Escort Head Unit Pre-Outs
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    My 98 Escort wagon has a queer ford indash four channel AM/FM/Cassette deck. It lacks power and the speakers were trash even when new. My plan is to replace the stock speakers with like sized after market stuff. Now the big question is: Does my existing head unit have pre-outs on the rear? I'd love to add a four channel amp with just a little power. 20 watts RMS per channel would be more than enough. Can anyone answer the "pre-out question for me so I don't have to take the car apart to check?
    Mark Twain
    John Paul Jones
    Rod Serling
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Escort Head Unit Pre-Outs
    Perhaps you could use the L & R Speaker Outputs. There is a jig called an IMPEDENCE CONVERTER that would take the Lo-Ohms speaker output and convert it to Hi-Ohms output which could go straight into the LINE INPUT of the Power Amp or Equaliser. So the Fader control on the Head Unit would be set to Front and the better speakers would be connected to the Power Amp.
      • 31157
      probably not,
      they are usually made by philips or visteon btw.
      you can get adapters to feed an amp from a speaker output though.
      i used them in the past.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        I found this thing on Crutchfield. It looks cheap to me. http://www.crutchfield.com/p_1209957...iring-Kit.html
        I do have a Sony HiPower CD head unit but it needs repairs on its FM section. Water got into it from the AC vent above it while it was in my Suzuki wagon. If I got that thing fixed and installed it in the Escort it would be a fine unit for me. My Sony is the CDX-CA750X. KC has been waiting for me to ship it to him for repairs for a few years now.
        Mark Twain
        John Paul Jones
        Rod Serling
        • delaware74b
          • Apr 2009
          • 628
          JP - that install kit looks like it will work for you. Most Ford speakers are decent as the head units have no a**.
          My factory am/fm/single CD head unit in my '04 Ranger is actually built by Pioneer for Ford, complete with both Ford and Pioneer part numbers. I first replaced the head unit with a Pioneer unit and that made a huge difference in quality and power. No separate amp needed.
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            That proprietary-ness reminds me of Pontiac G6s. Ever seen those head units?
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              I think that I'll buy a new normal din head unit with four speakers and be done with it. From crutchfield the mounting kit comes for free if you buy all the other stuff.
              Mark Twain
              John Paul Jones
              Rod Serling
              • dmill89
                • Dec 2011
                • 2534
                I used to have one, they integrated the VIC (vehicle information center, trip odometers, fuel mileage, oil life monitor, etc.) into the head unit. If you ever want to replace it your options are either a half-assed aftermarket bezel adaption with the VIC readout/buttons built in (these are cheaply made and have a high failure rate, failure of this can lock up the security system and cause the vehicle not to start), or some head units that are specifically made for GM vehicles that cost $600+ and integrate all the functions that the factory head unit did (or if you just want to upgrade from the base factory head unit to the more featured ones in higher trims you can get one from the junk yard, but you may have ton pay the dealer to program it for your vehicle).
                Apparently this is the case in most of not all newer GM vehicles (having the VIC integrated into the head unit).
                My '95 Jeep Cherokee is real easy, it just has a regular DIN opening in the dash so no adaptors needed just bolt the head unit right in (it would be nice if auto manufactures went back to standard single or double DIN units, but they think they have to make them look "pretty" and integrate them into the dash).
                  • 31157
                  you can get a nice head unit with fm tuner & mp3 playback from SD card with 4 channel output for about $30 from china.
                  who needs to pay for all that mechanical crap for tape/cd these days.
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    First I'm not doing a downgrade to china in order to upgrade my car. Good luck with your line of thinking.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                      • 31157
                      good luck thinking anything isnt made in china now.
                      i just cut out the middleman & the sticker company.
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        You have a point.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                          • 31157
                          o.k.
                          take a look at this,
                          http://www.dx.com/p/ca720-2-7-lcd-sc...ck-grey-181517
                          and tell me why i should pay $150+ for the same guts with a JVC or KENWOOD badge on it!
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            That is a lot of head unit for just $38.46! They used to sell and AM/FM tape deck unit at Luskins for $19.95. They also sold a pair of 6x9 three way speakers for $19.95. More or less $40 dollar bought you a working stereo. They didn't sound bad ether.
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                              • 31157
                              the way the chinese have kept the price down is because there is nothing mechanical, it has no tape or cd mechanism.
                              it's more like a pocket mp3 player with a power amp & front panel.
                              i dont know why all company's dont do this, who the hell needs tapes to unwind or dics to get messed up in the heat when you can just copy them to a memory card in the house.
                              • katzcaps
                                • Feb 2012
                                • 48
                                I wonder how good those really are. Kinda reminds me of the Pyramid/other brand radios/amps that were so popular years ago. The would advertise them at something like 500 watts (lol) and they all sounded like crap.
                                At any rate, I'm tempted by the cheap pricing. Too bad most of he models are sold out. For my needs I would need to have one w/ AM capability (gasp, I know). Guess I'll keep an eye on the site & order one when they become available.
                                  • 31157
                                  there are plenty more on ebay.
                                  i just like DX because it's all in one place, i have used them for years, and you can change the currency on the screen.
                                  AM may be an issue, it's not used much anymore and the actual electronics are pretty complex.
                                  you can do FM now with a single chip pretty much, but AM still needs the old coils & cans etc.
                                  btw, look at this!!!!!
                                  http://www.dx.com/p/lsqstar-8-touch-...d-focus-336428
                                  amazing that they even make a custom frame for it!
                                  • katzcaps
                                    • Feb 2012
                                    • 48
                                    What do you search for on ebay? I tried putting in a few of the names of those dx units and I didn't come up with many results...
                                    • eccerr0r
                                      old X58 triple channel board... memtest86 memory speed?
                                      by eccerr0r
                                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                      06-28-2025, 09:06 AM
                                    • spleenharvester
                                      Reverse engineering of 18650 4-channel tester
                                      by spleenharvester
                                      Hi friends
                                      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                      05-04-2025, 02:43 AM
                                    • CDNBrewer
                                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                      by CDNBrewer
                                      Hello Everyone,
                                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                      Symptoms:
                                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                      • I swapped the Left and Right surround
                                      08-05-2025, 09:29 PM
                                    • zen
                                      PS48 Bose sub & head unit schematic / advice please.
                                      by zen
                                      PS48 is model for sub & where i suspect issue lies .
                                      CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
                                      Can't seem to measure any voltages at secondary side of PSU within SUB unit ....
                                      07-08-2022, 07:53 AM
                                    • mikey5791
                                      Help on car amplifier only one channel works
                                      by mikey5791
                                      Hi all forum members,
                                      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                      08-06-2025, 10:36 PM
