Klipsch RW-10 LED is not turning on
  • Xan03
    Klipsch Promedia 2.1 rhythmic subwoofer "pulsing" during standby
    by Xan03
    I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
    I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?
    11-17-2024, 06:54 AM
  • Seb932
    LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    by Seb932
    i'would like to fix my not working LG 49UB850V tv.
    Symptoms:
    -AC plugged in, Standby LED not working
    -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
    Checked already:
    -Powersupply Output in Standby => 3.5V ok
    -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
    Any suggestions what to check next?
    Thanks in advance!
    09-14-2023, 06:28 AM
  • brithepi2k
    Samsung UE75TU7020k No picture, Standby blinks 2 times
    by brithepi2k
    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
    04-23-2025, 10:05 AM
  • cekanayake
    L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
    by cekanayake
    I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
    When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
    04-19-2023, 08:37 AM
  • moosets
    Hisense 55h8f, standby ok, not turning on
    by moosets
    Symptoms: Not turning on after pressing power button on tv. Standby red light on power button turns on when plugged in. Pressing power button on tv causes standby led to turn off for 2 seconds, and then back on red until power is removed (no longer responsive).
    Tried: Removing power, holding power button, returning power. No change.
    Power supply: 244194 RSAG7.820.8805/ROH
    Main board: 244187B, RSAG7.820.8833/ROH
    Opened back and inspected all boards, no obvious damage anywhere.
    The power supply is making a slight clicking noise, maybe a...
    12-08-2021, 11:55 AM
