Help with Onkyo TX NR 838
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    #41
    Re: Help with Onkyo TX NR 838
    Originally posted by tibimakai
    Main channels have higher mV, then the surround ones, if I remember correctly.
    It never happened to me, that it did not reach the required voltage. It happened that the voltage was raising to fast, which showed me, that there is still a problem.
    Just make sure, that you have 9-11mV, at 6 minutes after startup.
    You remember correctly.. but why? All channels are identical, so I believe this is onkyo's way to cool down a bit their units. Other possible explanation would be the heat gradient of the heatsink.. but from what I've seen, if all channels are running, the heatsink temperature is the same ( +/- a couple of degrees ) everywhere on its surface... so what's the point of having different settings on similar components?
    If the channels are identical, I always set the same idle current on all of them and aim for the higher end of the mV
    • madan1
      • Nov 2016
      • 682
      • Bulgaria
      #42
      Originally posted by Mogli1476
      Today i also measured the voltages and find out that the VOLH Voltage is normally between 0,47 and 0,5 V. But in the SM the graphic shows a voltage near 3,3V during normal run. Could this be a problem?
      I do not know what's running on VOLH, but yes, it could be ( and most likely is ) causing issues.
      See what's using that Volh and just try to use it ( like video/audio processing, OSD, HDMI, component video, ethernet, etc. ).
      Otherwise i don't have 64V but only 62V. But i think this is no problem at all.
      62V is just fine.
      How i can check that my HDMI Board is running well? I'm not sure that there is problem and i want to exclude it.
      Regards, Mogli
      See above - just test it.. see what is working and what not.
      • Mogli1476
        • Feb 2015
        • 36
        62V is just fine.
        Ok! I will do so ...
        I will check all the things step by step tomorrow.
        But some information i have before. Yesterday i tried to run the test mode 1.01 but it passes and jumps to test mode 4-19. This mode runs until 4-25 with turning the relays on and off. After this test run the messages RouteTest OK! and VideoDetection Ok! appears. After this NG is displayed.
        The time on the display continues but nothing happens and only NG is still in the display.
        And VOLH is still between 0,46V (LOW Mode) and 0,5V (HIGH Mode). It's the same with the PRE Amp Board uninstalled. I still think there is the problem.
        Tomorrow i will check everything and will disassemble the receiver again to find the problem on the Main Board. Maybe some of you have the same receiver or a similar one to check if the VOLH has to raise until 3,3V or something else.
        Regards, Mike
        • Mogli1476
          • Feb 2015
          • 36
          Regards, Mike
          Another last question before i will check everything is ...
          What voltage should i have at PIN 1 on the HDMI Board connector P901? The SM from the 646 says 3V. But I only measure a voltage of 0,3 .. 0,6v. Is there something wrong?
          Yesterday i determined that the HDMI Out Signal is like snow on the Main Screen when I switched to USB, NET or Bluetooth.
          Also the Network test can't finished without errors but WLan, Ethernet and Bluetooth is working like it should.
          Regards, Mike
          • Mogli1476
            • Feb 2015
            • 36
            Regards, Mike
            So! I'm back again with some more informations. I checked a working TX Nr609 from a friend to be sure which voltage is normal for MPOWER. After Powering on the 609 i measured a voltage of 3,1V on PIN 1 of connector 901. Also like the SM for the TX NR646.
            But if i'm measuring the Pin 1 of my 838, there is only 0,5..V during run. This is not normal or what do you think?
            I checked Q7016 and changed this too with a working one but it's the same. MPOWER on Q7016 is 3,1V during run and that seems ok i think.
            Later i checked the Power PCB for errors and measured 11,7 V at MPOWERD during Standby. After run MPOWERD go down to 0,5..V but MPOWER which comes from Q7009 is Ok with 3,1V.
            Is this a normal process or could there be a problem in the Power PCB?
            I also changed D9011 and C9015 beside the Relais on the Power PCB but that changes nothing. Is it possible that the relay RL9001 don't work like it should?
