Repairing dbx 1066 compressor/gate/limiter
  • Kesson
    • Nov 2019
    • Switzerland
    Hi! Hope you're fine! (:
    So a friend gave me this unit which had faulty pushbuttons. Sadly I messed things a little up while doing the job.
    Here's the schematic hosted:
    https://elektrotanya.com/dbx_1066_sch.pdf/download.html
    I managed to repair a vias connecting bottom and top with a bridge. After this sound is back on channel 1.
    More saddly I managed to destroy channel 2 by an overload occured while testing (too much volume). Now channel 2 is dead and I'm left with channel 1 who seems to work fine.
    As I am novice in repairing such kind of stuff and wanting to lurn as much as possible by the way I try to understand the schematic and make a "reverse engineering the signal path from the input. That I destroyed stuff is sad but if I see it as an opportunity to learn even more I will be very happy!
    So I'm looking at that first stage and looking at my documentation I see a substractor opAmp configuration. So what I understand is while this a balanced signal that's the stage where te noise accumulated gets canceled out.
    But also, isn't there a banpass filter?
    In fact what I wish right now is beeing able to calculate theorical gain and expected output for a 1KHz 1Vp-p input. In order to understand what
    I would share lot of pictures of my scope and schematics modification with measure points and my references for the formulas but I'm not sure where I should best host my images. Any suggestions?
    Cheers
    Any help greatly appreciated!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Repairing dbx 1066 compressor/gate/limiter
    Lucky you... only thing you have to do is to compare both channels to each other. Since you overloaded it on the input, feed it some audio and follow it with an oscilloscope to the point where you loose audio.
      Originally posted by capleaker
      lucky you... Only thing you have to do is to compare both channels to each other. Since you overloaded it on the input, feed it some audio and follow it with an oscilloscope to the point where you loose audio.
      +1.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        on the service manual, page 6, U14a. Compare the input to the output. I bet there is nothing coming out. Compare channel two U14a to channel one U7a. You also can try to compare the DC output voltage of U14a to U7a. If U14a output pin (1) is just giving a solid negative voltage like -15V, its bad.
        • Kesson
          • Nov 2019
          • Switzerland
          Hey CapLeaker!
          Sure I have a channel where sound comes out but I'm not convinced that everything is where it should be, especially with the +4/-10 switch.
          For example there is no more sound if I switch to -1 on channel 2. That points me out that I have damaged more things and maybe other which are not so obvious...
          By the way, channel 2 never had died (I didnt understand how that could be possible to break in this way...) it was just the thershold of the compressor I turned accidentally all the way down during the panic in this late night
          Sorry for that! It's was the try after where I controlled again every setting is the same on both channel.
          Lucky me I work in a sound system manufacture for 2 or 3 weeks. I already managed the boss to help me with the understanding of the schematic. I told him I will take the thing with me and he seemed to be pretty ok with that!
          Because what I maybe didn't mention clearly is the fact that I would like to understand what should be going on and being able to calculate it and thus refresh my electronic background.
          Thank's for your time!
          Cheers!
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • tofik
            MOSFET equivalent K8A60DA
            by tofik
            Hello guys,
            I have a shorted MOSFET K8A60DA with the following characteristics:
            Type Designator: TK8A60DA
            Marking Code: K8A60DA
            Type of Transistor: MOSFET
            Type of Control Channel: N -Channel
            Maximum Power Dissipation (Pd): 45 W
            Maximum Drain-Source Voltage |Vds|: 600 V
            Maximum Gate-Source Voltage |Vgs|: 30 V
            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
            Maximum Drain Current |Id|: 7.5 A
            Maximum Junction Temperature (Tj): 150 °C
            Total Gate Charge (Qg): 20 nC
            Rise Time (tr): 25 nS
            Drain-Source
            07-19-2023, 05:18 AM
          • mikey5791
            Help on car amplifier only one channel works
            by mikey5791
            Hi all forum members,
            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
            08-06-2025, 10:36 PM
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
