Bose Solo TV - need SMPS schematic
  • dobrykamil
    • Jun 2013
    • 69
    Hi
    I'm looking for SMPS schematic of Bose Solo TV. Does anyone also know, what is the output voltage of that psu?
    Thanks in advance.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Bose Solo TV - need SMPS schematic
    Whats the model number? this maybe?
    • dobrykamil
      • Jun 2013
      • 69
      Yes, I've got that service manual already, no schematics inside at all.
        Look at Manual in post #2:
        Page 25 show flyback transformer T1201 for 24V 2.5A. BOSE P/N 370743-0010 .
        So it is more likely to be 24V power supply,
        Page 20: the filter caps are rated at 1000uF 35VDC for C1321, C1318. C1316 is 220uF 35VDC.
        Cold side Rectifier page 22: D1301 SCHOTTKY RECT., 5A, 170V, COMMON CATHODE, BOSE P/N 329305-0010
        Page 23: U1201 is the SMPS IC, BOSE P/N 348216-0010.
        Page 23: LDO and Buck regulator ICs: U702, 704, 705.
        So lots of info on that service manual to get you started.
        May be you should upload the pictures.
        Subscribe to support us and access our Bios, Boardview, schematic search. It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • dobrykamil
          • Jun 2013
          • 69
          Hi.
          Yes, you're absolutely right, I should have done that in the first place I've found that smps controller is kinda dodgy and one of the mosfets has short. I still have psu from Canton DM50 which provides output of +23.5V, so I'll see if everything else is fine before I order some spare parts. Many thanks Budm for a tip!
          • Yasmoooni
            • Apr 2026
            • Deutschland
            i have a dead bose solo myself and try to find the fault. Unfortunately i am a little afraid of voltage and would like to ask if anyone know some testpoints on the board that provide the needed voltages. Thank you in advance
            • williej
              • May 2005
              • 12
              • electronic repair
              Bose Service Manual with Schematic
              • funny718
                • Dec 2024
                • 7
                So this took me 1 year if not more but I hate quitting.
                I used Claude ai as a mentor to help me fix this and produce this whole forum post so don’t kill me if I did something wrong but would love any constructive criticism.
                Thank you and hope this can help others keep these Bose solo out of the dump they aren’t half bad.
                Bose Solo 10 (and likely Solo 15 / Solo TV): won't boot or no chime. Corrupted SPI flash, how to check and reflash
                Verified on one unit: main board WBM0127, Boot 1.0.0.1148, Main 1.0.6.1287. Other revisions may differ, so compare before you write anything.
                The problem
                My Solo 10 would power up but never fully start. Cold starts stalled with no chime and no sound. For a while it would sometimes work after heating the processor area or after a reset, then it got worse over time, until it stopped booting completely. On the service (TAP) port it printed only <, or nothing at all, instead of the normal < → Bose Solo → >.
                The cause: the firmware had written one of its settings records on top of the boot program in the SPI flash chip (U201). With the boot program damaged, the processor couldn't start. Restoring 155 bytes in the boot area fixed it completely.
                If your unit shows the same symptoms, here's how to check and fix it, in order.
                Step 1: Rule out the basics
                • Power rails, compared against a working unit: 24 V in, about 6 V (VR703 output), 3.3 V, about 1.24 V core, 1.8 V (VR701). VR703 (TPS54140) is a common failure. Mine had a crater in it.
                • Reset: U204 (TPS3825) pin 1 should be high (about 3.3 V) when running.
                • Clock: the 24.576 MHz crystal next to the processor is U202's clock (not the 26 MHz one).
                If all of those are good and it still won't boot, check the flash.
                Step 2: Read the service port (TAP)
                • Connect to the unit's TAP service port (the 3.5 mm "Data" jack) with a 3.3 V USB-serial adapter, 115200 8N1, no flow control. Put 1 kΩ resistors in the TX and RX lines, otherwise the adapter can back-feed the unpowered board.
                • Listen only at first. A healthy boot prints < (the loader) then Bose Solo and >.
                • Useful read-only commands once it's running: vr (versions), sr (serials), persist, ui, dc (list commands).
                • Don't send fd, sw or other write commands until you've backed up the flash. I learned that the hard way.
                Signs of corrupted stored data: sr shows garbage serials or crashes, persist shows odd values (mine read drcSetting: 48, which should be 1), ui shows a nonsense "power cycles" count.
