Marshall Stanmore Repair
  • Arno2
    • Mar 2019
    Re: Marshall Stanmore Repair
    Hi there,
    I am willing to not scrap my marshall stanmore as well and reuse the existing enclosure as well as the drivers.
    I understood ToxicGumbo and others (https://techfindings.one/archives/3375) have explored this option .
    My questions to the group:
    1) Has anyone tried to reuse the original crossover ? If yes can you share your experience ?
    2) Could anyone identify the crossover itself ? The goop does not help and in case (1) is doable, I may not want to remove the goop to avoid damaging the crossover.
    3) @ToxicGumbo: Can you share your experience when you say "the 50watt amp was a bad choice" ? I would have thought a 50w amp was a reasonable option. I was actually thinking of using this one.
    Thanks !!
    Arno
    • ToxicGumbo
      • Jan 2016
      • 16
      Hey, Arno2. It's a daunting journey, but an enjoyable one and I learned a lot in the process. There are certainly several ways to go about it, too, and you've taken it a step further by trying to isolate the core parts of the existing hardware. I'd actually like to see that work out, but you're correct to point out the challenge of obfuscated design through all that anti-vibration/snooping goop they slopped on the PCB.
      In my case, the 50W amp I picked turned out to take a stereo input and split it into two outputs for left and right speakers. Since the Stanmore has one speaker, the objective would be to have left and right combined into a single 50W mono output. One no-no of audio is never to splice stereo input signals together to force "mono" as it can potentially wreak internal havoc due to sound wave conflicts, so I was essentially forced to live with one channel output (left speaker?) for the woofer and rely on the tweeters for more noticeable stereo. No big deal, but it was a bit of a gut punch. I never could find a 50W amp that was guaranteed to output 50W of a combined stereo signal into mono for one speaker. There are hacks to sort of make this happen, but the safest approaches are a bit of a hassle.
      I saw and liked the unit you spotted, particularly for the built-in Bluetooth, though I opted to add Bluetooth separately as an independent input choice for the pushbutton selection. Since that's all I use at this point, built-in bluetooth would have been less of a hassle. The one thing that worries me about that unit is the TPA3116 chip. That's the same one on the board I bought and if you read the spec sheet, you're likely stuck with the same situation I had:
      https://cdn.badcaps-static.com/pdfs/...d5f959dd7b.pdf
      From page 24:
      "The TPA31xxD2 family can be connected in MONO mode enabling up to 100W output power."
      In other words, the only way to get both Left and Right in a single mono output means you're forced with 100W, which will overpower that driver. You can see in the block diagram on page 13 how the chip takes L & R inputs (LIN*, RIN*) at the very start and produces L & R outputs (OUT*L, OUT*R) under normal 2x 50W mode.
      Maybe there's an easy solution to this, but just combining signals before or, especially, after, can possibly turn out nasty. For me, I just gave up looking for an alternative and went with one channel. Would love to hear your thoughts.
      • sunnysocket
        • Mar 2019
        • Taiwan
        Hi All , Have someone get success to fix stanmore ? I found mine met the same issue with R23 & still try to trace other problems
        • hann
          • Jul 2019
          • 16
          • Philippines
          hi im hann, my problem with stanmore is no power. On supply section. Already replaced pwm chip ob2269. Still to success.
          • hann
            • Jul 2019
            • 16
            • Philippines
            here is my board and i drawn a schem to find the culprit
            • hann
              • Jul 2019
              • 16
              • Philippines
              #26
              tested some voltage mark with arrows, but still no output
              • R_J
                • 9628
                You should have about 30 volts on the 100/63 cap connected to the diode and 5.1 resistor, The zener diode you have 5 volts on is too low.
                Do you have full B+ on the fet drain pin? are the two 0.1Ω resistors on the source good?
                When first connected to a/c, the ic should output pulses to drive the fet, that will induce a voltage in the secondaries of the transformer, The run winding should supply the run voltage (20~30v) to keep the ic operating. Check that the winding is not open, the diode is ok, the 5.1Ω is good and the 100/63 is good. Check that zener diode's number to get its value.
                • R_J
                  • 9628
                  I also see ZD1 drawn in series with the optocoupler, are you sure this is correct? Ususlly the zener is across the opto's output, check that it's not shorted
                  • hann
                    • Jul 2019
                    • 16
                    • Philippines
                    #29
                    thank for the comment, i try measure it again.there is no markings on zener.
