Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
  • slothen92
    • Apr 2025
    • Denmark
    Hello
    Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
    I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
    On the body of the IC it says: “LF33AH GK133544”.
    Does anyone know where to find this part or a replacement for it?
    Cheers
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Mouser has like 20k of these in stock.
    Mouser Part #
    511-LF33ABDT-TR
      • 31286
      http://www.farnell.com/datasheets/2815821.pdf
      • slothen92
        • Apr 2025
        • Denmark
        Thanks for the answer to both of you!
        I have found this part and datasheet before posting here, but I can't find the exact identical 3.3V component labelled "LF33AH" in the datasheet under ordering information.
        Is the last "H" not that relevant to the functionality?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          What’s relevant is LH33A. The H is in a different line.
          • slothen92
            • Apr 2025
            • Denmark
            That broadens the scope indeed. Thank you very much for your answer.
