Sony HT-CT290 subwoofer not pairing...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. This was meant to be a rant, so it should've probably gone in the off-topic section, but I thought someone might come up with an idea nonetheless.
    Sony has managed to, ONCE AGAIN, earn my loathing and my deepest sincerest wishes of extreme hate: this Sony soundbar POS came in under warranty and I had to take a look at it. The subwoofer was totally dead, so I took the back off and immediately noticed a popped IC on the amp/logic board. Since it was under warranty, I had the option to either ask for a replacement of the whole board or attempt to fix this one. I naturally chose the former, not only because this place is SEVERELY lacking in parts, but because I didn't want to risk something else popping or having different issues.
    Long story short: new board arrived, subwoofer powers on but no longer pairs with the rest of the soundbar....what gives ?! The manual did warn me that replacing the main board will cause this, obviously, because the pairing info is stored on the main board, not in the BT module, but I thought for sure I'd be able to pair them again...I followed those instructions countless times, tried all sorts of procedures, but no, it's useless: it simply doesn't want to connect....what a POS...I swear, if you ever see me buying a Sony, whoever you are, you have the right to slap me in the face ! :| So now I'm basically stuck with this thing, with the thumb up my ass not knowing what to do. The board is also probably going to be deducted from my wages and possibly a whole new system if it turns out there really IS no cure and has to be replaced....great...it's like pouring salt on the open wound....
    I press LINK on the back of the sub, the LED turns yellow and flashes, then I press a certain button on the remote to put the bar in pairing mode and after a while the yellow LED blinks slower and eventually turns red...like a giant middle finger...there IS some communication going on, between if I don't start the pairing sequence on the bar or leave it off, the LED on the subwoofer blinks forever, whereas if I do the pairing steps, it does attempt to link up but fails for some reason and goes to standby...
    Trouble is I already reset the bar several times, so even if I swap out the busted IC (a buck regulator) for the good one from the new board, it still doesn't guarantee it will link back again to the old board...the bar itself may have other issues and the asshole didn't mention it...
    Might be some firmware issue, although I upgraded the bar to the latest one - no change...so disappointed and angry at the though that I might have to pay to get this thing replaced, or worse: the whole SHOP might have to pay for it and I'll get cold stares for 1-2 months (our Big Boss usually applies collective punishments in situations like these because, granted, there was no way I could predict it wouldn't work, but you STILL have to get your money back somehow, so the best thing to do is to just punish everyone.....sounds fair >_>)
    Wattevah...
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8173
    Re: Sony HT-CT290 subwoofer not pairing...
    Since you have basically nothing to loose, I would start to swap stuff from one board to the other.
    So why did Sony send you a new board or even why is this board available, if no one can make it work with the rest of the soundbar, cording to the warning? I am a bit puzzled by that. There must be a way to pair that back.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      The BT/WiFi card was also dead - THIS was the problem. I was EXTREMELY lucky that a colleague in charge of warranties who usually handles this stuff and was away on a 1 month holiday (which is why all warranties were assigned to me instead), had a similar dead model which uses the same card and I swapped that over FIRST, before digging up the boards - it solved the issue and it connected on the first try...it probably got killed when that 3.3v regulator IC shorted, though it appeared shorted to GND. Must've first lost its regulation, ramped its output to the max and THEN died...
      Wattevah...
        master hoarder
        • May 2008
        • 12175
        It's not just Sony. ALL of these "trendy" soundbars are over-engineered, under-built garbage like that. Not only would I refuse to work on one, but I probably also wouldn't pick one up even if it's free. And why should I - they use shitty speakers, have shitty problems... and just sound like shit in general.
        That said, since your shop uses "punitive methods" when you don't fix something right... then simply don't attempt to fix it. Just call the customer right away and say, Sorry, this thing is FUBAR (okay, maybe don't use those same exact words ... but you get the point.) As curious as I am and love fixing things (even ones that often aren't worthwhile)... if I am going to be looked down on for making a legit repair attempt, then I'd rather just not make any attempt at all and use my time for something else.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          I'm afraid you can't "refuse" to repair something when it's still under warranty - you'd probably lose your job for that, but I CAN refuse to repair things which are no longer under warranty. This I often do if, like you said, they're not worth my time...even though I DO like tinkering with useless stuff just to hone my skills and learn.
