Definitive Technology SuperCube III Component Level Repair Troubleshooting Photos
  • DumpsterFire
    • Feb 2016
    Hi Everyone,
    I'm attempting to troubleshoot my Definitive Technology Supercube III and proceed with component level repair if possible. I have not been able to find a DIY guide on this.
    I've confirmed the amp receives power indicated by the Red LED light, however I have no sound/bass coming from the amp when I attempt to unplug and plug the RCA sub cable to the LFE input (the photo I took is testing other inputs). I have a secondary sub, which I tested to eliminate that it's an sub output receiver problem.
    The board looks fairly clean except for ST tip32c and LM337LZ transistors that seems to have some brown residue around the yellow potting material (photos attached below). I have not tested the pins for voltage and wasn't sure if this would affect the LFE input for sound.
    https://cdn.badcaps-static.com/pdfs/...4cb7a47e97.pdf
    https://cdn.badcaps-static.com/pdfs/...4f0ad28f91.pdf
    Does anyone have a schematic or way to possibly confirm the voltages on the transistor.
    Thanks,
    Last edited by DumpsterFire; 02-07-2016, 02:13 PM. Reason: added additoinal information
    Re: Definitive Technology SuperCube III Component Level Repair Troubleshooting Photos
    You must remove those glues first, as you can see in the last picture, it is turning dark brown, these glues become corrosive and will eat away metal and also become conductive.
    https://www.badcaps.net/forum/showthread.php?t=34692
    • tobascovodka
      CaffinatedBacon
      • May 2016
      Hi DumpsterFire, I have the same issue as you do with my III, have you had any luck in testing?
      With so many refurbished models it shouldn't be the adhesives, it is likely a component, I will be testing voltages tomorrow but I know my caps charged on both the amp and preamp.
      I know just enough to be dangerous...
      • westernmetro
        • Apr 2014
        • usa
        I am also troubleshooting a supercube III.
        There is a 5 wire plug from the crossover system to the amp.
        I think the crossover is ok with a bad amp?
        The signal plug has one wire is a different color and 4 wires same color.
        I am thinking one (the different color) may be a common/circuit board ground and the other 4 two + and two - for low level speaker input leads for the amp.
        The amp appears to have two parallel amp circuits.
        Anyone with an electronic background who can suggest how to test leads to determine what they are?
        I would like to input low level signal to test the amp separately.
        Another different question-
        Also- this system is a 120v system.
        There appears to be a transformer coil dropping the voltage- probably to DC.
        I would also like to identify a way to see if this could have the power supply hacked to run on 12v in a motorhome. I am can do guy but have no electicsal engineering info.
        i just solder and replace things and hack them.
        Thanks, Scott
          • 31015
          any decent sub will use more than 12v - usually about 30v
          • srt1
            • Aug 2013
            • 177
            • india
            Any one have schematic of super cube 3 , mine have no power
            • khajr
              troubleshooting definitive technology prosub 60
              by khajr
              My prosub 60 is blowing fuses. I bought replacement 1.25 amp 125v/250v slo blo fuses. When I replace the fuse it blows immediately along with a loud buzzing/hum from the sub. Attached are the schematics from definitive technology. There was one bad resistor, R19, and I have replaced this with the correct 1/2watt 1ohm resistor. When I plugged the unit it that resistor pops and the fuse blows. I have also replaced the following: caps C2 and C4, the bridge rectifier D1, op amp U1D, and the power mosfets Q1 and Q7. I have also checked R18, R20, and R21 and they checkout fine (removed...
              09-26-2020, 02:11 PM
              HP Z440 Workstation E5-1620V4 Specification for Upgrade or Repair
              This specification for the HP Z440 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 Workstation boardview and Z440 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
              09-12-2024, 03:44 PM
              HP EliteDesk 800 35W G2 EliteDesk 800 i5-6500T Specification for Upgrade or Repair
              This specification for the HP EliteDesk 800 35W G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 35W G2 boardview and EliteDesk 800 35W G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-12-2024, 03:36 PM
              HP Z440 E5-1650V3 Specification for Upgrade or Repair
              This specification for the HP Z440 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 boardview and Z440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z440 is accurate, safe, error...
              09-12-2024, 03:30 PM
              HP Z440 E5-1620V3 Specification for Upgrade or Repair
