Pioneer VSX-D309 No audio with speakers, ok with headphones
  • mykolas
    • Mar 2014
    • 18
    • usa
    I just got the above unit that works with headphones but not with the speakers alone connected. Speakers check fine. Opened unit up and checked all fuses(glass and micro). Fusible resisters in the preamp and amp section are ok too. When power is pressed, the power relay is heard then about one second later the speakers relay engages. No sound.
    Could the PAC012A/013A IC'S have opened up?
    Anyone encounter this?
    Mykolas
  • R_J
    • Jun 2012
    • 9594
    Re: Pioneer VSX-D309 No audio with speakers, ok with headphones
    Usually if the output ic's are bad the protection will cut in and the speaker relay will not engage, Check that the amp input ass'y board is seated properly
    Then check the solder connections on the output ic's
    Check if there is output from the suround speakers as well
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8331
      maybe the outputs aren't turned on? something stuck inside the headphone jack?
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
        Acoustic Audio GX-400 speakers
        by momaka
        Part 1 - Acoustic Audio GX-400 build "quality"
        Not going to lie – this will be another silly audio post/thread. If you thought the cheap Panasonic Thrusters speakers I posted about last time were bad enough, then you are about to explore some new depths in lo-fi audio here. Ladies and gentlemen, I present you the Acoustic Audio GX-400 speakers... or speaker (only pictured one for better details )
        Before I continue any further, perhaps you might be asking why I even bother to post about such crap audio gear (let alone keep it). The answer...
        03-07-2019, 09:04 PM
      • abajor
        A2141 No audio on speakers, yes audio on headphone jacks.
        by abajor
        I just can't escape Apples most CURSED laptop the dreaded A2141.
        Can't find any info on this speaker problem. I've been digging through the schematics and found there's a separate chip U6300 to drive the headphone jack.
        It appears all of the audio signal is transmitted using i2S. It's pretty wild that the internal speakers have 3 amplifiers each. I'm assuming whatever provides the clock or routes the signal to the speaker amps has an issue?
        U3900 is as far as I've gotten in my exploration.
        Anybody know this issue? Is it fixable? U3900 looks like something...
        12-30-2024, 07:42 PM
      • lfhlaw
        Hisense 43H4030f3 Audio flipping between Earphone and TV speakers otherwise great shape
        by lfhlaw
        I was able to get a Hisense 43H4030f3 43" TV for free, however, after it has been on for about 40 minutes or so, the audio will start to flip between Earphone and TV speaker mode most likely indicating a failure of a switch, or the audio sensing chip.
        I'm just curious at this point, whether it's better to just replace the main board -- at least that's my inclination.
        Looking at the main board, I do not see any blown capacitors.
        I uploaded a pic of the main board, and a short 22 second clip which shows the issue....
        09-13-2025, 07:30 PM
      • Delicieuxz
        I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
        by Delicieuxz
        I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
        Here's an audio clip of the sound coming from my speakers:
        https://vocaroo.com/16HaryHwTx78
        I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
        11-15-2023, 09:50 PM
