Re: Help with Onkyo TX NR 838
You remember correctly.. but why? All channels are identical, so I believe this is onkyo's way to cool down a bit their units. Other possible explanation would be the heat gradient of the heatsink.. but from what I've seen, if all channels are running, the heatsink temperature is the same ( +/- a couple of degrees ) everywhere on its surface... so what's the point of having different settings on similar components?
If the channels are identical, I always set the same idle current on all of them and aim for the higher end of the mV
