Blown resistor, cant figure out what it was.
    Re: Blown resistor, cant figure out what it was.
    Originally posted by mikay786
    Test diode like you do a transistor so only goes one way? Not tested a diode before but have done a transistor
    Can I do in circuit?
    The IC did have some blackness on the pins but that probably came off the resistor.
    ill do that now
    You can test that Diode in circuit just using Diode mode on your meter.
    The Cathode side of the Diode feeds the 680 Ohms to GND, it also feeds 8K2 Ohms resistor (another end of the resistor feed pin 21 of the IC and the peak charged capacitor.
    • mikay786
      • Aug 2014
      • 765
      diode looks ok reads 0.548v, only one way
        That is fine.
        • mikay786
          • Aug 2014
          • 765
          http://www.maplin.co.uk/p/metal-film...m-resistor-m1k
          is that ok as a replacement resister?
            It is just a generic carbon film resistor 1K 5% 1/4 W. No need for 0.6w 1% resistor.
            • mikay786
              • Aug 2014
              • 765
              I don't know the difference between the two. Maplin's is local so can just go pick that up today if it will do.
                That will work.
                • mikay786
                  • Aug 2014
                  • 765
                  Nice one budm, looks like no other damage was caused and is working as it was. I would probably have been still staring at the wrong schematic!
                  Got rid of the scratchyness by cleaning pot but still got the static at full volume when speakers are idle (no music playing) I'm thinking this is normal now as cant be heard when music is playing only when paused and at full volume. The left channel does this too but at about 50% less.
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    I'd clean switches and check the caps. I wouldn't considering it normal, it may be tolerable, but it could be better. The 40mV DC offset on the RT spkr output may be tolerable but it's not quite right. I suspect a leaky cap, not physically leaking goo but leaking DC current through it that it's supposed to block.
                    • mikay786
                      • Aug 2014
                      • 765
                      Cleaned all switches and pots so I don't think they are the cause. You are probably right about a leaky cap but there are 100s of them and its probably not worth the cost / effort to change them all.
                      Might also be because I'm running with one fuse missing at moment, have misplaced the fuse cap.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        It'd probably be in the final output amp. Have you been able to get the right schematic yet?
                        • lookimback
                          • Aug 2013
                          • 1489
                          I learned the hard way that you should always take good clear pictures before you start taking things apart. I can't tell you how many hours I spent looking for pictures on the internet when I forgot what orientation a component was in, or something blew up, or even just crumbled when trying to remove it. As a general rule, I clean up any part I'm going to remove and write down the numbers which are on it, for ICs I permanently mark the location of pin 1 with a light scratch if it isn't already marked on the board, for diodes mark the cathode location the same way, then I take pictures.
                          ------------signature starts here------------
                          • x_orange90_x
                            Sony Bravia KD-50X690E blown resistor
                            by x_orange90_x
                            I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                            The power supply is 715G8413-P01-001-0H2S...
                            07-16-2024, 06:53 AM
                          • redbaron1007
                            Arcade PSU blown resistor ID
                            by redbaron1007
                            I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                            01-06-2023, 04:13 PM
                          • youpla
                            PowerColor rx 5700xt dual fan : current sense resistor
                            by youpla
                            I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
                            The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
                            The card wasn’t displaying anything after this fix.
                            When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
                            I tried to resolder it with a hot air station, but the resistor wouldn’t...
                            Yesterday, 07:52 AM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • labello
                            Honda XL 600 LM 1985-1989 PD04,Resistor blown up and losted
                            by labello
                            Hi guys a friend of mine give me this old counter it's for Honda XL 600 LM 1985-1989 PD04.
                            He opened it and found a resistor that was blown up. Then he lost it. I knowing it's not easy to fix it, but I just guess (maybe we can) thank you so much...
                            09-27-2023, 02:46 AM
