Need help identifying capacitor
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Need help identifying capacitor
    https://en.wikipedia.org/wiki/Inductor
    Quote: "An inductor typically consists of an insulated WIRE wound into a coil around a core."
    You'd (have to) be worried if your meter was saying "OL" (out of range) on the resistance (ohms) measurement of an inductor.
    Or what makes you think they're bad?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      Originally posted by vierdane
      So I test both inductor 8019P 100L. . Reading 0.00 all three different holms meter including a Fluke. I think they bad? I can't find a place on line where to purchase them.
      Unless big quantities.
      Can someone help
      DCR reading of that inductor will show really low Ohms reading, Ohm reading will only tell you if the inductor has open circuit or not, you need meter that will read inductance.Why do you think it is bad?
      • R_J
        • 9569
        Can someone help
        They are NOT BAD! you are using your meter to measure the DC resistance of a piece of wire. YOU are NOT measuring the inductance of the coil.
          I do not think we are getting through.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            "No good deed goes unpunished"...
            • kjd
              • Nov 2019
              Have exactly the same issue with a Pro 600. 2200uF cap on the amplifier board leaked. I think the L101 and L102 (8019P 100L) inductors are OK though. Also, u1 and surrounding diodes on the power supply board all burned.
              Did anyone get a schematic for this unit? If so, could you post or send?
              K
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Ambro
                Help identifying missing smd capacitor for HP elitebook 840 g3
                by Ambro
                In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
                I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
                I've attached a picture of where it's located on the board.
                Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
                Thank you for any help you can provide....
                09-09-2023, 06:21 PM
              • Adenitz
                Explanation of capacitor rating
                by Adenitz
                I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
                The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
                What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
                12-26-2022, 12:36 AM
              • jeffer76
                Help identifying capacitor rating
                by jeffer76
                I need help identifying this capacitor. Voltage and rating?'...
                03-04-2020, 02:30 PM
