Bose soundtouch 30 woofer works tweeters do not
  • spdy
    • May 2018
    • 26
    • india
    I have a Bose Soundtouch 30 series III model that is not producing any sound
    but everything else appears to work.
    When I disconnect the tweeters (twiddlers as called by Bose) the sound starts coming from the woofer.
    The woofer and tweeters are powered by two different ic's but using the same 24 volt supply which goes to zero when the tweeters are connected but remains at 24, with the tweeter disconnected.
    The ic for the tweeters is TPA3100D2. I wonder if I should change this ic or is there something on its circuit that I can check.
    With best wishes.
    spdy
    Re: Bose soundtouch 30 woofer works tweeters do not
    https://cdn.badcaps-static.com/pdfs/...fc56812a68.pdf
    Leave the Tweeter disconnected and then check the Voltage between GND and each pin of the Tweeter connector on the board to see if it has Voltage on it.
    BTW, uploading good clear pictures will also help.
    • petehall347
      • Jan 2015
      • 4426
      check tweeters for shorting
      • spdy
        • May 2018
        • 26
        • india
        Thanks budm and petehall347, the tweeters are functioning when I did a sound test from another source. Also I added another speaker, one only on the each of the output connections and immediately the sound (from the woofer) stopped coming and the voltage in the power supply went to zero.
        I have a feeling I have to replace the tweeter ic TPA3100D2. I will try to also do the voltage checks as suggested.
        With best wishes.
        spdy
          With best wishes.
          spdy
          Are you saying you connect ADD another speaker in parallel with existing speaker? Some amplifier may not like heavy load than what it is designed for so which can damaged the amplifier by over loading its output.
          • spdy
            • May 2018
            • 26
            • india
            No, I added the speaker in place of the tweeters, not parallel to them. If I do not connect the tweeters, but the ic remains connected and only connect the woofer, it produces sound, tested for over 45 minutes.
            If I connect the tweeter it works for a few seconds before the smps goes from 23.8 volts to zero.
            • spdy
              • May 2018
              • 26
              • india
              budm, I forgot to mention that the voltage is 9.3 on alternate pins (zero on the other pin) with the tweeters disconnected and woofer(which is connected to a different ic) connected and sound coming.
              • spdy
                • May 2018
                • 26
                • india
                I just discovered that that the schottky double diode UH840 in the secondary section is showing over 120 volts, while the output capacitor is showing 23.9 volts and the unit has been working for almost one hour on the woofer only, with the tweeters disconnected.
                The UH840 output shows continuity with the positive of the output capacitor. I checked UH840 after disconnecting the Bose unit and it was not hot to touch.
                Isn't this voltage too high and why is it not burning up the capacitor, which shows normal voltage?
                Also is the tweeter ic TPA31002d consuming too much current which perhaps makes the
                smps to shut down or is there some problem in the current protection section?
                  master hoarder
                  • May 2008
                  • 12175
                  Sound like the TPA31002d IC may indeed be bad. But before jumping to that conclusion, it is worth noting that the speakers are BTL-connected to the IC outputs. Thus, 9.3V to ground doesn't necessarily indicate a complete short-circuit on the output of the IC. But 9.3V isn't quite right either. Ideally, that voltage should be at half of the Vcc input voltage (i.e. half of 23.9V, or about 12V).
                  Before replacing the IC, first check the input differential caps connected to pins RINN, RINP, LINN, LINP. If they are ceramic caps, make sure they are not short-circuited or leaky (if resistance on these caps shows below 100 Ohms, definitely remove them from the circuit and check their resistance again). Likewise, if the caps are cheap electrolytic ones, that could be the problem too.
                  On that note, also check any other surround ceramic caps around the IC for short-circuit / low resistance (with the power off, of course). And with electrolytic caps, note what brand they are.
                  If that's measurement is of the unrectified, unfiltered voltage going to that diode, I would say your meter is just getting tricked from the high-frequency square wave output of the PSU. Either that, or perhaps you're not using the correct grounding point.
                  But since the voltage on the capacitor is what it should be, I don't think there would be a problem, especially since the woofer amplifier seems to be working okay.
