L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    #41
    Re: L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
    What a way to end it!
    I can’t believe you would stop! You’ve got 3 or 4 very knowledgeable and smart blokes basically spoon feeding you how to go about repairing the set and you’ve give up!
    What a tit!
    • IoT-Maker
      • Aug 2020
      @Davi.p thanks for your hint.
      I never had a bad transformer on a PSU. Got this BN44-00627A here since March and could not fix it. First i found the D2011K damaged. The IC is next to the transformer. Also one UF4007G diode was damaged. I replaced it with a UF4007 only to find out weeks later it's causing trouble. The boost circuit was not working. It needs 390V but was only at around 316-320V. I replaced the UF4007 with the (hard to find) UF4007G which is much quicker and the boost voltage works.
      But there was still a clicking and no stable output voltage. Because i could not find the fault, i bought a working board to compare measurements. Some values were different but not that much. At the end, i started to swap parts. I swapped all elkos, all diodes on the top side. Nothing helped.
      Finally, because i read this post today and the transformer on the old board was heating up a little bit (which the one on the working board did not), i desoldered the 210064HD KE-03B DY transformer (something i did never before) and testet it with a DE-5000. One winding should have 0,410 Ohm but i read 1,230 Ohm. I swapped the transformer and the board was working as expected. No clicking, stable voltage.
      • Seb932
        LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
        by Seb932
        i'would like to fix my not working LG 49UB850V tv.
        Symptoms:
        -AC plugged in, Standby LED not working
        -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
        Checked already:
        -Powersupply Output in Standby => 3.5V ok
        -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
        Any suggestions what to check next?
        Thanks in advance!
        09-14-2023, 06:28 AM
      • brithepi2k
        Samsung UE75TU7020k No picture, Standby blinks 2 times
        by brithepi2k
        My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
        04-23-2025, 10:05 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • Jackching
        Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
        by Jackching
        I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
        04-15-2024, 05:14 PM
      • billg123
        NEC E464 no picture/backlight, standby light blinks on 10s interval
        by billg123
        Hoping you might be able to help me with an odd issue. I have a bank of 4 NEC E464 commercial screens that have been running on an ~8hr cycle for maybe 5 years. I unplugged them during some electrical work, and when I plugged them back in, one refused to come back up. It doesn't respond to the hard buttons or the remote at all. The main "clue" I have to work with is that the standby light blinks twice on a 10-second interval. I can't find a technical manual for these screens to see what that indicates. I've already tried many of the easy internet suggestions (plug...
        04-23-2022, 06:03 PM
