Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Mercedes-Benz W163 Bose Audio System
  • FALKLAN
    Madman
    • Nov 2023
    • 14
    Howdy everyone!
    I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
    On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the 2ohm Bose system. Is that correct? It's been so long I can't remember parallel or series. *** googled it after-the-fact *** Also this is a, I think, D2B fiber optic system which limits me to two channel input from the head unit to D2B converter.
    Replacing the entire system doesn't concern the 2ohm Bose problem. 4ohm component and loudspeakers and 2ohm/1ohm sub configuration. I'll probably go with 2 amps if replacing the factory system.
    Thanks much!
    Last edited by FALKLAN; 12-07-2023, 11:33 PM. Reason: added Bose system information
    • 31498
    4ohm will be fine - just slightly less loud at full power
    2ohm sounds insane - i wonder what the amp chip looks like!
    bit of advice - unplug the canbus or optical from the unit and make sure the car doesnt throw a code.
    if it's optical like s-class your gonna need a loopthrough bypass adapter
    • FALKLAN
      Madman
      • Nov 2023
      • 14
      It's fiber optic to the amplifier and CD changer. All the fiber optic decoders I've seen only accept 2 channels (left/right). I don't like that one bit. However, breaking down the amplifier connector to get to the speaker wiring is something I would rather not do. Neither do I have any desire to run new speaker wire to 4 doors and two rear, what are they, D-pillars.
      Installing a completely new system is the best choice. I'll simply have to clinch my teeth and bare it.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8379
        Yes, the Fiber optics gonna be a pain in the butt. Probably better off to do a full replace.
        • FALKLAN
          Madman
          • Nov 2023
          • 14
          I installed a new audio system mid 2024: Boss BVCP9700A-FL 7" floating display head unit w/backup camera, (2) 10" DD Audio Redline subs, (2) Down4Sound 65 v2 6.5" midrange, (2) Pioneer ts-b401pro 4" tweeters, DD Audio D1100 monoblock 1100W RMS @ 1Ohm, D4S JP84 4Ohm Bridged 280W RMS 2 ch.
          Click image for larger version  Name:	chuchero (cropped).jpg Views:	0 Size:	493.4 KB ID:	3567110
          Click image for larger version  Name:	Enclosure1cropped.jpg Views:	0 Size:	438.6 KB ID:	3567111
          Click image for larger version  Name:	7.4.2024 Head Unit Install.jpg Views:	0 Size:	439.1 KB ID:	3567112
          The system sounds great! I'm going to replace the head unit with a flush mount unit and install a radial arm to use a tablet as an audio source. This head unit, like most I believe, is incapable of doing much of anything with stored media (thumb drive). I will only read 999 mp3s, and if there are more audio files, it neither reads them or plays them. It only produces a fixed list of music files on the USB media, and you cannot manipulate that list at all. No sorting, no searching, no playlist creation/reading, nothing more than a fixed list alpha numerically sorted. Also the backup camera I installed only works well during daylight hours, which I'm installing some LED pods for reverse lights. The pods should illuminate the area well enough for the backup camera to function at night.
          • Steadily7-Colossal0
            bose soundlink color 2 strange behavior
            by Steadily7-Colossal0
            My dad gave me his bose soundlink color 2, claiming that the charging port was loose. I opened it up, plugged it in, probed around with a multimeter, and I can measure 5V all over the board. I wiggle the charging cable around, no change. The port looks fine: sturdy, clean contacts. I measure across the battery wires and I get 0V, so I assumed the battery was the problem. But then a few minutes later after I disconnected and re-connected the daughter board with the buttons, lights were flashing and I was reading 3.3V across the battery wires. The only logical explanation for this I could come up...
            12-12-2024, 03:20 PM
          • mpa2
            Bose Lifestyle 650 remote malfunction
            by mpa2
            I'm trying to fix this RF Bose remote (model nr. 420129) for a friend. After applying supply voltage the display shows the Bose logo, after a short period of time it goes dark and the MCU enters a sleep mode. It wakes up after a key is pressed, the display remains dark all the time after the start up sequence.
            Sometimes it can still be paired with the main unit and you can control it for a short period of time, then the unit stops reacting again.
            The pcb is clean, there are no signs of corrosion. The voltages look adequate.
            I read...
            10-28-2024, 03:10 PM
          • Marek011
            Help in recognizing the components on the BOSE amplifier board
            by Marek011
            Hello, I have a problem recognizing the elements marked with blue dots, unfortunately BOSE does not provide any boardview. What could it be? Foil capacitors?
            BOSE board number: 283394-001
            Thank you...
            03-25-2024, 08:24 AM
          • crigab
            Bose soundtouch 30 no power on
            by crigab
            Hi guys, I have a Bose Soundtouch 30 to repair and I am stuck. I have 320V from the PSU to the mainboard, 24V on the amplifier, 5V and 3.2V, but pushing the power button, It is not powering on. I found a chip that it is heating when i plug the speaker in the outlet, but i can not find anything about the chip - C4E smd 8pin chip. It is anyone with some experience on this type of Bose to help me with some ways to find the problem? Thanks
            03-06-2024, 12:49 AM
          • CraigR
            Bose Wave Radeo CD not spinning
            by CraigR
            I have a Bose Wave radio series 3 that came in with "disk unreadable" issue so I cleaned the lenz and blew the thing out clean and recapped the laser board. It payed half way through a song then just quit. I watched as the CD enters the player and it does not spin or move what so ever. I did attach a power source to the motor and it does spin. I get 3v comming to the + side of the motor but nothing for a ground and it's not directly grounded. Anybody have some ideas??...
            10-14-2025, 03:57 PM
