sony STR-AV310
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    sony STR-AV310
    This was my grandpa's who passed away about 4 years ago, and he bought this about 5 years ago. Its a really nice receiver, I have it hooked up to two Polk audio 5JR 60469 speakers. It sounds really nice, extremely loud, no need to take it past 1/2 volume even though its only 90w (45 per channel), and those Polk monitors hardly distort. It has a remote with volume control and a volume knob, which doesn't make sense except for that when you turn up the volume on the remote it moves the knob. I also have a JBL 200w sub, but that's fed directly from my computer and gets its power from the wall.
    The only problem I have with it is that sometimes there will be a buzzing from the speakers. I ruled out my computer, as it still does it when you unplug it, and the speakers are fine hooked up to anything else. I don't think it is the caps, as the primaries are Nichicon, and all the other caps are rubycons, I think it is some connection issue, as it sometimes goes away if you wiggle the input connections from the computer, and will always go away if you smack it lightly.
    Any Ideas?
  • Logistics
    • Apr 2007
    • 721
    Re: sony STR-AV310
    cold/cracked solder joint? Replug some of those pin-connectors, too.
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Re: sony STR-AV310
      I isolated the problem to a certain part.
      Its labeled as the regulator on the PCB.
      It has the markings as follows:
      NEC
      D1585
      1 93
      It has a small heatsink attached to it, and if you poke it with a screwdriver lightly, the buzzing starts. If you poke it some more, the sound completely goes away, and it starts to get very hot until you power down and re-power on the unit.
      • PlainBill
        • Feb 2009
        • 7034
        Re: sony STR-AV310
        NEC
        D1585
        1 93
        Maybe something like this?
        Seriously, if resoldering it doesn't fix it, it's time to break out the scope and find out what is happening.
        PlainBill
        • shadow99
          • May 2007
          • 24
          Re: sony STR-AV310
          You should start with checking the solder around that xsistor 1st. Be sure it's screwed tightly to it's heatsink. It may need to be replaced if all else fails.
          You mentioned the speakers hardly distort. 45W is not alot of power and high volume levels will send it into clipping (distortion). Clipping is when a sine wave gets cut off and is square which is DC in that portion of the waveform. Thats how most speakers get cooked, by being fed distortion or clipping from an underpowered or overdriven amp. That's why you are less likely to blow speakers with a higher powered amp since it is less likely to be driven into clipping. All within reason of course.
          Once the amp is driven into clipping, it heats up more, thermal runaway can take place on your outputs, clipping becomes worse, DC levels higher and before you know it the voice coils on your speakers are cooked and maybe your amp is fried.
          Bottom line....dont turn it up so loud that it distorts. Unless you dont like your equipment. If you want cleaner, louder sound, buy a larger wattage amp. Your speakers will appreciate it.
          • PM650
            • Dec 2008
            • 37
            Re: sony STR-AV310
            That 2SD1585 is used as a +16V regulator from the main B+, for running analog ICs and other misc. circuitry.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Re: sony STR-AV310
              Well, I took out D1585, and when checking it with a DMM set on ohms, it does the following
              left leg (positive lead of dmm)-center leg (negative) conducts about 17.85 Mohms and slowly drops down to about 17.10.
              Right leg (positive lead of dmm)-center leg (negative) nothing
              Nothing if I reverse the leads.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Re: sony STR-AV310
                according to NEC's datasheet for it, it is a 60v, 3A (5A pulse) NPN switching trasistor. Could I replace it with thise 400V, 5A (8A pulse) NPN switcher from a deer power supply I scrapped?
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  Re: sony STR-AV310
                  Ok, so it worked.
                  Actually turned out that deer kind of overbuilt that power supply. It was a Sanyo 12A (20A pulse) part. Works fine now. Now extreme heat built up and no cutting out sound.
                  • weirdlookinguy
                    • Sep 2007
                    • 1638
                    Re: sony STR-AV310
                    Very nice.
                    I doubt that receiver is only 5 years old though. It looks early 90's. Exact same style as my old Sony AVR-900 (1989).
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Re: sony STR-AV310
                      Originally posted by weirdlookinguy
                      Very nice.
                      Well, bought it 5 years ago at a garage sale. I would imagine it would be from about 1990 or so.
                      • Robertt1971
                        mr fix it
                        Re: sony STR-AV310
                        Hello 370ForLife,
                        I have exactly the same receiver as you (if you still use it), and also the same buzzing problem, for years i have been wiggling the connectors in the back to get rid of it for time to time, with mixed success. However this is a european version, bought originally in Holland.
                        I am very interested to know what type exactly you used for replacing the 2SD1585 (with the sanyo one), so i can cure this problem for good. Also quite recently the tuner stopped getting any signal and i suspect the Front End or the IF amplifier. Most likely a bad capacitor,transistor or resistor. I do have an osciloscope but it stops at 20 MHZ, so i do not know if his will be much good, furthermore i have the service manual of the STR-AV310, but no idea where to start trouble shooting the tuner, maybe you or someone else can put me in the right direction?
