Replace main relay in Amp
  • techfixit
    • Feb 2014
    • 44
    • Ireland
    Hi, I have an unknown brand amp that when i first power on the main relay keeps clicking for about a minute or so afterwards. I've checked all solder points and everything seems to be in order so i'm left with the relay itself.
    I'd like to replace it but the relay in question is no longer in production. Can someone suggest a replacement for an OMI-SS-212DM? I'd prefer to purchase it from an irish or uk seller if possible
    Thanks in advance
  • R_J
    • 9520
    Re: Replace main relay in Amp
    It sound more likely that the supply voltage for the relay is low causing the relay to droping out. or maybe a low standby voltage causing the drive to turn on and off
    • petehall347
      • Jan 2015
      • 4424
      • United Kingdom
      sounds like a bad relay driver to me . or bad timing cap if it has one . or possibly ac riding on the dc supply .
      need to see good pics and schematic to proceed further .
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Perhaps this is the same relay https://wellgainelectronics.com/pcb-...-ss-212dm.html
        • techfixit
          • Feb 2014
          • 44
          • Ireland
          I'll post some pics of the front/back of the board tomorrow. The relay only acts funny for about 10-30 seconds after powering on the amp then it works perfectly fine until the power is switched off and back on again.
          • techfixit
            • Feb 2014
            • 44
            • Ireland
            I've attached some pictures of the board. I tested the 3 diodes close to the relay in diode mode and the results show
            1: .527 leads reversed 0
            2: .527 leads reversed 0
            3: .140 leads reversed .140
            Could a bad diode be the cause of my problem?
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Either the relay contacts are going bad or the voltage that is on the coil is fluctuating at start up. Once you find out what the voltage is doing on the coil of the relay is doing at start up you will know which one to investigate.
                That is speakers protection relay.
                The two caps (220uF/25v, 47uF/25v) and and the 3 transistors and diodes right below the relay as shown in your pictures are probably for the DC detection/relay drive circuit.
                So you the circuit may have detect DC at the output of the amplifier or there is bad parts such as those two caps are bad.
                Make and model of the unit?
                • petehall347
                  • Jan 2015
                  • 4424
                  • United Kingdom
                  monitor the dc voltages where the emitter resistors join together whilst relay is playing up .
                  emitter resistors are the big white ones next to the output transistors .
                  • techfixit
                    • Feb 2014
                    • 44
                    • Ireland
                    On budm's advice i tested the 2 diodes and 3 transistors near the relay. I discovered that the 47uF/25v capacitor was showing no value in either direction when i tested it with my esr meter. I replaced that diode and now the relay is switching perfectly without any issue
                    • petehall347
                      • Jan 2015
                      • 4424
                      • United Kingdom
                      might have been the timing cap .. hard to say without diagram ..
                      well done fixing it ..
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Originally posted by techfixit
                        On budm's advice i tested the 2 diodes and 3 transistors near the relay. I discovered that the 47uF/25v diode was showing no value in either direction when i tested it with my esr meter. I replaced that diode and now the relay is switching perfectly without any issue
                        So the 47uF/25V is a capacitor not a diode. A esr meter is for capacitors.
                        Glad you got it fixed.
                          Thanks for the follow-up on the repair.
                          • techfixit
                            • Feb 2014
                            • 44
                            • Ireland
                            Apologies i meant Capacitor
                            • techfixit
                              • Feb 2014
                              • 44
                              • Ireland
                              Promethean AV-30164
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                No problem just wanted to make sure you understood.
                                • cheeky2
                                  by cheeky2
                                  05-25-2024, 03:27 AM
                                • valvashon
                                  Repair Success! Middle Atlantic UPS2200R-IP
                                  by valvashon
                                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                  02-06-2024, 12:54 PM
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
                                • JSin21
                                  Compatibility of main boards between different variations of samsung MU6100
                                  by JSin21
                                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                  11-27-2023, 04:54 AM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
