Rocnation Audio Jack
  • JJR
    • Mar 2013
    • 171
    Does any know the wiring for a Skullcandy Roc Nation Aviator headphone audio jack?
    It's a TRRS 4 panel jack.
    I don't know which colour to solder to which panel.
    The colours I have are:
    Red
    Red/green
    green
    copper
    Any help will be appreciated.
    Dave
    • 31111
    Re: Rocnation Audio Jack
    i suspect red and red/green is one side with red being the +
    and the green and copper is the other side with green being the +
    once you tin the ends, you can hold them on the new plug to test the theory.
    btw, what the hell is a "TRRS 4 panel jack."
    • JJR
      • Mar 2013
      • 171
      The 3.5mm 1/8" audio jack/connector has 4 parts instead of 3.
      T=tip
      R=ring
      R=ring (2)
      S=sleeve
      Normal TRS jacks have just 1 ring.
        • 31111
        4pole jack - like on a cellfone?
        what uses that?
        or is that what your doing?
          MAC uses them too of course.
          http://appleinsider.com/articles/09/...ew_audio_jacks
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            There are two standards in use for headsets with a mic used on mobile and game consoles.
            OMTP: Used by old Nokia (and also Lumia starting from the 2nd gen[16]), old Samsung (2012 Chromebooks), old Sony Ericsson (2010 and 2011 Xperias), old Wiko (2012-), Sony (PlayStation Vita), OnePlus One
            T = L
            R = R
            R = Mic
            S = Common
            CTIA: Used by Apple, HTC, latest Nokia, latest Samsung, latest Wiko (2013+), Jolla, Sony (Dualshock 4), Microsoft (including Surface, Lumia, and XboxOne controller with chat adapter) most Android phones
            T = L
            R = R
            R = Common
            S = Mic
            Concerning your wire colors bare copper is common, red is probably right and you'll need to test out the others to determine which is left and and which is mic. A guess would be that green is left and red-green is mic.
              It will be easy to tell which wires are for the speakers in the headphone left and right, the Ohm meter will show the resistnce of the speaker which can be from 8 ~32 Ohms, the MIC will be much higher resistance. You can also hear the pop on the speaker when you use beeper mode on the meter when you touch/un-touch the speaker wire with the meter.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                ^Exactly.
                  • 31111
                  didnt know it had a mic - poster never said that.
                  just looked them up, amazing what some people will pay for a pair of can's with the right label on them!!!
                  • JJR
                    • Mar 2013
                    • 171
                    Thanks Guys, I will give it a go when I get back to work on Monday
                    • JJR
                      • Mar 2013
                      • 171
                      WHAT A NIGHTMARE!!
                      Now, I can solder, I repair DC jacks etc, it's easy after the first time.
                      But these headphones are wrecking my head.
                      It should be really easy, I have tinned the new jack in all 4 places, no problem.
                      I've stripped the cable to expose all 4 wires.
                      I've cleaned the end of each wire.
                      I've fluxed the end of each wire.
                      But I cannot tin the wires and I cannot solder them to the jack.
                      It just does not take.
                      It's driving me mad, I've walked away twice to stop me throwing it through the window.
                      What on earth am I doing wrong?
                      • JJR
                        • Mar 2013
                        • 171
                        Sorry Guys, I don't expect an answer here, I'm just blowing off steam
                          • 31111
                          lol
                          to tin enamel/plastic-coated wire:
                          twist them together, dont add flux.
                          put a big blob of solder on the tip of your iron - preferably lead-free at 300-320' temp setting.
                          hold the twisted wire end in the blob.
                          after a few seconds it will burn the coating off and take to the copper.
                          • JJR
                            • Mar 2013
                            • 171
                            Hi stj
                            No twisting 2 wires together, soldering straight to jack connections.
                            I used 2 methods to remove coating: 1st - hot solder as you suggest, 2nd - FIRE (lighter).
                            Tried tinning with & without flux.
                            • JJR
                              • Mar 2013
                              • 171
                              Cable getting shorter lol!
                                • 31111
                                what iron have you got?
                                and what solder?
                                • JJR
                                  • Mar 2013
                                  • 171
                                  Atten 8568
                                  Multicore leaded 0.5mm Ersin 309
                                  The above has never let me down.
                                  BUT, we have lift off, the only thing I did differently was to use some cheapo lead-free that has been lurking in my toolbox for 5 years.
                                  Me no understand
                                    • 31111
                                    lead-free melts at a higher temperature, so the flux is also designed to work higher without just burning.
                                    btw, the best solder i have found so-far in MANY years is Multicomp Kristall-505
                                    Farnell sells it.
                                    set your iron to 310'
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      aspirin. no joke. put the wire and the tip of the iron to a tablet of aspirin. dont breath the smoke!
                                      Follow the white rabbit.
                                        • 31111
                                        that can damage the coating on the iron tip.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:18 AM
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:33 AM
                                        • kurtspirit
                                          A2141 Jack audio issue
                                          by kurtspirit
                                          Good morning,
                                          I have a problem with a Macbook A2141 with the audio jack port. Sound only comes out from one side (left). The right one just emits a kind of crackling sound.
                                          I changed the jack ports twice to be sure that it was not caused by a defective part, but the result was the same.
                                          I have the impression that it could be an audio filter or component but I am unable to locate the affected part on the motherboard.
                                          Have you ever encountered a similar problem and can you help me find the filters, if they exist, on the map please?
                                          Thanks in advance...
                                          07-25-2024, 04:11 AM