                        Kind regards from Cyprus, europe.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Re: sony STR-AV310
                          I don't have this unit anymore, It began to buzz again after about 6 months of replacing that transistor. I can't remember the part number for the sanyo transistor I used, but it is very similar to a D13007/D13009. You can find them in just about any cheap computer power supply as the primary switching transistors. I got fed up with it and sent it in to goodwill. I got a 70's kenwood now that I use to crush cars on the weekend.
                          • RomoRock3r
                            • May 2011
                            Re: sony STR-AV310
                            Hello Everyone, I also have this receiver and it had the buzzing problem too. I guess it was a manufacturer's defect. However I have an Issue, I think I fried mine . I would plug in my Sony Turntable to the PHONO jacks along with the ground wire to the ground screw and it would play well. Sometimes the buzzing would gradually get louder until it got so loud that the protection circuit goes on and an orange "P" would light up on the LCD. After I unplug the turntable, it goes back to normal. The last time I plugged it in, the buzzing got louder again until I heard a pop from the speakers. The receiver froze and it would not respond to the power button. Both the DBFB and Mute light was on and the LCD which said PHONO showed only parts of the letters lit. The "P" symbol didn't light. After a few seconds I saw a small amount of "Magic Smoke" coming from the receiver top. I quickly unplugged it after. I opened the top cover and looked for "fried" components. I didn't find any capacitors or resistors burnt or other burn marks on the PCB. The fuses near the transformer weren't blown. However I found the leads on what appears to be a Table Rectifier Diode burnt/charred. What I realized after is that the RCA plugs on the turntable seem to be frayed as when I plugged them into my computer, I also heard buzzing and crackling which was the same as I heard on the receiver before it broke. Is this receiver now completely broken? If I replace that table rectifier diode will it work again? I have found similar table rectifier diodes online however I am not sure what the original voltage and Amps were on the original piece.
                            Here is where the broken part is:
                            This is how the replacement part should look like:
                            Do I need to have the replacement diode have the same rating of Amps and Volts as the original?
                            • lti
                              • May 2011
                              • 2557
                              Re: sony STR-AV310
                              I don't think that the bridge rectifier is bad. You should start a new thread for your problem. This thread is about the bad transistor.
                              • 63Strat
                                • Aug 2013
                                Re: sony STR-AV310
                                I just inherited one of these myself from a dear friend who moved out of the country to work a goldmine! For real not a tale! Also have a STR-AV970X i got from my brother years ago that i don't have the heart to toss. So I'm learning a bit here.. It seems Sony really dropped the ball on these units back then.. Sort of like the AMC years for Harley Davidson.. My STR-AV970X used to cycle on/off and then slowly turn its volume knob all the way up to ten slowly as if a ghost was doing it.. Stopped using it of course and switched my stereo system to a vintage Onkyo Integra system i got from one of my students in a trade.. My AV310 has this same exact problem.. Hmmm I'll steer clear of these Sony's from now on but still love the company and use tons of their gear...
                                • Longbow
                                  • Jun 2011
                                  • 623
                                  Re: sony STR-AV310
                                  It is unlikely that a number of people would report a regulator transistor that has become intermittent and sensitive to pressure from a screwdriver. It is much more likely that the small bridge rectifier is the problem in all of the units. These small bridges are a common failure item.
                                  The symptom is buzzing. That symptom would be related to AC ripple on the input to the (+) regulator. A bad regulator usually opens up and does not cause ripple to be present at the output. I believe the OP was actually stressing the pcb and not just the regulator transistor. One or more of the diodes in the bridge is intermittent. I'm going to predict that the buzzing returns at some point unless the bridge is replaced.
                                  Is it plugged in?
                                  • Theripper973
                                    • Sep 2013
                                    • 13
                                    • Usa
                                    Re: sony STR-AV310
                                    I have one of these amps too. Sony used to make sure better things then they do now it seems like.
                                    • cnlmustard
                                      • Jan 2014
                                      Re: sony STR-AV310
                                      What seems to be the fix on these? My first unit was a AV1070. It had the "ghost" turning it on and cranking up the volume. A local repair shop did fix that, they said there was a "factory bullitin" on some loose grounds. It eventually did the crash and fail on protect mode a few years later. So I got a used AV970 which worked fine for years, but now it's started doing the "ghost thing". It also sometimes fails to power off the switched 110v outlet.
                                        Re: sony STR-AV310
                                        Try tightened up the all the screws for the boards mounting, since the ground to the chassis is made through the board mounting screws where they put the ground pads on the board. I used to solder the wire directly from the ground pads to the chassis so I do not have to worry about the poor connection due to corrosion or oxidation.
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • karthur
                                          Vizio D65x-G4 Volume changes on its own
                                          by karthur
                                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                          06-05-2025, 08:13 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • Ruptor
                                          Sony MHC 6600 volume clicking
                                          by Ruptor
                                          Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                          05-21-2023, 05:32 AM
