Klipsch RW-10 LED is not turning on
  • Xan03
    Klipsch Promedia 2.1 rhythmic subwoofer "pulsing" during standby
    by Xan03
    I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
    I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?
    11-17-2024, 06:54 AM
  • JarzabekPZ
    HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
    by JarzabekPZ
    I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
    09-18-2025, 08:16 AM
  • Seb932
    LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    by Seb932
    i'would like to fix my not working LG 49UB850V tv.
    Symptoms:
    -AC plugged in, Standby LED not working
    -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
    Checked already:
    -Powersupply Output in Standby => 3.5V ok
    -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
    Any suggestions what to check next?
    Thanks in advance!
    09-14-2023, 06:28 AM
  • brithepi2k
    Samsung UE75TU7020k No picture, Standby blinks 2 times
    by brithepi2k
    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
    04-23-2025, 10:05 AM
  • cekanayake
    L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
    by cekanayake
    I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
    When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
    04-19-2023, 08:37 AM