                Step 3: Back up the flash
                • U201 = Spansion S25FL032P, WSON-8 6×8 mm (marked FL032PIF), pin 1 dot at top-left.
                • Remove it with hot air (protect U202's legs with Kapton and foil). I used 350 °C with low airflow.
                • Read it with an XGecu T48 plus a WSON8/QFN8 6×8 → DIP8 socket adapter. In Xgpro, select "S25FL032P @SOIC8". Read twice and confirm the checksums match. Keep both files.
                Step 4: Check the dump
                Flash layout (4 MB):
                Address
                Contents
                0x000000
                Boot program (starts with TIPA)
                0x010000
                Settings storage (serials and counters, records start with 5E B0 FE CA)
                0x020000
                Mfg/test program
                0x060000
                Factory main program (1.0.2)
                0x1E0000
                Updated main program (1.0.6), only present if the unit was ever updated
                Each program ends with a checksum byte: all bytes of the image, including the last one, add up to 0x00 (mod 256).
                Range
                Boot
                0x000000–0x00FFFF
                Mfg
                0x020000–0x05FFFF
                Main
                0x060000–0x1DFFFF
                Upgraded main
                0x1E0000–0x35FFFF
                If one fails its checksum, that's your problem.
                What mine looked like: the boot area was normal up to 0x15F, then 0x160–0x1FA held a settings record (marker 5E B0 FE CA, my serial text) instead of the boot table, which in a good image looks like FF FF FF FF 11 11 11 11 0D 59 53 58 07 00 03 00 …. Only 1→0 bit changes, meaning it was programmed over without an erase.
                Step 5: Get a known-good reference
                • Run Bose's official updater (Bose Solo support page, "Updating the software"). It creates a Bose_Solo_TV_sound_system_1.0.6.1287.bos file on the USB stick. That file is a raw flash image for 0x000000–0x1DFFFF, with the same layout (boot, mfg, main).
                • Its boot program is a newer build (1287) than mine (1148), but apart from the version text it's identical. That includes the table at 0x160.
                • Or read the flash of a working unit with the same boot version, which is the best reference.
                Step 6: Repair and reflash
                • Change only the damaged bytes. Copy 0x160–0x1FA from the reference into your dump. Leave everything else, especially the settings area, untouched.
                • Check that every image's checksum passes. My repaired boot passed using its original checksum byte, which proves the restored bytes were right.
                • Write it with the T48: FLASH only (STATUS/CFG unticked), Erase before ✅, Verify after ✅.
                • Resolder U201. Pin 1 dot top-left, flat pads, check for bridges.
                Small checker and patch script (Python):
                # usage: python fix.py my_dump.bin reference.bos out.bin
                import sys
                d = bytearray(open(sys.argv[1],'rb').read()[:0x400000]) # Xgpro adds 272 bytes of config at the end
                ref = open(sys.argv[2],'rb').read()
                imgs = {'boot'0,0x10000),'mfg'0x20000,0x40000),'main'0x60000,0x180000),'upg main'0x1E0000,0x180000)}
                def check(buf):
                for n,(s,l) in imgs.items():
                if buf[s:s+3]!=b'TIP': print(f'{n:9s} not present'); continue
                print(f'{n:9s} checksum', 'OK' if sum(buf[s:s+l])&0xFF==0 else 'BAD')
                print('before:'); check(d)
                d[0x160:0x1FB] = ref[0x160:0x1FB] # restore the damaged boot table only
                print('after:'); check(d)
                open(sys.argv[3],'wb').write(d)
                Only write the result if every image says OK. If your damage is somewhere else, find it by comparing against the reference first. Don't blindly copy my address range.
                Step 7: After the fix
                • If the serials are garbage, the service manual's sw command restores them: sw cafeb0se,<bank>,<serial>, with bank 0 = main board, 1 = IR, 2 = system (from the label). Back up first.
                • Check persist now and then. The "current block" address should stay inside 0x10000–0x1FFFF. If it ever points outside that range, the bug is about to strike again.
                Result
                Boot restored, 10/10 cold power-ups with the chime, and it passed an overnight cold soak.
                Please don't post full flash dumps. They contain your unit's serial numbers, and Bose's firmware isn't ours to share. Share the addresses and checksum results instead.
                Thomas Edison's
                "I have not failed. I've just found 10,000 ways that won't work."
