Yamaha CR-640 LED mod, an filter cap source
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    does anybody know where i can get 12,000uf 50v caps for this thing?
    also, how would you do an LED mod to the dial lamps? IIRC the voltage on the bulbs is 14v.
    Follow the white rabbit.
    • 30985
    Re: Yamaha CR-640 LED mod, an filter cap source
    so what size is the cap?
    as for the led, just calculate the correct resistor size.
    http://led.linear1.org/1led.wiz
    • mariushm
      • May 2011
      • 3799
      You can buy capacitors from online stores like digikey.com , newark.com , mouser.com - all three in us.
      That capacitor is for bulk storage of energy, it doesn't have to be exactly 12000 uF, you can go just a bit lower with let's say 10000uF or you can go a bit higher. Lower capacitance could affect the amplifier at extremes, let's say when you turn the volume knob way high, but that's about all.
      The voltage rating must be at least 50v, the same as the old capacitors or more. The next voltage rating would be 63v.
      So I'd say pick any 50v/63v 10000-15000uF and you'll be fine, just check diameter and height and maybe the spacing between the leads of the capacitor (but that can be worked around if you want to)
      As for led mod ... it's simple ... formula is V = I x R
      Any led needs a resistor to limit the current going through the led so it won't burn up, so you need to figure out what resistor to use in series with the led.
      So let's say you want to use a blue led that has a forward voltage of 3v and you want to let about 10mA of current (0.01 A) flowing through the led... not too bright, not too dim.
      Therefore you have:
      Voltage - Forward Voltage LED = Current x Resistance
      14v - 3v = 0.01A x R
      => R = 11v / 0.01 = 1100 ohm
      So if you want to use a blue led and 10mA, you can use a 1000 ohm resistor or something close to this value to achieve the results.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        would this cap work?
        http://www.mouser.com/ProductDetail/...52bJszroGWs%3d
        for the LED mod im partly colorblind, it looks yellow to me, but others describe it as "a darker yellowish green" so should i use daylight white or green LEDs? i plan on keeping the original diffusers if that helps.
          • 30985
          use a high CRI white led or any coloured bits wont look right.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8126
            Here is something you might be interested for the LED conversion: Onsemi makes an 20ma LED constant current regulator NSI45020. It can do up to 45V input but it has to be DC. Works great! Other than that, you have to work with voltage dropping resistors etc.
              • 30985
              grab this:
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                ok, i removed the large filter caps and both test absolutely spot on. im just going to replace the failed lamps with incandescent lamps. screw trying to match colors i can't even see!
                  Is it fuse type lamps or Grain of Wheat type?
                  http://www.audiolabga.com/data_html/PRB-FL6.html
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    not fuse type, but not rice grain either. they are around 5mm(no calipers)
                      • 30985
                      i will look at the manual later and give good advice.
                        • 30985
                        the lamps are 14.5v 80ma and there are 8 of them.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          thanks for the info, i will order replacements and post results.
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            Well, fuck sakes. I forget about a project for three years, and the thread for 4 years. I relamped it in '17 and just now remembered this thread.
                            Final outcome.
                            https://i.imgur.com/mQzYtwh.jpg
                            All warm white LEDs with the original diffusers. Sans dialpointer, anyway.
                            Im not sure why my camera picks up the dialscale as a sky blue. It's really not, but i couldn't really describe the color... I like it whatever it is.
                              • Jul 2011
                              • 6037
                              Here is something you might be interested Onsemi makes an 20ma LED constant current regulator NSI45020.
                              Can you provide a link where you can buy them
                              When I googled it the first time I could not find any place that had any in stock
                              Never mind I found some here
                              https://www.mouser.com/ProductDetail...LmPs%2fA%3d%3d
                              I have a question is possible to use just one LED @ 5 volt with this NSI45020
                              From what I read in the data sheet it has to 1.8 volts higher than the LED or LEDs hook to it if I read the data sheet correctly
                              If this is the case then it slove a problem about a LED project that I been wanting to build for a long time
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8126
                                Looking good! I like it!!!
                                • Lvsitano
                                  Asus X532FL 3.2V at source and gate
                                  by Lvsitano
                                  I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                  First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                  I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                  First...
                                  06-26-2024, 02:13 PM
                                • sanalelevenstar
                                  Yamaha RX-V485 Wn9711 Update
                                  by sanalelevenstar
                                  Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                  I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                  I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                  12-04-2024, 04:32 AM
                                • AlexVG
                                  YAMAHA CLP-550 without of sound
                                  by AlexVG
                                  Hi.
                                  I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                                  I have replaced all green marked elements, but it gave me nothing.
                                  The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                                  But it is custom YAMAHA's chip, and I can't find any information about it.
                                  Maybe somebody came across with the same issue?
                                  Any information will be very useful. I will be very appreciated.
                                  Thank you....
                                  06-08-2025, 09:29 AM
                                • LarrySabo
                                  Samsung ProBook NP767XCM-K1CA battery connector replacment source?
                                  by LarrySabo
                                  Tonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
                                  12-04-2024, 09:10 PM
                                • tofik
                                  MOSFET equivalent K8A60DA
                                  by tofik
                                  Hello guys,
                                  I have a shorted MOSFET K8A60DA with the following characteristics:
                                  Type Designator: TK8A60DA
                                  Marking Code: K8A60DA
                                  Type of Transistor: MOSFET
                                  Type of Control Channel: N -Channel
                                  Maximum Power Dissipation (Pd): 45 W
                                  Maximum Drain-Source Voltage |Vds|: 600 V
                                  Maximum Gate-Source Voltage |Vgs|: 30 V
                                  Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                  Maximum Drain Current |Id|: 7.5 A
                                  Maximum Junction Temperature (Tj): 150 °C
                                  Total Gate Charge (Qg): 20 nC
                                  Rise Time (tr): 25 nS
                                  Drain-Source
                                  07-19-2023, 05:18 AM
