Harman Kardon AVR1700 not powering up
  • tibimakai
    • Jan 2012
    • 3680
    Re: Harman Kardon AVR1700 not powering up
    I have swapped, with another one from the same board. I don't have a spare one.
    • tibimakai
      • Jan 2012
      • 3680
      The VCC supply, why is oscillating?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4978
        • New Zealand
        #43
        Which did you swap? You may have swapped with another faulty one, if it was connected to the other IC which blew.
        Did you try replacing C918? If it is bad, the VCC supply for IC91 won't hold up under load when the IC tries to start up.
        -David VanHorn
        • tibimakai
          • Jan 2012
          • 3680
          I have swapped it with PC94.
          I have replaced that capacitor right now and there is no change.
          What kind of voltage should I have at pins 4 and 5, of the IC?
          I'm getting around .200V. If I remember correctly, I used to get here 324V.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4978
            • New Zealand
            #45
            PC94 connects directly to IC92 and if IC92 blew up, there's a high chance PC94 was also damaged. So you may have swapped two bad optoisolators with each other. Check them with a test circuit, if they're bad, buy new ones. I wouldn't swap them with the others in case they are faulty and cause more damage elsewhere.
            That's odd about the voltage going down. Do you still have ~324V on the primary capacitors? Or has it also gone down to 200V?
            -David VanHorn
            • tibimakai
              • Jan 2012
              • 3680
              I have tested three optos: PC92, PC94 and PC95.
              Used a power supply and a resistor. As I increase the voltage, the resistance decreases.
              The 325V is still there, at the main capacitors.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4978
                • New Zealand
                #47
                What's the voltage across C902?
                -David VanHorn
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4978
                  • New Zealand
                  #48
                  Can we get some more photos of the PSU in its current state?
                  -David VanHorn
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I will take some pictures and measure that voltage, tomorrow.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      At C902, I have 326.3V.
                      Pictures are not the best, taken inside with phone.
                      In some spots looks messy, because I have tried removing, that white foam thing.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        What should we check next?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Anybody has any more ideas?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4978
                            • New Zealand
                            #53
                            It's very odd.
                            What voltage do you get on the diode side of the PC92 optocoupler? Both pins.
                            Where did you get IC91 replacement? Do you have another to try?
                            -David VanHorn
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Almost nothing. .001-.002V
                              On the primary side, with min/max I have measured 3V.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4978
                                • New Zealand
                                #55
                                I've been re-reading the thread. I notice this.
                                Originally posted by tibimakai
                                There is 253 Ohm, between D921 cathode and ground
                                I am suspicious of this value. I would have thought it would be something higher than that. Maybe there is a bad part on that rail somewhere. Can you start lifting parts that go across that rail to ground and see where the resistance changes? I wonder if something is a bit leaky. Maybe a capacitor, or the shunt regulator.
                                Or D921 itself is leaky. It could be that on test with low current it's OK, but when it sees the full load of the power supply, it's effectively a short. If you have something you can swap it with, I'd try that too.
                                From the schematic, there's nothing to suggest to me that the resistance to ground from that rail should be that low.
                                Also I find this odd. Unless you are running at 230v line voltage, the voltage at C902 should be 160v DC or so. According to the schematic, it's powered from a full-wave rectifier (D901\D902) straight from the AC, so it doesn't have anything to do with the voltage doubler of DB91\C903\C901
                                -David VanHorn
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  This time, I could not find that low resistance at D921. I don't know, how did I measure that resistance that time.
                                  I did something stupid, twice. I have discharged the capacitor C902, with two screwdrivers and blew two diodes D901 and D902. I need to buy more diodes, to be able to continue.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Diodes are in.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4978
                                      • New Zealand
                                      #58
                                      Just to confirm, IC91 was one of the ones which blew up, originally, right?
                                      Can you try disconnecting: J931, J914\J906 (probably the board only has one of these) and J955?
                                      Then see if there is 5v at D921 Cathode.
                                      If that goes nowhere, check if there is anything coming out of TF91 Pin 3\R932 and getting to D911's Anode.
                                      -David VanHorn
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Yes, IC91 it was one of the original blown one. I have replaced it again later one, because it was shorted again.
                                        I have removed those jumpers and there is no 5V. Some milivolt variation only.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4978
                                          • New Zealand
                                          #60
                                          Have you replaced IC91 twice now?
                                          If so, it could be that a bad snubber network keeps destroying the IC.
                                          Remove D910, C911, check that the resistance of R979, R980, R981, R982 in parallel is exactly 470k divided by 4, ie: 117.5k - If it's off, one of those resistors is bad. Replace the lot.
                                          Replace with brand new parts, D910 and C911 (note: 1kV part), and of course, IC91 again.
                                          D914 could also be suspicious, and if bad would cause IC91 to be damaged. Even if it tests fine out of circuit, it might be intermittently failing. Likely worth it to replace it as well.
                                          -David VanHorn
