Denon DCD-810 not spinning up
  • smallprint
    • Nov 2010
    • 86
    Hi I have recently aquired a denon dcd-810 cd player the guy I got it from dropped it and damaged the cd tray it was working beforehand I have got it home and opened it up and took a look at it and got the tray mechanism working again so it loads and unloads discs but i did notice the laser wasn't lighting up upon insertion of the tray there was no activity at all from any of the motors apart from the tray motor. I have had the tray out and have tested both the spindle motor and the worm drive independantly from the board in the player and both work fine using a 5 volt supply yet it doesn't seem to be getting any power from the board for the new laser I have just fitted or either the worm drive or the spindle. Any help getting this playeer going again would be greatly appreciated many thanks
  • R_J
    • Jun 2012
    • 9535
    Re: Denon DCD-810 not spinning up
    Have you checked any voltages to make sure they are all there? If the player was dropped I suspect it also cracked the circuit board somewhere.
    Check that you have plus and minus 5 volts, I suspect they are there because the tray is working. Check the plus and minus 10 volts as they are used for the spindle and slide motors.
    Get the service manual if you hav'nt yet
    • smallprint
      • Nov 2010
      • 86
      I think i've got it sussed down to a pair of bad transistors D1274 and D1913. The D1274 had come away from the board so I re soldered it and switched on and it spun briefly so it looks like i'm gonna be ordering a pair of those from ebay and as for the service manual the only one I can find is in german and my german is a bit rusty to be fair
      • R_J
        • Jun 2012
        • 9535
        Those transistors seem to be for the focus drive, did you put a disc in the tray? It needs to see the disc before it will spin up. The transistors are likely ok and had poor solder connections, thats why they came loose, it would be a good idea to inspect the boards for other poor solder connections
        • ChaosLegionnaire
          optical drive tray loading problem
          by ChaosLegionnaire
          i started using a couple of my optical drives again to perform some testing and backup but to my disappointment, they have tray loading problems. both drives wont eject the tray and when i load the tray back, it auto ejects the tray again. it seems that the laser sled assembly in the drives wont drop down fully to the correct position to release the tray and the laser sled assembly wont extend back up to the proper position to lock and load the tray so it auto ejects the tray again.
          i tried lubricating the gears in the tray loading mechanism and the tray sled rails but it didnt...
          02-26-2019, 02:07 PM
        • bogosort
          Sony DVD player stuck tray (DVP-SR310P)
          by bogosort
          I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
          Anyone knows why?
          Thank you....
          05-11-2024, 04:29 PM
        • avneeshshrotria
          Mac Pro 5,1 2010 CPU Tray Damage
          by avneeshshrotria
          Hey guys ,
          Need assistance with a Mac Pro 2010 5,1 single cpu , cpu tray .
          Ive bought the computer used , it’s really been through a hard time.
          Someone has managed to pull components off the bottom side of the cpu tray!!!
          I need assistance in identifying the components and the values of
          1. CG410(missing)
          2. Q2400(TWN. Marking on it) , Q2450(TWN. Marking on it) (this marking does not correspond to any specific IC as far as I can tell , need help to identify!l )
          3. Q2120 (missing) ,
          4. R2444(missing)
          Im attaching a couple...
          04-11-2024, 02:20 AM
        • Green Probe
          Recapping a Denon AVR X6400h SMPS
          by Green Probe
          (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
          Disclaimer: I'm an amateur hobbyist and will get things wrong.
          Always use caution when working around mains power and high voltage capacitors!
          Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
          SYMPTOMS:
          -No display...
          07-18-2025, 03:36 PM
        • trepachka
          Yoga 9 14ITL only left fan spinning
          by trepachka
          Hi, I have this laptop that had multiple issues: a bad USB-C chip, a bad power regulator, a bad ALC3306 chip. The latter stumped me because I never had an audio chip cause any issues. Yet, it was heating up to 80c.
          After all of these got replaced, the laptop is working again but only the left fan is spinning upon heat buildup. The right one is not spinning ever. I had a spare heatsink/fan assembly which I installed but the problem is not going away. So, the fan itself is ok. I checked pins on the fan connector and it does get 5v and 3.3v.
          I don't think it's the thermal...
          11-07-2023, 03:09 AM
