This soundbar has a blown AC/DC Offline Switcher IC which is top257en. I replaced it, power restored, can on the unit and sound works fine. After a while, turn it off, and turn it back on again by pressing the power button, the IC blows again
 Replaced it again, it blows again after playing with the power button ON and OFF a few times. If the power board is not connected with the main board, its not blowing. It only blows when in operational mode. I suspect it could be the ceramic caps and possibly the electrolytic caps as well. Any suggestions? 19V present (according to service manual) on the output pin that's connection to the main board which states 18V. I believe the AC side is working fine as the fuse is not blowing. Its definitely something to do on the DC side thats blowing the IC.
Already tested all the diodes, all in good order
 Replaced it again, it blows again after playing with the power button ON and OFF a few times. If the power board is not connected with the main board, its not blowing. It only blows when in operational mode. I suspect it could be the ceramic caps and possibly the electrolytic caps as well. Any suggestions? 19V present (according to service manual) on the output pin that's connection to the main board which states 18V. I believe the AC side is working fine as the fuse is not blowing. Its definitely something to do on the DC side thats blowing the IC.Already tested all the diodes, all in good order
