Harman/Kardon Onyx Bluetooth Speaker - No Power
  • caphair
    • Nov 2011
    • 1249
    #121
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    Update:
    Replaced ic charger and the diode and instant 3.20v on output of the ic charger and at battery. Kept measuring and voltage was slowly increasing
    That ic was the hardest thing I've ever replaced! Used hot air but still wasn't easy had to apply kapton tape around the near by plastic connectors. Took me a bit but finally got it.
    I want to thank you guys tremendously for your help/input. Learned a lot on this one!
    • Agent24
      I see dead caps
      • Oct 2007
      • 4961
      • New Zealand
      #122
      Good to hear
      SMD parts are hard at first but once you get the technique they're not so bad. I would probably have used a drag soldering method to install the new chip. I find with SMD a big part is good flux and very little solder.
      -David VanHorn
      • caphair
        • Nov 2011
        • 1249
        #123
        Left it charging and haven't been home yet for the final declaration that it's 100% fixed lol
        What I did was removed old ic with hot air and flux then cleaned and added the tiniest bit of fresh solder on the board contacts, added flux and basically reflowed new ic with hot air. It had a ground plate for heat dissipation underneath so realized hot air would be best method.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4961
          • New Zealand
          #124
          Good point, I didn't think about the grounding\heatsink pad. Sounds like what you did was the best way then.
          -David VanHorn
          • caphair
            • Nov 2011
            • 1249
            #125
            Thanks man.
            So I left this thing charging for three hours. Came home and the power led is still flashing which means low battery/charging. Figured it'd be a solid light by now.
            Unplugged charger and it powered on with the battery, so I guess it's charging but takes a while?
            I hope there isn't a new issue like the full battery indicator faulty or something lol
            • Agent24
              I see dead caps
              • Oct 2007
              • 4961
              • New Zealand
              #126
              How long did it take to charge before?
              Is this with the same battery which was measuring 0v before? If it is, perhaps you need a new battery.
              You could try putting an ammeter in series with the battery and see what the charge current is.
              -David VanHorn
              • caphair
                • Nov 2011
                • 1249
                #127
                Yes same battery. Before it'd take anywhere from 2-4 hours I believe.
                I'll leave it plugged in overnight and see what happens.
                I'll run an ammeter through it tomorrow. What should I be looking for?
                One thing I noticed is upon first power up with charger disconnected the speaker turns on then quickly shuts off. A few seconds later it powers on fine.
                Manual says quick flash means low battery and slow flash means charging.
                It's only doing a slow flash when charger plugged in or disconnected.
                • fzabkar
                  • Mar 2009
                  • 772
                  Your battery is rated at 2600mAH. My previous calculations suggest that the precharge current for a flat battery is 160mA, the fast charge current is 800mA, and the pre-termination current is 80mA. This means that the charge time for a dead flat battery would be in excess of 3 hours (2600mAH / 800mA = 3.25 hours).
                  • caphair
                    • Nov 2011
                    • 1249
                    #129
                    Ok I measured the battery and it has 4.2v on it. So is there something wrong with whatever tells the power led the battery is full?
                    I wonder if it has anything to do with the original problem and the smd cap I replaced because the "power led" line I traced back to c309 which the other end connects to c318 which connects to c317 which goes to the base of q301
                    Or that could just be for power on led not charge flash. Not sure what to look for next in terms of this
                    I also noticed power buttonA has 4.1v and power buttonB has 0v even when powered on but in original fault the voltage to B would go high after pressing A. Not sure if related or has any meaning to current issue?
                    • caphair
                      • Nov 2011
                      • 1249
                      #130
                      Scratch that about c309 I was accidentally tracing the grounds to those other components.
                      • fzabkar
                        • Mar 2009
                        • 772
                        I would measure the voltage at the thermistor and the voltage on the ISET resistor. That should tell us the temperature and the charging current. Charging should stop when the current drops to 80mA.
                        • caphair
                          • Nov 2011
                          • 1249
                          #132
                          ISET has .31v and voltage at thermistor is .52v
                          Also battery is 4.18v does it have to reach 4.2v to stop or close enough? Because I noticed it keeps fluctuating between 4.18 and 4.17v
                          • fzabkar
                            • Mar 2009
                            • 772
                            The thermistor voltage corresponds to a resistance of 10.4K, which in turn corresponds to a temperature of around 25C.
                            When the battery voltage reaches 4.20V (or near enough), the charger should go into constant voltage mode and the battery current should then gradually decline until it hits the pre-term setting. IIUC, an ISET voltage of 0.31V corresponds to a charging current of 102mA. That's higher than the pre-term setting of 82mA. AIUI this explains why the battery never stops charging.
                            ISTM that the battery is old and tired, or maybe it was damaged by overcharging or deep discharge. I would run the speaker on battery power and see how long the battery lasts before it goes flat. If you get reasonable play time out of the battery, then you might be able to extend its useful life by increasing the pre-term current to 100mA, say. However, you would need to modify a resistor value. That said, I don't know if it would safe to muck about with a sick lithium battery.
                            • caphair
                              • Nov 2011
                              • 1249
                              #134
                              Awesome, curious how you arrived at 102ma?
                              Also why does the power led slow flash even with charger disconnected if a slow flash means charging, it never fast flashes to indicate low battery either like it's supposed to.
                              • fzabkar
                                • Mar 2009
                                • 772
                                The ISET resistor configures the fast charge current at 820mA. AIUI, the ISET voltage is 2.5V when the IC is fast charging. Therefore a voltage of 0.31V would correspond to a charging current of ...
                                (0.31V / 2.5V) x 820mA = 102mA
                                I could be wrong, but that's how I interpret the datasheet.
                                I don't understand the behaviour of the power LED. That would be driven by the Bluetooth module. ISTM that the module may not be sensing the battery correctly. Perhaps you should check the module's Vcc and BAT pins. I would also measure the voltages at the BAT54C dual diode.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  #136
                                  I'll take those measurements when I get a chance.
                                  I'm confused where you're getting some numbers like the 2.5v? Also are you using basic ohms law or variations of it?
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4961
                                    • New Zealand
                                    #137
                                    As far as I know, the formula is in the datasheet, it's specific to that charger IC itself, regarding the charge currents.
                                    -David VanHorn
                                    • fzabkar
                                      • Mar 2009
                                      • 772
                                      Oops, I goofed.
                                      I believe the actual current is 0.31V / 1.5V x ISET = 0.21 x 820mA = 170mA.
                                      That's slightly higher than the precharge current. I'm not sure what's going on now. :-(
                                      I'm using the functional block diagram in section 9.2 as my guide.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        #139
                                        Do you think that's relative to the flashing power led? I mean even at 4.1v with charger disconnected it id imagine it would be solid not flashing no?
                                        • caphair
                                          • Nov 2011
                                          • 1249
                                          #140
                                          VDD - 3.25v (pin 13) and 1.8v (pin 15) also I measure 3.23v on pin 14 which USB power according to the data sheet. Which is tied in from VDD according to Datasheet.
                                          VDD_Bat - 3.25v
                                          Both LED pins on module fluctuate voltages from 1 - .38v which is responsible for the flashing.
                                          On V_Chg I measure 0v Datasheet says operating voltage 4.5v but I'm guessing that's if the Bluetooth module is being used as a battery charger? But we know this speaker has its own charge ic.
                                          BAT54C (pin 3 common cathode)
                                          with charger connected I get:
                                          4.67v pin 1
                                          4.74v pin 3
                                          4.18v pin 2
                                          Disconnected:
                                          0v pin 1
                                          4.01v pin 3
                                          4.06v pin 2
