A2141 No audio on speakers, yes audio on headphone jacks.
  • abajor
    • 178
    I just can't escape Apples most CURSED laptop the dreaded A2141.
    Can't find any info on this speaker problem. I've been digging through the schematics and found there's a separate chip U6300 to drive the headphone jack.
    It appears all of the audio signal is transmitted using i2S. It's pretty wild that the internal speakers have 3 amplifiers each. I'm assuming whatever provides the clock or routes the signal to the speaker amps has an issue?
    U3900 is as far as I've gotten in my exploration.
    Anybody know this issue? Is it fixable? U3900 looks like something I do not want to mess with.
    Acoustic Audio GX-400 speakers
    by momaka
    Part 1 - Acoustic Audio GX-400 build "quality"
    Not going to lie – this will be another silly audio post/thread. If you thought the cheap Panasonic Thrusters speakers I posted about last time were bad enough, then you are about to explore some new depths in lo-fi audio here. Ladies and gentlemen, I present you the Acoustic Audio GX-400 speakers... or speaker (only pictured one for better details )
    Before I continue any further, perhaps you might be asking why I even bother to post about such crap audio gear (let alone keep it). The answer...
    03-07-2019, 09:04 PM
  • lfhlaw
    Hisense 43H4030f3 Audio flipping between Earphone and TV speakers otherwise great shape
    by lfhlaw
    I was able to get a Hisense 43H4030f3 43" TV for free, however, after it has been on for about 40 minutes or so, the audio will start to flip between Earphone and TV speaker mode most likely indicating a failure of a switch, or the audio sensing chip.
    I'm just curious at this point, whether it's better to just replace the main board -- at least that's my inclination.
    Looking at the main board, I do not see any blown capacitors.
    I uploaded a pic of the main board, and a short 22 second clip which shows the issue....
    09-13-2025, 07:30 PM
  • kurtspirit
    A2141 Jack audio issue
    by kurtspirit
    Good morning,
    I have a problem with a Macbook A2141 with the audio jack port. Sound only comes out from one side (left). The right one just emits a kind of crackling sound.
    I changed the jack ports twice to be sure that it was not caused by a defective part, but the result was the same.
    I have the impression that it could be an audio filter or component but I am unable to locate the affected part on the motherboard.
    Have you ever encountered a similar problem and can you help me find the filters, if they exist, on the map please?
    Thanks in advance...
    07-25-2024, 04:11 AM
  • Delicieuxz
    I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
    by Delicieuxz
    I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
    Here's an audio clip of the sound coming from my speakers:
    https://vocaroo.com/16HaryHwTx78
    I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
    11-15-2023, 09:50 PM
  • willis6732
    LTO PS 4LA Powerred Speakers - Tweeter Audio Low
    by willis6732
    Hello, I have two of these speakers with the same Prioblem. The tweeter volume is very low. I believe it happened after running them too loud.
    There is a lightbulb on the tweeter output i tried shorting and no change.
    The tweeters measure 6 ohms and it seems to play loud if i plug them into an alternate amplifier
    There are a couple resistors and diode getting really hot in the mute circuit...
    At the bottom left of image. R17 gets the hottest. Over 70 deg C
    Z1 and R7 next to that get hot as well. Zener tests ok
    I measured the...
    11-02-2023, 06:14 PM
