Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
  • petehall347
    • Jan 2015
    • 4438
    • United Kingdom
    Re: Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
    leave the door unlocked then to a burglar there cant be anything worth taking .
      • 31196
      but then people sleep in it or the police break in to "investigate" and shoot you because they are gutless fucks who "fear for their life"
      that's a line they use to avoid prosecution btw. it's almost a meme it's so old
      • CapLeaker
        Leaking Member
        • 8327
        Originally posted by stj
        well if you want to go down the blatant route you could use a solenoid valve or electric pump to spray the intruder with anything from freezing cold tap water to petrol or kerosene
        that should make them run - nobody is going to start a fight while they are at risk of exploding in flames!
        I am liking it! After that I’d give him a run for the money too, as my furry legged friends with pointy ears always like new chewies!
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I am liking it! After that I'd give him a run for the money too, as my furry legged friends with pointy ears always like new chewies!
          I almost did this and changed my mind - then some dope head broke into my house. Lol. You will be seeing some fun upgrades like that to my door soon.
          A working TV? How boring!
          • slybunda
            Alarm Siren issue
            by slybunda
            Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
            Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
            took siren out of the car and checked it out and pics attached seem to be the source of the issue.
            shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
            getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
            02-04-2024, 11:01 AM
          • Tom41
            Honeywell Accenta G3 tamper alarm
            by Tom41
            This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
            I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
            08-31-2023, 04:00 AM
          • jayjr1105
            Micronta Talking Alarm Clock Full Recap
            by jayjr1105
            My grandfather had this Micronta VoxClock3 digital alarm clock that just had random digits displayed when you plugged it in and just overall acted crazy. Opened her up last night and found every single cap either completely open or ESR in the 50 ohm range. All caps replaced but waiting on a .47uf 50v cap to arrive as I didn't have any.
            05-17-2021, 07:18 AM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
          • Ady2017
            Does anyone know about 16x2 LCD screens used in alarm keypads?
            by Ady2017
            I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
            06-02-2025, 04:56 PM
