Harman/Kardon Onyx Bluetooth Speaker - No Power
  • fzabkar
    • Mar 2009
    • 772
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    It might be worth checking whether the device identifies itself via USB. You could use a tool such as UVCView or USBDeview for this:
    http://www.nirsoft.net/utils/usb_devices_view.html
    http://download.microsoft.com/downlo...31d-436b-9281- 92cdfeae4b45/UVCView.x64.exe
    http://www.users.on.net/~fzabkar/USB...VCView.x86.exe
    • fzabkar
      • Mar 2009
      • 772
      In the absence of further information, this is my best guess as to how the circuit works:
      Code:
              U600        U701
             | step  |~6V   | battery | +4V
           |---| down  |--------| charger |-------|
           |  |converter|    | control |    |
           |   TPS54331     BQ24083 ?    |
           |               Bat/AC   |
           |               switch   |
           |         U702          |
           | D701  D702 .---------.  Q702 ?   |
           |       | boost |   _/  .-------.
       19VDC o-+--->|-+--|<---|converter|----o/ o--|battery|
              |    | 12V ? |      '-------'
              |    TPS54331
              |     U700       U300
              |    | step  |+3.3V |bluetooth| .----.
              +-------| down  |------| module |--|USB |
              |    |converter|   |     | '----'
       speakers   |      | +3.3V
          |\  |class D| .---------.
          | ||__| audio | |  AKM  |
          | || | power |--| audio |
          |/  | amps | |  chip |
                    U400
      https://cdn.badcaps-static.com/pdfs/...3b7c29533e.pdf
      • caphair
        • Nov 2011
        • 1249
        #43
        Hey guys thanks for the replies! Appreciate it. Finally home and can post part numbers of the ic's on the board. Let me know if you need any others from what I've listed:
        U702 - 3860S14B
        Q701 - CSD17307
        Q700 - P3035LS
        U701 - 24090
        U700 - 54331
        U400 - AK7742EQ
        • fzabkar
          • Mar 2009
          • 772
          BQ24090, Texas Instruments, 4.45V - 6.5V in, 4.20V out, 1.0-A Single-Input, Single-Cell Li-Ion Battery Charger:
          https://cdn.badcaps-static.com/pdfs/...609a177dad.pdf
          https://cdn.badcaps-static.com/pdfs/...557f031697.pdf
          AK7742EQ, Asahi KASEI, 24bit 2ch ADC + 24bit 4ch DAC with Audio DSP, +3.3V:
          DMP3035LSS, Diodes Inc, SINGLE P-CHANNEL ENHANCEMENT MODE MOSFET, -30V, -11A:
          CSD17307Q5A, Texas Instruments, 30V, 11A, N-Channel NexFET Power MOSFET:
          https://cdn.badcaps-static.com/pdfs/...682ed3c199.pdf
          TPS54331, Texas Instruments, 3-A, 28-V Input, Step Down DC-DC Converter With Eco-mode:
          https://cdn.badcaps-static.com/pdfs/...bc7b95556e.pdf
          Code:
               |   U600        U701          |
               |  | step  |~5V-6V | battery | +4.20V    |
               |---| down  |--------| charger |-------|    |
               |  |converter| -->  | control | -->  |    |
               |   TPS54331      BQ24090     |    |
               |               Bat/AC   |    |
               |               switch   |    |
               |         U702   DMP3035LSS  |    |
               | D701  D702 .---------.   Q700   |    |
               |       | boost |   _/  .-------.  |
           19VDC o-+-->|--+--|<---|converter|----o/ o--|battery|  |
                  |    | 12V ? |   |  '-------'  |
                  |    '---------'   |   3.6V   |
                  |    TPS54331
                  |     U700       U300
           speakers   |      | +3.3V      |
              |\  |class D| .---------.      |
              | ||__| audio | |  AKM  |      |
              | || | power |--| audio |-----------|
              |/  | amps | |  chip | <-- audio
                        U400
                       AK7742EQ
          • fzabkar
            • Mar 2009
            • 772
            I'm stumped by U702, but I'm convinced it's a boost converter. Maybe someone else can identify it. In any case I think there is enough information to locate the fault, assuming there are no errors in my layout.
            • caphair
              • Nov 2011
              • 1249
              #46
              Thanks for that! So am I just looking for voltages that should be on inputs of the ics?
              • fzabkar
                • Mar 2009
                • 772
                I'd be looking at the cathodes of D701 and D702 in battery mode (12V ??) and charger mode (18V).
                Check the load side of the 6R8 coil driven by U600. In charger mode you should see between 5V and 6V, whereas in battery mode there should be 0V.
                The load side of the 6R8 coil driven by U700 should be at +3.3V in both modes.
