SMD Regulator gets too hot
  • DjKrish
    • Oct 2012
    • 354
    • SG
    I have a cd player that has a problem of giving a plain siren sound after warm up say like 1 or 2 hours. It plays fine before that. No matter cd player is playing or idle, the siren sound continues. I check the audio signal output board and found out that theres a voltage regulator thats getting pretty hot. Not burning my finger but it is hot within a second or 2.
    I checked for voltage as its a SMD 12V>5V regulator. Used digital MM and found incoming is 11.7V and output is 5.7V. Is that normal? Or the regulator fried? Should DC voltage be 100% accurate or can be plus minus a few percents? According to the datasheet, plus or minus it shouldn't be above 1% that's +/- 5.05V but here its showing 5.7V which is 14% higher than allowed
    I have attached the datasheet for the regulator and also a schematic for the board.
  • R_J
    • 9594
    Re: SMD Regulator gets too hot
    You could have a bad cap (1uf/50v) on the output. If the output is not filtered properly they can start to oscillate.
    • DjKrish
      • Oct 2012
      • 354
      • SG
      But shouldn't the output leg show exactly 5v? Cause its a 12v>5V regulator.
        Not if it is oscillating.
        Look at the output with the scope.
        • DjKrish
          • Oct 2012
          • 354
          • SG
          Thanks for the reply budm, sadly i dont have a scope. Only digital and analogue MM
          • R_J
            • 9594
            Just find a 1 uf (or what ever value it is) and add it across the output and see if the voltage drops and it runs cooler.
            • DjKrish
              • Oct 2012
              • 354
              • SG
              As i suspected, it was indeed the regulator. Now the voltage is stable on the output after replacing a new one.
                Glad to hear that it is just the bad regulator not the oscillation due to bad filter caps or too much current drawn by the load.
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  Thats right, before was high voltage around 5.8V, after replacing stabilized to 4.8V which is normal.
                    The spec of the IC indicates High precision output of +/- 1%,
                    So getting 4.8V instead of 5V is more than 1% tolerance, that is about 4% off, so may be there is still problem in the circuit.
                    From spec sheet:
                    "High Precision Output Vo ±1.0%"
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      From spec sheet:
                      When ever i see an instance of a voltage regulator whether linear or digital become hot or unstable I tend to first blame the input filter caps because of age or other problems with the caps. These are the most suspect components in my opinion.
                        We already suggested OP to check the output and input caps, and look at the output with the scope.
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          From spec sheet:
                          But the weird part is, i had 3 other same players and i tested the voltage and it all stands still at 4.8V. Weird? Or bad design?
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            Have you checked the calibration of the volt meter, is it in spec?
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              I used 3 meters and it gives same reading
                              • Sparkey55
                                • Jan 2010
                                • 1523
                                So? You could still have three meters out of calibration. Are you using the same set of meters leads each time you take readings? Find a three terminal voltage regulator preferably a 7805 and connect the +12v in from the amps power supply and measure the output (+5VDC) from the 7805 reg.
                                • DjKrish
                                  • Oct 2012
                                  • 354
                                  • SG
                                  Yes all my meters are recently calibrated.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5041
                                    • New Zealand
                                    Makes me think that maybe they've all recently been calibrated incorrectly, then.
                                    Or, you could still have some kind of noise on the output of the regulator, which is causing the error.
                                    -David VanHorn
                                    • slothen92
                                      Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
                                      by slothen92
                                      Hello
                                      Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
                                      I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
                                      On the body of the IC it says: “LF33AH GK133544”.
                                      Does anyone know where to find this part or a replacement for it?
                                      Cheers
                                      04-09-2025, 08:30 AM
                                      MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                      This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      09-06-2024, 05:30 PM
                                    • redwire
                                      Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
                                      by redwire
                                      My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
                                      Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
                                      Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
                                      The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
                                      The tone caps are green film caps I left alone. Newer...
                                      07-30-2023, 08:21 PM
                                    • disorder
                                      HP 2311 display, 3.3v regulator fried, need help to replace
                                      by disorder
                                      hello,
                                      i have a hp display 2311 to repair, totaly dead
                                      on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                      i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                      thank you
                                      07-27-2025, 04:34 AM
                                    • slybunda
                                      Alarm Siren issue
                                      by slybunda
                                      Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
                                      Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
                                      took siren out of the car and checked it out and pics attached seem to be the source of the issue.
                                      shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
                                      getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
                                      02-04-2024, 11:01 AM