          I feel my skills are suffering and declining here just because there's plenty of junk I'd like to mess with but can't because of my much-older "colleague" who I've mentioned countless times so far who wouldn't let me do anything. Recently I started pulling field duties just to get away and actually do something...horrible jobs, out in the cold a lot of times, given that I've been a "shop-boy" all these years, but still better than sitting in a chair and dozing off day in and day out because I've got nothing to do... :| There's not a damn thing you can do about it other than keep calm and carry on . They also say "live every day like it's the last...(to which I'd add)...day before the old geezer retires" THAT will be a fine day, lads
          Wattevah...
          • madan1
            • Nov 2016
            • 682
            As an authorized partner sony service, don't you have the required know-how and/or tools and procedures to pair the new board?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              We did - pairing doesn't involve anything other than following the instructions in the manual, which we did but didn't work, leading us to finally swap out the BT/WiFi card. Unfortunately we don't keep a stock of Sony parts to immediately swap out when in doubt - this time we got lucky to have a similar unit lying around, otherwise I would've had to pay for the replacement...not terribly expensive, but why pay at all...
              Wattevah...
                master hoarder
                • May 2008
                • 12175
                That's even more reason then why your boss shouldn't be charging out of *your* pocket if something doesn't work. I mean, that's just shitty policy. What if this was a $10,000 device and its part cost $2000. If it's defective, surely no employee should have to pay that out of pocket.
                Of course, I don't know your place's circumstances, so I can't judge too much. But still, this sounds worse than selling rotten apples on the local flea market.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  Yeah, I SUPPOSE that's how it should be, but when something doesn't go as planned it's considered that it's you, the technician, who didn't assess the problem correctly and, by expansion, didn't do your job right - no room for f-ups here.
                  That's Sony's policy at least, and I think I mentioned this before: you only get one shot, so once they've sent you a replacement for a component free of charge under warranty, if something else happens to be faulty (or worse, the part you requested wasn't the problem to begin with), you're paying for whatever needs to be replaced next...not sure if this is fair or not TBH. When I say "you're paying", I mean the service center does - how they recover their loss is up to them. In this case, if it's not terribly expensive, I believe they let it slide, but I remember my colleague down in the warranty department had to pay through the nose for a POS TV which just turned off by itself at random intervals and he just couldn't pinpoint the issue. He kept ordering parts - main board, PSU, hell, even a WiFi module - NONE of them solved the issue because the problem was in the panel (bad LED) and the cost of all those parts was deducted from his wages, because as we've seen Sony only sends the first part he thought was bad for free - NOT cool at all :| I don't want to comment on whether or not this can be considered as him not having the proper know-how to correctly assess the defect and set a proper diagnostic from the start - you be the judge of that...
                  On the contrary, take my case for instance: there was no way I could predict the WiFi card would also be dead, so I do not agree with me getting charged extra for it. The proper way to do it would be to have a stock of the most common parts and immediately swap them around before ordering the new one. The capital is home to the central Sony offices where I believe this might be possible, since that's where all the parts come from, but here we just have to make due with what we have...that's just how it works...this is why the guys save every piece of equipment and every board that gets left behind, you never know when you might need something off of them - long live my colleague for providing the WiFi card, otherwise I would've probably got scolded, which is worse than getting fired at this place Being told off in front of everyone for not being a good technician is the worst blow you can deliver to one's ego Whew....ok, enough rambling, sorry guys
                  Wattevah...
                    master hoarder
                    • May 2008
                    • 12175
                    With today's electronics, almost nothing ever goes as planned. So I think your boss really needs to drop that policy. The previous repair place where I used to work, we were Dell, HP, and Apple -certified repair center, which meant any warranty parts we got were directly from Dell, HP, and Apple themselves. Nevertheless, I can't tell you how many times even companies as big as HP and Apple have sent us the wrong part or a non-working one back. If our repair place had adopted a policy like that, we wouldn't have survived very long as a business.
                    Not only is it not fair, it is complete nonsense! You absolutely can have multiple parts fail in a system. If these were the terms that Sony gave me (as an owner of a repair shop), I wouldn't even think twice about dropping out from doing warranties for them. Either Sony sends me all the parts I need to complete the warranties, or I can just tell the customer to call them and let Sony explain why their device cannot be repaired.
                    So similar to my old repair place... except any losses from warranty repair weren't taken out of my pay check ever. Instead, they were passed onto the customers as "labor costs" and whatnot and sometimes even spread out over other services - in other words, rob Peter to pay Paul.
