Yamaha HTR-5920 cracked schottky diode
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5046
    • US
    So I was replacing some bad caps on this receivers main amp and a glass schottky was inside the goop by one cap and cracked when I removed it. I already got some good idea from another member but I don't know if there is anything else I need to know. Here a direct link to posts and pictures
    https://www.badcaps.net/forum/showth...24&page=38#756
    if anyone has a schematic to this board, that would be fantastic
    thanks
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5046
    • US
    Re: Yamaha HTR-5920 cracked schottky diode
    found service manual. D938. References Q654. Also had a diode list but not sure which one it is.
    now i'm not sure its a schottky, maybe Zeiner
    • petehall347
      • Jan 2015
      • 4451
      1SS133
      it is written next to it on schematic .
      http://uk.farnell.com/rohm/1ss133t-7...rfnonsku=false
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5046
        • US
        I thought that area would be text searchable, shows what I know. Thanks for the info, you're a life saver
        ugh shit, I am not finding a replacement at mouser my closest supply. How much margin is there for error on this one? can I just surpass the maximum surges to the nearest high value? voltage too?
        • petehall347
          • Jan 2015
          • 4451
          1N4148 or something like it should work .
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            I usually keep about 50 1N4148's around the house.
            sigpicThe Sky Is Falling
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5046
              • US
              its been answered before but I would like a second opinion, do you think the forward voltage difference of 200mV should be ok?
              also, do you think the stuff covering the diode was there to prevent the cap from heating up too much? I mean, it has a 175C tolerance, putting it next to a 105C cap, was it for this purpose.
              funny ive dealt so much with caps on mboards and tvs but when it comes to pretty much every other component i'm pretty much in the dark (except maybe resistors)
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                Should be fine. That's such a small difference.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5046
                  • US
                  well I got them (diode, all 4 caps)
                  and, nope. The original problem was just a 60hz hum
                  now the initial power relay clicks, and as soon as the main amp relay clicks it turns off
                  • petehall347
                    • Jan 2015
                    • 4451
                    are you running it direct on mains power ? not that it should do this even on limited power .
                    any speaker loads ? if so try without .
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5046
                      • US
                      I'm...not sure what you're talking about.
                      speakers, yeah, I disconnected them , one at a time to see if it made any difference, nope
                      • petehall347
                        • Jan 2015
                        • 4451
                        try both disconnected
                          So the main power relay RY91 drops out when the speaker relays (RY61~64) comes on?
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5046
                            • US
                            it sounds that way
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5046
                              • US
                              video (turn your sound up, kind of soft)
                              • redwire
                                • Dec 2010
                                • 3912
                                It powers up, after a delay, relay clicks and it powers off?
                                The MCU has made an executive decision, lol. If this is what is happening, I'll guess... two things.
                                The MCU has a mega power supply monitoring line PROTE_PS pin 5 BN82 to CN96. It's a summation of a bunch of PSU voltages. This signal gets renamed PRV and is a monitor for +5V, +12V, -12V and the amp's rails +50V, -50V.
                                I estimate that line should be 2.5VDC if all PSU rails are OK. If you can watch it with a multimeter. Guessing the MCU turns things off if there is trouble seen there.
                                It might be nightmare in the muting circuit you were in, with D938 (by IC98).
                                Did you have a failed STK402? Maybe unmuting the power amps causes one channel to have a DC shift and trip the protect line at Q559/Q558.
                                I don't know what this receiver does if a power amp problem trips PROTECT.
                                Most stay on and display PROT or something, instead of powering down.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5046
                                  • US
                                  normally it clicks once the second you turn the power button. Display turns on and displays the volume or input for a second, and the second click turns on the speakers.
                                  I don't think the second relay is clicking on, the sound is the first relay clicking on and off
                                  I don't think my relays are failed. The unit was working just fine with the exception of 60hz buzz that I were believed from the bad caps on the main vrm (C960, C933(which wasn't bloated, but I replaced it just in case)). And two more next to them
                                  • redwire
                                    • Dec 2010
                                    • 3912
                                    If something works worse after I replace parts, I check my soldering, connectors etc. in case I did something "extra"
                                    I would measure the power supply voltages and see if they are good, and then the 6 power amp output voltages to check if a channel has DC offset and it's in protect mode. R564-R570 are one place to measure voltages.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5046
                                      • US
                                      Already checked it. Indeed I did break some traces right around many of the joints, but I scraped the insulation off the trace and flowed the solder to the trace. I then check the nearby joints with the meter to make sure its connecting, all seem fine.
                                      • rhomanski
                                        nowhere man
                                        • 5157
                                        • U S of A
                                        I've never owned a Yamaha, but I have read a lot of people griping about their crappy soldering. You probably flexed the board and made the bad solder worse. You could just reflow everything you can around the relays.
                                        • Baste
                                          MBR3045CT and SR3045LCT Schottky diode testing help.
                                          by Baste
                                          Hello experts,
                                          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                                          Aneng ST182 Meter.
                                          Diode mode.
                                          MBR3045CT:
                                          Diode mode
                                          Pin 2-1 - 0.150v
                                          Pin 2-3 - 0.150v ...
                                          10-21-2025, 06:14 AM
                                        • debidoobs
                                          Yamaha delay D1500, zener diode broken with no marking
                                          by debidoobs
                                          im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                                          Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                                          04-24-2024, 09:01 AM
                                        • iyas132
                                          Corsair RM 750 blown schottky diode near ES1DF
                                          by iyas132
                                          Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                                          Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                                          My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                                          Can anyone help me identify the component...
                                          12-30-2024, 01:34 AM
                                        • budwich
                                          ESD Diode on HDMI output of Yamaha a1050 RCVR
                                          by budwich
                                          I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
                                          I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
                                          09-11-2023, 12:21 PM
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