                Check that the bluetooth module (U300) can be detected by your PC using UVCView or USBDeview. If it shows up as a Harman Kardon device, then this would suggest that it is alive and that the MXIC flash memory chip is intact. If it detects with the product and vendor IDs of the bluetooth chip, then this would point to a checksum error in the firmware or something along those lines.
                Remember to press the power button.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5079
                  • New Zealand
                  #48
                  Package marking S14B matches the LM3478, I think this is U702.
                  -David VanHorn
                  • fzabkar
                    • Mar 2009
                    • 772
                    Thanks Agent24. I was looking for "514B". <smacks forehead>
                    BTW, TI have a part marking lookup resource:
                    http://www.ti.com/general/docs/partm...hType=partmark
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5079
                      • New Zealand
                      #50
                      I think we all hate SMD IC codes...
                      Thanks for the link. Looks very useful. Pity all the manufacturers don't do that!
                      -David VanHorn
                      • caphair
                        • Nov 2011
                        • 1249
                        #51
                        Battery mode I measure 0v both on D701 / D702 - However, if I press the power button they both measure 11.20v and the voltage slowly drops down when power button released.
                        In charger mode both D701 / D702 measure a solid 18.82v and no change whether power button pressed or not.
                        U600 6R8 measures 3.25v in charger mode regardless if power button pressed. battery mode 3.25v only when power button pressed
                        U700 6R8 measures 4.67v in charger mode regardless if power button pressed. 0v and no change when power button pressed in battery mode
                        I think you had U600/U700 mixed in your drawing bc I seem to get values you mentioned just on opposite ICs
                        PC did not detect the Bluetooth module
                        • fzabkar
                          • Mar 2009
                          • 772
                          Assuming you were holding down the power button, and assuming that +3.3V was present all the while that the USB test was being performed, then ISTM that the bluetooth module must be dead.
                          As for the supply voltages, they all seem to be where they should be. If we take the 15W power rating and compute the peak voltage required to achieve this rating in full bridge mode, we get ...
                          Power = Vrms x Vrms / Resistance = (0.707 x Vpeak) x (0.707 x Vpeak) / 4 ohms
                          So ...
                          Vpeak = sqrt( 15 x 4 x 2) = sqrt(120) = 10.95 volts
                          ... which matches your measured value of 11.2V.
                          The BQ24090 battery charger IC has an input voltage range of 4.5V - 6.5V, so your measured value of 4.67V for the step-down converter is at the lower end of the range. This makes sense since this would result in the least input-output voltage differential for the BQ24090, which in turn would result in the lowest possible power dissipation.
                          The reason that I got U700 and U600 mixed up was because I was confused by your statement in post #33 when you wrote that "I noticed the top [regulator] has voltage readings while the bottom one didn't have any". It did occur to me that it would make more sense for the 3.3V regulator to be near the bluetooth and AKM chips while the 4.67V regulator should be nearer the battery charge controller. Anyway thanks for clearing that up.
                          As for the power button, I'm thinking that it may behave like a latching "soft" on/off toggle. The following explanation is my guess as to how it works. It may be completely wrong.
                          When you hold down the button, Q700 is switched on, causing U702 (+11V) and U700 (+3.3V) to come alive. The bluetooth controller (U300) then wakes up, sees that the power button is closed, and then shunts the button with a transistor switch. This transistor keeps the power switched on when the button is released. A dead bluetooth controller would explain why you can keep the regulators alive by holding down the button and why they switch off when you release it. In fact Bob Parker's ESR meter uses exactly this type of latching arrangement. See the instructions in the DSE kit for a circuit diagram:
                          • caphair
                            • Nov 2011
                            • 1249
                            #53
                            Thanks so much for your help it was appreciated. Would I be able to find a replacement Bluetooth controller or is this a proprietary part that only the company would have?
                            • fzabkar
                              • Mar 2009
                              • 772
                              First let me confess that I have no experience with Bluetooth, nor do I have any Bluetooth devices, so others may be better placed to advise you. That said, your photo isn't clear, but AFAICT the Bluetooth module consists of a receiver IC and a serial (?) flash memory IC on a daughter PCB. It would help to see what is under the sticker, but I expect that the module may be available as a generic unit for OEMs to adapt for their own use. You would then need to transfer the firmware in the MXIC chip from your Harman Kardon device to the replacement module. Depending on the manufacturer's support for the module, there may be a software tool for uploading firmware to a blank module.
                              There is one other possibility that comes to mind. It could be that the module is shutting down in response to an external fault. One way to test for this would be to disable the MXIC chip. This will invalidate the OEM firmware and cause the Bluetooth chip to revert to kernel mode. The chip should then identify itself via USB and prepare itself to receive a firmware upload. If the chip is still unresponsive, then this would confirm that the fault is localised within the module.
