Help identifying missing smd capacitor for HP elitebook 840 g3
  • Ambro
    • Sep 2023
    In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
    I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
    I've attached a picture of where it's located on the board.
    Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
    Thank you for any help you can provide.
  • mon2
    • 14685
    Re: Help identifying missing smd capacitor for HP elitebook 840 g3
    Most likely a typical despike capacitor that should be applied on each and every digital IC between the power rail (VCC pin) and ground. The value is often 0.1uf and the voltage rating of 6 volts or higher is fine. The local flash memory device is probably operating at 1v8 or 3v3.
    Physical size appears to be 0402 or perhaps 0603. Suspecting the 0402 but both versions are dirt cheap from Digikey or Mouser. You should be able to find these on a donor motherboard as well.
    This capacitor is nice to have but will not be a show stopper if it is missing.
    • Ambro
      • Sep 2023
      mon2, thank you so very much for the detailed information! I ended up purchasing a very cheap donor board from eBay so I can replace the cap. Good to know that it's not going to result in any issues not being there.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • krob80
        PS5 Edm-010 No Power - Help identifying missing capacitor
        by krob80
        Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
        It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
        When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
        I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
        05-15-2025, 04:24 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • benberry24
        surface go 2 missing capacitor, Motherboard# DA0Z93MBAE0
        by benberry24
        I have surface go 2 that a capacitor was nocked off. Can anyone tell me the value of the missing capacitor or if it's needed.
        Motherboard# DA0Z93MBAE0...
        09-12-2025, 10:16 AM
        HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
        This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
        09-07-2024, 05:50 AM
