Fisher RS-1056: No Longer Powering Up
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Hello!
    Went into my Fisher RS-1056 stereo receiver to troubleshoot the damaged meter...
    annnnnnnnnnnnnnnnnnd in the process while the unit was powered up(trying to move meter cover to get at actual meter wires) I touched the cover to one of the transistor's heatsinks. Unit shut down. Took cover off. Unit restarted. Touched cover back. Unit shut down. Repeated said process 1 more time(trying to figure out what's going on) and all of a sudden the unit dies and will not restart. Main transformer is good. On the main power board, there is the proper voltage on all pins EXCEPT for pins 3, 4, and 5. Tuner is totally dead. No voltage leading to resistor R01. Ditto for resistors R04 and R05. All fuses are good and the audio transistors are getting power.
    I'm stumped. Please help.
    Thanks.
    Schematic: https://www.badcaps.net/forum/attach...1&d=1484447932
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Fisher RS-1056: No Longer Powering Up
    Hello??
    sigpic
    • madan1
      • Nov 2016
      • 722
      can you post some pics of the unit, PSBs, point the parts which touched, the pins that do not read good... etc. .. not everyone is familiar with that particular unit and the schematics need time which not everyone is willing to invest, but the visual aid will work for most people familiar with electrocics
      • petehall347
        • Jan 2015
        • 4440
        first check all fuses ...if any blown report back before replacing any .
        if all fuses test good with a multi-meter carefully get all power supply voltages . report back with a list of readings .
        example ..
        pin 1 ..12.41v ...
        if negative voltage is read then write like this -21.1v
        use chassis as ground for black meter probe .
        edit ......
        ok i bothered to read the first post ..
        get ac voltages at pins 1 and 2 .. power supply .
        ..i bet you shorted a regulated transistor and blew one of those 1 amp fuses or burned a trace on the board . may have also blown a transistor or 2 .
        if dont see any ac voltages at pins 1 and 2 . check voltages transformer side of the fuses that feed pins 1 and 2 . ..if no voltages then turn power off and ohm out that winding on transformer .
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          ok... popped the fuses. now to find some 1A fuses.
          sigpic
          • petehall347
            • Jan 2015
            • 4440
            make sure the regulator transistor isnt shorted first ..q1 .
            also test the zener diode d05 .
            might be ok because if i am right you shorted q1 collector to ground and the fuses caught the main strike .
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              I somehow shorted pins 3 and 4 or 4 and 5 together. That must have been what killed the fuses.
              sigpic
              • petehall347
                • Jan 2015
                • 4440
                deffo test that transistor then .. if it shorted c to e and you power it up the circuits it supplies will see 19v instead of 12 ...
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  hmm ok
                  sigpic
                  • petehall347
                    • Jan 2015
                    • 4440
                    just trying to save you fuses and more damage ...
                    hopefully the semiconductors survived . if not just upgrade them .
                    • Drack
                      Yup it's me
                      • Nov 2016
                      • 297
                      • Venezuela
                      Any news?
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        Nope. Fisher makes it dang near impossible to check the diodes on that PSU board.
                        sigpic
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          can you use a dim bulb tester in circuit on one of these to protect the fuses and see if theres a short?
                            Can we see the pictures of the board we requested?
                            You can test the diode on that power supply board without removing them for now.
                            • valvashon
                              Repair Success! Middle Atlantic UPS2200R-IP
                              by valvashon
                              Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                              Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                              02-06-2024, 12:54 PM
                            • ngml
                              Repair of an LG split AC system indoor unit PCB
                              by ngml
                              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                              This indicates an error in the communication between the outdoor and the indoor unit.
                              The outdoor unit is fine, so the problem is the indoor PCB.
                              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                              Does anybody have the schematics of this board,...
                              02-01-2025, 12:55 PM
                            • CoinCoin88
                              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                              by CoinCoin88
                              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                              09-15-2025, 03:36 AM
                            • DrDos
                              Unit runs but no speaker output kenwood KR-6030
                              by DrDos
                              I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                              09-14-2025, 09:57 PM
                            • bauto601
                              KDM 480W PSU upgrade succes! (opinions?)
                              by bauto601
                              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                              A "nice" YoungYear unit? - Badcaps
                              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                              12-26-2023, 03:05 PM