                  • spdy
                    • May 2018
                    • 26
                    • india
                    Thanks, so far I have not been able to trace out the capacitors to pins RINN, RINP, LINN, LINP. I do see two sets of bank of four resistors of about 103 ohms each for both the TPA31002d ic and the woofer ic. These appear to go to the input output circuitboard.
                    The input to the resistors for the TPA31002d IC shows 1.8 volts for three inputs and 3.2volts on the fourth.
                    The woofer bank of resistors shows about 2.3 volts on each of the four.
                    • spdy
                      • May 2018
                      • 26
                      • india
                      I have not been able to get a circuit diagram for this, but found a service manual, which can be downloaded here
                      and would be grateful, if anybody can locate the schematic.
                        OUTPUT pins of the BTL should show same DC reading otherwise you will have large offset Voltage of 9.3V as you report that other pin is SHOWN 0V.
                        All you have to do is to check the DC V of the woofer speaker pins that I already suggested for you to do so.
                        • spdy
                          • May 2018
                          • 26
                          • india
                          Thanks the woofer shows 11.9 volts each on both pins, to the ground
                            That is correct so the main result is the there will be 0 Volt offset Voltage on the speaker coil which is how it should be.
                            • spdy
                              • May 2018
                              • 26
                              • india
                              I still cannot understand why the tweeter voltage is about 9.3 on one pin of each and zero on other in both speakers (tweeter disconnected) unlike the woofer which shows about 11.9 on both pins (woofer disconnected). The pins with zero show about 520 ohms resistance to ground.
                              Also the voltage to the resistors to the tweeter ic input pins show
                                Just replace the IC.
                                • R_J
                                  • Jun 2012
                                  • 9547
                                  On a regular amp with + & - supplies you would normaly measure zero volts at the speaker.
                                  On this ic it uses a single +24 volt supply so at the speaker measured to ground would be half the +24 volt supply (+12 volts measured to ground)
                                  Note one side of the speaker does not connect to ground like a normal split supply amp.
                                  From LOUTN to LOUTP you should measure zero volts but measure each to ground will be +12. (woofer working side)
                                  On the tweeter side you measure +9 and 0 which suggests the internal fets are likely bad on that side or the gate drivers are bad, either way the ic is bad.
                                  If you measure the voltage across the woofer LOUTP & LOUTN it will be 0 volts, measure the voltage across where the tweeter connects and it will show 9 volts, so connecting a speaker will shut down the amp.
                                    I hope that the tweeter voice coil is not damaged by that 9VDC.
                                    • spdy
                                      • May 2018
                                      • 26
                                      • india
                                      Thanks, most of the other amplifiers I have seen hardly show any voltage at the speakers
                                      and very often one of the outputs is grounded
                                      The tweeters are OK and have been checked from another sound source again.
                                        The amplifiers you are working on are using BTL output configuration that is why none of the speaker connection is connected to GND, look at the spec sheet of the IC.
                                        • crigab
                                          Bose soundtouch 30 no power on
                                          by crigab
                                          Hi guys, I have a Bose Soundtouch 30 to repair and I am stuck. I have 320V from the PSU to the mainboard, 24V on the amplifier, 5V and 3.2V, but pushing the power button, It is not powering on. I found a chip that it is heating when i plug the speaker in the outlet, but i can not find anything about the chip - C4E smd 8pin chip. It is anyone with some experience on this type of Bose to help me with some ways to find the problem? Thanks
                                          03-06-2024, 12:49 AM
                                        • FALKLAN
                                          Mercedes-Benz W163 Bose Audio System
                                          by FALKLAN
                                          Howdy everyone!
                                          I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
                                          On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
                                          12-07-2023, 11:22 PM
                                          Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                          by momaka
                                          Boston Acoustics fans, this thread might not be for you.
                                          A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                          01-30-2022, 11:57 PM
                                        • CapLeaker
                                          Dell ATX PSU won’t start, but forcing it works fine?
                                          by CapLeaker
                                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                          10-28-2024, 06:59 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
