lm3886t
  • drdyzio
    • Apr 2014
    • 74
    lm3886t
    Hey guys,
    i got a pair of berhinger studio monitors (active) and one went pop and no sound came out of it however the other is working fine.
    i tested all parts and the circuit board the amp is on is the culprit.
    it has one of the lm3886t chips and some other guys but for some reason i thought its this sucker.
    i tried pulling it off and pulled most pads so now i gotta trace it and get cables running to where it needs to. i never managed to test anything. so dunno if this chip is the problem.
    what i wanted to do is pull it off and stick the known one that works on to test but i decided to wait and just order a new one. i didnt wanna risk braking the working monitor as its a reference for where the pins go to.
    can i test this chip somehow?
    what the speaker did after it popped was, once u powerd them up they did a sound of the ocean, like a white noise slowly pitching up. for about a second till capacitor got filled up. and then quiet. both the bass speaker and the tweeter.
    i also noticed that there were little clear plastic sheets beetween this lm3886 and another one next it and the heatsinks. i think these used to hold the paste and they never got peeled off these chips prior to them getting scewed to heatsinks.
    idk im going to take pictures and mark all points of where the traces go to and write this one up. berhinger brand stuff is normally pretty nice just made with mediocre components and are known for failing. i just wanna be able to fix them knowing that the speaker itself and the power supply is still good.
    BIG QUESTION HOW TO TEST THIS CHIP?? PLZ HELP..
    ALSO WHATS THAT NOISE!!!!???
    these monitors are my favorite possession and all i wanted to do on xmas was have a mix on the decks. and i was listening to them quietly and pop.
    i was soooo frustrated!!!
    any help would be appreciated ill update this post as soon as i get further into this.
    HAVE A MERRY XMAS AND A HAPPY NEW YEAR!!
  • drdyzio
    • Apr 2014
    • 74
    Re: lm3886t
    Ill what else could go wrong?
    • drdyzio
      • Apr 2014
      • 74
      Re: lm3886t
      oh yeah and sicne the 3886t and 4701t are both not isolated does that mean i got to isolate one with that tape i took off?
      i did plug it in and it worked ? any ideas sorry to babble.
      Much thanks
        Re: lm3886t
        If the IC mountings have insulator thermal transfer pads then you do need to put them back on.
        This bi-amp setup, one power IC for driving the tweeter and another power IC for driving the woofer. If you hear noise from both speakers (tweeter and woofer) then it will be something that is common that generates the noise and feed into to both amplifier ICs.
        • drdyzio
          • Apr 2014
          • 74
          Re: lm3886t
          yeah after a bit of reading i realized myself i need insulation on those chips. i traced the lifted pads of the 3886 to these points on this image below.
          any one know what could be the culprit on this board?
          im going to plug both in and power them up and have a poke around see what i can muster up. im gonna stick the old 3886 and solder it up to the points shown.
          then ill have a poke around. i lost the mica insulator so had to order a bunch from hong kong. bit confused never fixed an amp.
          any help will be appriciated.
          • chth96
            How Can I test PWM DM0365R?
            by chth96
            Hello
            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
            06-18-2025, 04:14 PM
          • khelane
            test active pfc power with lamp test
            by khelane
            Hello
            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
            Is there a way...
            06-03-2025, 01:00 AM
          • chronic519
            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
            by chronic519
            Hello.
            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
            Found issue with a RAM block
            Replaced, green lines gone.
            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
            Used a good card to test and same results low errors 32+.
            I am just search for some form of command to do a full test on the GPU.
            I just ran the mats command with my good GPU and passed after roughly 40 min.
            The repaired one, ran...
            05-20-2025, 07:56 PM
          • alltvrepairs
            Lg TCon test pins for screen test
            by alltvrepairs
            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
            Appreciate your help....
            06-13-2025, 06:33 AM
          • signal.quest
            Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
            by signal.quest
            I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
            I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
            09-30-2024, 11:21 PM
