Fender PD-250 Passport going into protect mode when running off 500 Watt Inverter
  • tfs2015
    • Feb 2015
    • 135
    Dear members in the previous thread that I started, I posted about my Fender PD-250 Passport PA System. All the previous problems are fixed on it now, but now I have new problem that keeps coming up with it. I was running it off of a 500 Watt Power Inverter during a parade this past week. Anytime I would turn the output volume up to high it would go into PROTECT mode. Then I would have to shut it off wait a few minutes and then turn it back on. It would run for a little while and then go into PROTECT mode again. At home plugged into a normal household outlet it can run all day long with no problems at all. Should I turn the LEFT and RIGHT BIAS down on the power amp board so that it does not draw as much current? The specs on the inverter are:
    • Model: EN500 Energizer
    • Input: 12VDC 54A
    • Output: 115VAC 60Hz 4.4A 500W
    Tom
    Computer and Small electronics troubleshooting and repair
    Re: Fender PD-250 Passport going into protect mode when running off 500 Watt Inverter
    The Bias setting is set when the unit is in idling mode (no signal input), when the unit is fed with signal, then the bias in the output will vary with the amount of signal for the required out put to drive the speakers, lowing the bias current will not reduce the current draw when the amps are demanded to put out the required power. Less drive to the speakers = less current draw by the amplifiers = less current draw from the power supply = less current draw through the Inverter. 500W Inverter (it claims 500W continuous) does not look to be enough head room when high power are demanded by the amplifiers.
    Since it runs fine all day on AC SINE WAVE with no problem, then it has to be due to the step sine wave inverter problem.
    Did you run the same setup before the repair without any problem.
    • japlytic
      • Oct 2005
      • 2086
      I have read in a Jaycar catalog that one of the things which are best for pure sinewave inverters is mains powered PA equipment.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8146
        Probably you run out of juice from the cheap modified sine wave inverter. Some things don't run that great on modified sine wave inverters as they consume more power on that modified sine wave than on a true sine wave. There could be also a small problem on how you connected the inverter to the battery. Like is the inverter close to the battery or are the battery cables a half mile long etc.
        I really don't think it is the PA's fault.
          Not sure if this true or not.
          http://www.themagiccafe.com/forums/v...44221&forum=11
          • x_orange90_x
            Vizio E55-E1 bad backlights or bad inverter?
            by x_orange90_x
            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
            I don't know how exactly to test the inverter itself. Is it...
            01-29-2025, 09:24 PM
          • CapLeaker
            Fender Acoustasonic 100 / 150 repair
            by CapLeaker
            Got this Fender Acoustasonic 100 in for repair.
            Complaint: Supposedly does strange things, the instrument channel goes pop, crackle, no audio then all of the sudden works again?
            Well... Open this 15 year old sucker up and I am greeted with leaking capacitors. I changed these out, cleaned the board and no audio out of the instrument channel, but some weirdness is gone and sounds now clean on the second channel. So I put my laptop on there and cranked the music full tilt. Sure enough, it goes crackle and pop with the bass in rhythm. Put my signal geni on it and sure...
            07-26-2025, 02:06 PM
          • Gentian
            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
            by Gentian
            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
            03-06-2023, 07:07 AM
          • valvashon
            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
            by valvashon
            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
            01-04-2024, 01:44 PM
          • eccerr0r
            A modified sine wave inverter + a grid tie inverter?
            by eccerr0r
            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
            Next thing is trying to charge the batteries using solar power, but that's another issue ...
            08-31-2023, 09:14 PM
