Bose Solo TV - need SMPS schematic
  • dobrykamil
    • Jun 2013
    • 63
    Hi
    I'm looking for SMPS schematic of Bose Solo TV. Does anyone also know, what is the output voltage of that psu?
    Thanks in advance.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Bose Solo TV - need SMPS schematic
    Whats the model number? this maybe?
    • dobrykamil
      • Jun 2013
      • 63
      Yes, I've got that service manual already, no schematics inside at all.
        Look at Manual in post #2:
        Page 25 show flyback transformer T1201 for 24V 2.5A. BOSE P/N 370743-0010 .
        So it is more likely to be 24V power supply,
        Page 20: the filter caps are rated at 1000uF 35VDC for C1321, C1318. C1316 is 220uF 35VDC.
        Cold side Rectifier page 22: D1301 SCHOTTKY RECT., 5A, 170V, COMMON CATHODE, BOSE P/N 329305-0010
        Page 23: U1201 is the SMPS IC, BOSE P/N 348216-0010.
        Page 23: LDO and Buck regulator ICs: U702, 704, 705.
        So lots of info on that service manual to get you started.
        May be you should upload the pictures.
        • dobrykamil
          • Jun 2013
          • 63
          Hi.
          Yes, you're absolutely right, I should have done that in the first place I've found that smps controller is kinda dodgy and one of the mosfets has short. I still have psu from Canton DM50 which provides output of +23.5V, so I'll see if everything else is fine before I order some spare parts. Many thanks Budm for a tip!
