Frequency sweep on audio tape
  • Tom41
    • Oct 2005
    • 336
    • England
    Recently I recorded a frequency sweep (low to high) on an analogue audio tape, trying to see what is the highest frequency it could properly reproduce. To my surprise, when I played it back I heard other tones going all over the place - downward sweeps as well as upward!
    I've attached a picture of the spectrogram. The top shows what I recorded to the tape (generated in Audacity), and the bottom is what I got on playback.
    Anyone know why this might have happened? Something to do with harmonics or 'reflecting' signals? I wonder if tapes inherently have some sort of 'reflecting' effect on certain frequencies...
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Frequency sweep on audio tape
    Your input signal was clipping at the recording device.
    A working TV? How boring!
    • Tom41
      • Oct 2005
      • 336
      • England
      I thought 'clipping' was only to do with the strength (amplitude) of a signal, not its frequency.
      I generated the sound with Audacity, burned it to an CD as full uncompressed CD-DA audio, then put the CD in an expensive hi-fi system. I played the CD there and used the hi-fi to record to cassette.
      To rule out any distortion caused by the CD decoding, I also recorded the CD output from the hi-fi and the trace looked almost exactly like the signal I generated in the first place. Only when playing back the cassette did these extra tones appear.
      • Uniballer
        • Jul 2013
        • 334
        Might be partly due to print-through effects. Especially if the signal is strong.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Like i said, it's not the CD causing the issue, or the CD playback device. I stated explicitly that the recording device was clipping. Either the tape preamp, the tape head or the tape itself was overloaded, causing these audible artifacts.
          A better method is to use pink noise and a RTA (can be done with free software) to check the frequency response.
          • Towncivilian
            • Jul 2014
            • 22
            • US
            http://www.tapeheads.net/showpost.ph...76&postcount=9
            ASUS P8Z77-V LK, i7-3790, 32GB DDR3-1600, GTX 750 Ti, 256GB 840 Pro & 2x1TB / 1x2TB, Creative SoundBlaster ZxR, FSP Aurum S 400W
            abit IP35 Pro, Q9300, 16GB DDR2-800, GTX 750 Ti, 128GB 840 Pro & 1TB WD Blue, Corsair CX430
            HP d530 CMT, P4 EE 3.2ghz (with modded BIOS for correct microcode), 4GB DDR-400, ATI 9600XT, X-Fi, 80GB Velociraptor, 500GB WD Blue, XP SP3, Sony SDT-9000 & Seagate CTD-8000 DAT drive for ripping audio DATs
            abit BX133-RAID (recapped + SMD caps installed in processor socket), PIII-S 1.4ghz Tualatin, 768MB PC133, FX5600, SoundBlaster AWE32, 40GB Deskstar, Windows 98SE
            Depeche Mode Live Wiki
              • 31094
              the cd player will be filtering the beat frequency out so you dont hear the laser too.
              you should link the soundcard to the tapedeck.
              also, i wouldnt be surprised if your input is picking up noise from inside the pc.
              • Tom41
                • Oct 2005
                • 336
                • England
                I'd say the theory of the tape being saturated/clipping seems right. I recorded over the sweep with some speech, and could still faintly hear the sweeping tone upon playback - almost as if the tape was too far saturated to be fully erased.
                I also recorded the same sweep (from the same CD) twice; once on a cheap boombox and again on the expensive hi-fi. Looking at the spectrograms, the pattern of tones going up and down was quite different on the two recordings! Must be some sort of resonant frequency - perhaps these could be used to 'benchmark' cassette recorders lol
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Over-saturation will do that to a tape. Use a bulk tape eraser to eliminate it.
                  The sweeps are showing you the differences in the frequency responses between the two machines.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Are you using a metal tape (CrO2, FeCr, Metal) by any chance? If yes, that can cause problems too if you don't have a hi-fi deck with metal-tape capability. Most late 80's stuff and newer don't.
                    Also, try erasing the tape several times and turn off any Dolby or MPX filters that your deck might have (if that is possible at all - 90's decks and newer lack all of these option altogether and usually employ Dolby B/C that cannot be turned off). Lastly, make sure you're not saturating the tape. Does your deck have power level meters? If yes, make sure you don't go over 0 dB point while recording.
                    By the way, what did you use to create the sweeping signal and do you mind posting it here? I'm curious to try this on my Marantz SD4000 tape deck.
                    • dreamlayers
                      Weird clipping on Logitech Z-10 speakers
                      by dreamlayers
                      I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                      05-22-2025, 11:41 AM
                    • RetroComputingGrotto
                      IBM LTO 7 Tape Drive - Dust Sensors??
                      by RetroComputingGrotto
                      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                      09-19-2024, 01:54 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • triplefour
                      LG 75UN8570AUD panel issue fixed with tape.
                      by triplefour
                      I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                      add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                      07-17-2023, 10:22 PM
                    • alltvrepairs
                      Hisense 55AS6G screen double sided tape required
                      by alltvrepairs
                      I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                      I need a source for this type of double sided tape adhesive please.
                      https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                      Tks!
                      07-17-2025, 09:32 AM
