ESR radial Capacitors caps 105C New low impedance...
                                          08-02-2022, 06:38 PM
                                        • Delicieuxz
                                          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                                          by Delicieuxz
                                          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                                          Here's an audio clip of the sound coming from my speakers:
                                          https://vocaroo.com/16HaryHwTx78
                                          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                                          11-15-2023, 09:50 PM