            Regards, Mike
            • madan1
              • Nov 2016
              • 682
              • Bulgaria
              #46
              Well, take out of the board RL9001 and test it.. it looks like it is drawing too much power or the power supply is too weak.
              • Mogli1476
                • Feb 2015
                • 36
                I think this was not the problem. I changed the old Relais from my 609 with this one inside my 838 and measured 330ohms on the old one (838) and 550ohms (609). The Voltage is now changed from 8,7v to 9,2v but everything was working like before.
                I'm not sure if this is ok but at the moment it works. The relays in the 609 though is not the same but both have 9V Coil voltage and are switching 120A,250V. I don't know the exact difference between both relays.
                Otherwise MPOWERD has now 0,52V instead of 0,37V and that means the state for low input on Q7016 is working. Also with 0,37V the receiver works well.
                • Mogli1476
                  • Feb 2015
                  • 36
                  Otherwise I checked the whole receiver functions yesterday and found nothing corrupt. Everything is working like it should. Only the receiver is getting warm and warmer so that i cannot touch most parts of the PRE Amp Board and also the heatsink for the 15V regulators. Is this normal?
                  The receiver works and works and works, tested with every hdmi source, flat tv and loudspeakers. Only the heat growth seems not ok for me but the receiver runs for approx. 2 hours and all was ok.
                  • madan1
                    • Nov 2016
                    • 682
                    • Bulgaria
                    #49
                    Onkyo receivers tend to run very warm. Unfortunately I did not measure the temp. of the units I was fixing so cannot tell you if yours is running hotter than it should.
                    Currently I have a Cambridge audio receiver and here are some measurements:
                    65-80 degrees on the main heatsink ( for the power amplifier )
                    55-65 on various voltage regulator heatsinks ( 3 or 4 of them )
                    I've not noticed excessive heat coming from the pre amp board of a properly working amplifier. Once I had a such case when there was an interrupted path to one of the drive transistors and several components were getting very hot, but the channel was still producing sound.
                    If you really think that your pre amp board is getting too hot and do not have the means to measure the temperature ( like thermal camera, infrared thermometer, thermo-couple, etc. ) you can use sticky thermal printing paper ( stick it to the transistors and see if any of them get hotter than the rest ).
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I believe, that the fan should kick in, around 60C.
                      I have replaced the internal fan, with a laptop cooler's fan(same size), that had an adjustable speed controller and I have adjusted for low fan noise. USB cable, was plugged in into my TV's USB port. So every time the TV it was on, the fan would be on as well.
                      The latest receivers, don't even have a fan, they run much cooler. There is no idle current adjustment either.
                      • Mogli1476
                        • Feb 2015
                        • 36
                        For sure I have an infrared thermometer ;-) The next time i will measure the hottest parts in the receiver and post it here to check if everything is Ok.
                        I'm not sure yet but i think the Driver Transistors TTA/C 004B on the Pre Amp Board have had approx. 70 degrees after my last measurement but i will post actual values next time.
                        Regards, Mike
                        • CDNBrewer
                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                          by CDNBrewer
                          Hello Everyone,
                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                          Symptoms:
                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                          • I swapped the Left and Right surround
                          Yesterday, 09:29 PM
                        • eccerr0r
                          old X58 triple channel board... memtest86 memory speed?
                          by eccerr0r
                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                          06-28-2025, 09:06 AM
                        • spleenharvester
                          Reverse engineering of 18650 4-channel tester
                          by spleenharvester
                          Hi friends
                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                          05-04-2025, 02:43 AM
                        • ai.need.help
                          Onkyo TX-8050 AV-Receiver no sound
                          by ai.need.help
                          I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                          It doesn't play music. There is no real output from:
                          pre-out
                          amp-out A and B
                          phones out
                          The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                          I tested with analog-input, usb and radio.
                          I know that there is a common problem with...
                          12-20-2022, 05:54 PM
                        • acedogblast
                          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                          by acedogblast
                          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                          03-01-2023, 08:24 PM