                              Still another check would be to test for the presence of a standby supply at one or more of the module's pins, without pressing the power button. If my analysis is correct, then I would not expect to find a standby voltage.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5079
                                • New Zealand
                                #55
                                I know less about Bluetooth than you, I expect...
                                All I can think of are the obvious things... is power actually getting to the module? Is the module's clock crystal working? If there are any external reset or enable lines to the module, are they OK?
                                caphair, can you give us a closer photo of the Bluetooth module to show it better? Maybe there are components on there you could check. Knowing the code silkscreened on its board might also help, since the sticker codes don't come back to anything.
                                Take the sticker off and find the IC code underneath, maybe a datasheet could be found for that. Maybe...
                                -David VanHorn
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  #56
                                  Here's a pic hope it helps. I'm curious to get it going if possible. This thing was $300 brand new. I'm wondering, would the company give out the schematic if I contacted them or something they don't make public?
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5079
                                    • New Zealand
                                    #57
                                    Looks like it's a BM150 from Sunitec: http://www.sunitec.com.tw/product-it...avi=52&uid=123
                                    Found a BOM on FCC website: https://cdn.badcaps-static.com/pdfs/...667a2bc897.pdf
                                    Also found datasheet for the BM150 here: https://cdn.badcaps-static.com/pdfs/...a02ece2fe5.pdf (Page 4 of this document shows the module's pinout)
                                    Datasheet for Bluetooth chip BC57E687C here: https://cdn.badcaps-static.com/pdfs/...086079d3a0.pdf
                                    You better hope it's an issue with the external Reset line or something, as I doubt troubleshooting that module would be easy, nor would replacing the chip, unless you can do BGA rework. And it doesn't look like new modules are easy to get either.
                                    If you asked nicely and were extremely lucky... you are still unlikely to get it
                                    -David VanHorn
                                    • fzabkar
                                      • Mar 2009
                                      • 772
                                      I found one more document that may or may not be of use.
                                      Here is the FCC page for "a 2.0 Speakers System" manufactured by Guoguang Electric Co.,Ltd (FCC ID: 2AAP8HSBT67):
                                      https://apps.fcc.gov/oetcf/eas/repor...id=2AAP8HSBT67
                                      There are two schematics:
                                      https://apps.fcc.gov/eas/GetApplicat...tml?id=2141465
                                      https://apps.fcc.gov/eas/GetApplicat...tml?id=2141466
                                      One of the schematics shows the internal circuit diagram of the Bluetooth module, plus it shows the pinout of the PCB. The module's part number is BM153 rather than the Onyx's BM150, but I believe that they are the same module. According to the Rockbox datasheet, BM153 is the order number for the 3.3V version of the BM150. Also, Sunitec's web site states that the BM150 is "factory configurable to either 1.8V or 3.3V supply". Make sure you order the 3.3V version rather than the 1.8V.
                                      I don't know if these modules need to be reprogrammed, but I would be prepared for that possibility. In fact ISTM that the Programmable Input/Output Lines would need to be configured by each appliance manufacturer to correspond to their specific button and LED functions.
                                      BTW, be very careful when buying your module. I found other modules that look very similar but have slightly different pinouts (pins 53-60 are different).
                                      The following examples are similar but NOT identical to the BM150:
                                      https://cdn.badcaps-static.com/pdfs/...731f5c4cff.pdf
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        Curiosity led me to this Onyx Studio FCC database page:
                                        https://apps.fcc.gov/oetcf/eas/repor...c_id=APIONYXST
                                        Underneath the heatsink are two TI TPA3116D2 power amps.
                                        TPA3116D2EVM Evaluation Module
                                        https://cdn.badcaps-static.com/pdfs/...19c7d8b85a.pdf
                                        TPA3116D2, 50W Filter-Free Class-D Stereo Amplifier with AM Avoidance:
                                        The following thread discusses the Harman Kardon ONE device:
                                        http://www.oluvsgadgets.net/2015/06/...mware-fix.html
                                        The HK ONE uses the same BM150 module (see the internal photos):
                                        https://apps.fcc.gov/oetcf/eas/repor...cc_id=APIHKONE
                                        Just FYI, the following links constitute a firmware update for the HK ONE. I'm guessing that a similar procedure using the same (?) software but different payload would apply to the ONYX STUDIO.
                                        Uploaded firmware 1.4.1, CSR BlueSuite and installation manual:
                                        http://putit.ru/download/MjMxNjU3OTYyMTUzOA==
                                        http://my-files.ru/d58uuf.JBL_CHARGE_2.7z
                                        http://higgs.rghost.ru/download/89c8...BL_CHARGE_2.7z
                                        • caphair
                                          • Nov 2011
                                          • 1249
                                          #60
                                          Thanks guy! How do I go about trying the external reset first? As it seems the easiest