                    • hann
                      • Jul 2019
                      • 16
                      • Philippines
                      #30
                      sorry for the drawing, its parallel on the opto. thanks for the correction. great help here.
                      • hann
                        • Jul 2019
                        • 16
                        • Philippines
                        #31
                        there is full B+ on fet drain pin, both .1 ohms good, both windings were ok, diode us1m reads .412 volts and ss14 reads .144 on dmm diode test. 5.1 ohms good, 100/63 good.
                        • R_J
                          • 9628
                          Whats the number on the (unmarked) zener diode? if it is bad it could be killing the feedback/run voltage
                          That ss14 seems to read low, was that check in circuit or out?
                          Also, check ZD1 that is cross the opto, it could be shorted
                          • hann
                            • Jul 2019
                            • 16
                            • Philippines
                            #33
                            ZD3 on pcb with blue band, ss14 check out in the circuit, zd1 is ok.
                            • R_J
                              • 9628
                              5 volts on the transistors collector is too low, find out why and you will likely fix the problem
                              • R_J
                                • 9628
                                Are you sure about how ZD3 and the transistor are drawn? Or is like this? This way the transistor acts like a regulator and the zener diode sets the regulator voltage.
                                Any other marks, letters, or bands on the zener? A blue band seems to designate Zener, but there is usually another band that tells the zener voltage
                                • hann
                                  • Jul 2019
                                  • 16
                                  • Philippines
                                  #36
                                  sir R_J thanks for the input sir. i have found the fault. its the 3.3/50 volts e cap, replaced it then voila! power restored. i studied the datasheet on the pwm ic. the e cap doesn't charge that is why the ic wont start. a very big thank to you sir.
                                  • hann
                                    • Jul 2019
                                    • 16
                                    • Philippines
                                    #37
                                    thank you sir R_J
                                    • R_J
                                      • 9628
                                      Good to see its fixed, That 3.3/50 is a common failure on smps's. and I would have replaced it right at the start. I guess I should have suggested that right away. That cap. needs to charge to the full vcc supplied by the transformer after a couple cycles, if it does'nt the ic will not start and run.
                                      • hann
                                        • Jul 2019
                                        • 16
                                        • Philippines
                                        #39
                                        I only tested that cap with analog multimeter that is i didn't see its bad. Hehehe
                                        • petehall347
                                          • Jan 2015
                                          • 4451
                                          • United Kingdom
                                          #40
                                          did you do as i do and see how long meter beeps for ?
                                          • Kezi Gamer
                                            Marshall stanmore multi room
                                            by Kezi Gamer
                                            Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                                            03-24-2025, 08:37 AM
                                          • jingleslacks
                                            Marshall Stanmore II - chip flash
                                            by jingleslacks
                                            Hey Friends!
                                            I have both a live and demo unit. Demo unit firmware disables Bluetooth, power toggle, and other settings. Resets via button combos will not work on these. Reaching out to Marshall is not an option either.
                                            I copied my live CMOS chip and flashed it to the demo unit, but that didn't fix it (MX25U3235F) This has worked for other devices in the past. I'm not a chip expert, but I'm assuming the firmware is stored in another chip.
                                            If anyone has any experience or ideas, let's hear them!
                                            Stanmore II
                                            Stanmore 2​...
                                            03-23-2024, 05:09 PM
                                          • thuygsm
                                            Marshall Stanmore 2 (flash chip)
                                            by thuygsm
                                            hello
                                            in my case, the Bluetooth - AUX - RCA signal light goes off after 5 seconds and repeats, (sound is there then 5 seconds then gone and repeats)
                                            i forgot them and reconnected, but they do not play on the speaker, although i can still adjust the 3 modes Bluetooth - AUX - RCA (on the phone)
                                            after i loaded a new rom, i lost bluetooth connection and could not power off, no boot sound. i loaded the previously saved rom again, but the situation still cannot find bluetooth and boot sound
                                            hope everyone can help​
                                            04-08-2025, 10:27 PM
                                          • learnmore
                                            Help choosing replacement transformer for Levoit 600S SMPS
                                            by learnmore
                                            Hello Community,
                                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                            Peace
                                            LM...
                                            11-04-2025, 09:35 AM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