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8887
                  Not the First time I see that the boot gets overwritten somehow. There are quite a few devices I know of where the first of the boot gets overwritten with something or even rubbish and the device won’t work anymore. So I started to question why this happens, but found no answer. Just like your device, fixing the first lines on the boot fixes the device.
                  I’d really like to know why this happens and the boot gets overwritten right at that spot. Why not at the middle or the end? Better yet why not anywhere else on the flash?
                  This has nothing to do with Bose, same problem with other manufacturers and way different devices.
                  • new
                    Collection of Laptop Motherboard Schematic and Boardviews
                    by new
                    List of Pack :
                    01- Acer Aspire 3 A315-23G Quanta Z8E (DA0Z8EMB8C0) Schematic & Boardview
                    02- Acer Aspire 3 A315-33 DH5JL Compal LA-F943P r1.0 Schematic
                    03- Acer Aspire 5 A515-52K Compal LA-H441P Schematic
                    04- Acer Chromebook Spin 311 CP311-2H ZBA ZBB DA0ZBAMB6A0 Schematic
                    05- Acer Chromebook Spin 311 CP311-3H ZDE DA0ZDEMB8B0 Schematic
                    06- Acer ConceptD 9 CN917-71 Compal FH79F LA-G162P Schematic
                    07- Acer Spin 3 SP314-53GN Pegatron DL4FA Dolly Schematic
                    08- Acer Swift 3 SF315-41G...
                    02-18-2026, 01:06 AM
                  • Boardview and Schematic Bot
                    Xbox 360 All Models x815842-002 X862605-002 584711 Schematic & Boardview
                    Xbox 360 All Models x815842-002 X862605-002 584711 Schematic & Board view
                    Xbox 360 Jasper V1 x815842-002 osp.pcb
                    SCHEMATIC 584711 Wireless Control.pdf
                    Xbox 360 Corona V5 V6 sterling osp.pcb
                    Xbox 360 Corona V1 V2.brd.pcb
                    Xbox 360 Corona V3 V4 X862605-002 waitsburg.pcb
                    Xbox 360 Trinity FabF ver2.pcb
                    Xbox 360 Zephyr_B.pcb
                    Xbox 360 Zephyr A.pcb
                    Xbox 360 Jasper Kronos.pcb
                    Xbox 360 Falcon.pcb
                    Xbox 360 Xenon.pcb
                    Xbox 360 Xenon 008.pcb
                    Xbox 360 Corona Translation Schematic.pdf
                    Xbox 360 Zephyr A Schematic.pdf...
                    10-01-2026, 03:26 AM
                    Huawei P7 P7-L05 P7-L07 Schematic & Boardview
                    Huawei P7 adt.pdf
                    Huawei P7 adb.pdf
                    Huawei P7-L05 P7-L07 (TL) schematic diagram.pdf
                    Huawei P7 schematic diagram.pdf
                    Huawei P7 schematic.pdf
                    Huawei P7-L05 P7-L07(TL) Schematic diagram.pdf...
                    10-20-2026, 02:53 PM
                  • huzo
                    AI Service Engineer – Laptop Schematic Analysis & Guided Board Diagnostics [BETA]
                    by huzo
                    I've been working on a small Windows tool for laptop motherboard diagnostics and I'd like to share the first public beta with the community.
                    The project is called:
                    AI Service Engineer
                    The idea came from a very practical problem during board repair.
                    When troubleshooting a motherboard, a lot of time can be spent jumping between schematic pages trying to find the next power rail, enable signal, power-good signal or reset signal that should be checked.
                    I wanted to build something that could help guide that process....
                    08-31-2026, 02:13 PM
                    Tesla Motors Model X Model Y Model S Model 3 Parts, Schematic & PCB Data
                    Tesla Motors Model X Model Y Model S Model 3 Schematic Part & PCB Automobile Data. Donated to Badcaps to help with PCB repairs.
                    Tesla Motors 12V HVAC Communications Controller.pdf
                    Tesla Motors Vehicle Interface 09-000162-00 09-000162-01.pdf
                    Tesla Motors EG89M52 + EG3011 + EG1181 Electric Vehicle Schematic.pdf
                    Tesla Motors Top Level 12V HVAC Controller.pdf
                    Tesla Motors 09-000040-01 Vehicle Display System VDS Schematic.pdf
                    Tesla Motors 12V HVAC Controller Power Section.pdf
                    Tesla Motors 12V HVAC Controller Power Supply.pdf
                    Tesla Motors TTL...
                    10-19-2026, 03:57 AM