                    Yes, I've had to deal with a returned PC like that at my previous job. Needed motherboard, CPU, PSU, and RAM to get one machine going. And it wasn't just one of those that was bad - I tested each component in various other PCs, and all of those components were bad. It was a Dell Inspiron PC or something along those lines - one of those late 2016 models with cheap tin can cases, small proprietary PSUs, laptop DVD drive, and a joke of a motherboard. Really Dell should have just sent me a brand new PC - it would have been cheaper for them, less work for me, and the customer wait less for the repair. Of course, they don't do that. They implement these shitty warranty policies that basically test the customers' nerves (and ours), so that hopefully the customer will give up and buy a new PC... and keep the economic wheel "turning".
                    That's one of the reasons I have pretty much stopped working on new PCs now. If it's something old, I might try to fix it (and it usually is fixable).
                    It can happen to anyone - even the most experienced of techs.
                    Big companies will never do that anymore. They like to run a "tight ship" with the warranties and hopefully steer their customers into buying a new unit of whatever rather than getting the old one fixed. So that's why you will never ever have warranty parts on hand anymore.
                    As much as I do that myself too for my personal projects... in a big repair shop, this can quickly become problematic. In particular, once you get too many things, you won't even know what you have, and that's as bad as not having the things either.
                    Kudos to your colleague who actually not only saved the part but also knew where it was and what it could be used for. Staying organized is the only way to make use of junk parts. But that in itself can take a good amount of energy and effort too.
                    I would like to see your boss try that with me. I'll probably laugh my ass off right in front of him/her and not give even half a crap.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      Let's keep ranting to vent some anger
                      Organized ? Yeah right >_> The place is a dump. Sure, there's no way you can compare it to my former apartment-sized shop where there was only me and 2-3 other people who were (relatively) tidy. That doesn't mean that it would be impossible to achieve the same degree of order and perfection with 20+ people AND a big space - that's what pisses me off, the fact that it would be possible ! Stuff everywhere with no rhyme or reason, no thought-process whatsoever going on, nobody knows where something is...nobody cares, much less so the boss himself (makes sense I guess - money is a boss' only concern. People are expendable and disposable). The "laiser-faire" type boss, I'm sure you've heard of that: if your employees are a bunch of lazy incompetents who do nothing but the bare minimum and the boss doesn't enforce a strong policy regarding tidiness and overall organization, nobody's going to lift a finger to do it out of their own free-will and the joint turns into the sh!t-hole which it presently is. Like I said, it COULD be done, but it's clearly not WANTED. Instead of 10 coffee and smokes breaks each day, how about you pitch in and actually clean this joint up a bit, eh ?! >_> So much wasted potential ! Sad really... What I would've given to have this amount of space on hand at my former shop where I was...pretty close to an administrator myself really...*sigh*
                      Another thing that really grinds my sh!t is over-qualified a-holes: I'd love to show you some pics of some of the network "engineers'" handy work around here, but I don't want to risk anyone picking up on it...I provide a bit too much info on my profile and am rather "detectable"
                      Can't begin do describe how angry this makes me. There's nothing wrong with having all sorts of papers and qualifications as long as it doesn't turn you into a complete douche ! These fellas sit at their cozy desks all day, all lined up in a row with their laptops and computers pecking away all day....heaven forbid you ask them for help because something broke down in their precious network - you're given a cold shoulder and left hanging until they decide you're worth their time. Also their installs look like this *insert mental picture here*: a mess of wires and gear all botched together in a disarray of madness and thrown in a corner somewhere covered with dust and spider webs. Adding insult to injury, we claim we provide "high quality networking services by trained and authorized personnel yadayadayada" Cisco certificates and other jazz....bitch u serious ?! That's all fine and dandy, but how can you have the nerve to promote that when your building is wired like THAT and barely working ?! >_> There should be a picture of one of these "racks" on our homepage, right next to those networking offers >_> God I'd so love a good troll like that ! If I ever quit this place, I swear I'm doing just that on my Facebook profile: publish one of those add for this place but with those pics attached - SAVAGE !
                      Wattevah...
                      • huj3r
                        Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                        by huj3r
                        Hi there!
                        I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                        Photo of the situation after the black shadow dissipates:
                        After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                        I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                        > This indicates HFR Communication error. [ HFR Communication...
                        08-15-2023, 10:55 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • cheeky2
                        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                        by cheeky2
                        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                        01-08-2024, 05:56 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
